xu-1 Camshafts
107 replies to this topic
#51 _rat catcher_
_rat catcher_
Posted 05 January 2008 - 05:53 PM
Hi fellos im still not convinced that early 72 xu1s had the HX cam. my brother has a 9-72 bathurst special and his cam is the HX. if anyone with an early lj xu1 with a standard motor has pulled there motor down lately then we would know.
#52 frash da bucket
frash da bucket
  • 1,890 posts
Posted 14 January 2008 - 08:54 AM
Hi all,
Iv'e just pulled out my camshaft 9/72 xu-1 over the weekend,finally removed it,
On the front it has HX,and on the end of it has stamped and saying, JC,then below
it says,387HH,cheers.
#53 _vin150cars_
_vin150cars_
Posted 14 January 2008 - 12:30 PM
ha frash
could you measure the height off a few lobe's
to see how much lift at the lobe
my hx cam has only got c stamped on orther end,
and has about 285''[tho] lift at lobe'
that would make it a wade 373 grind,
your's might have about 303'' lift at lobe
very interesting
#54 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 14 January 2008 - 03:04 PM
Hi
Thanks frash. This adds to the body of knowledge.
Bazza
#55 _threeblindmice_
_threeblindmice_
Posted 14 January 2008 - 06:16 PM
#56 _threeblindmice_
_threeblindmice_
Posted 14 January 2008 - 06:20 PM
#57 _threeblindmice_
_threeblindmice_
Posted 14 January 2008 - 06:22 PM
#58 frash da bucket
frash da bucket
  • 1,890 posts
Posted 14 January 2008 - 06:57 PM
Hi all,thanks to threeblindmice for posting my pictures of my camshaft
and dizzy,I made a mistake for posting the wrong numbers on my dizzy,
was covered in oil and dirt,very hard to read when fitted in the torana,cheers.
#59 rodomo
Posted 14 January 2008 - 10:22 PM
I was talking to my brother in law tonight (about family stuff) and as usual the topic turned to cars.
He had a genuine LC XU1 in the early 70's.
We spoke about cams as I remember when he changed his (I was about 12 at the time) and I mentioned the "HX" cam.
His instant response was no, it was a "XH" cam and he commented that he had looked up the part No. (he worked at a Holden dealer).
The paperwork from "Wade's" above^ seems to confirm this?
#60 _vin150cars_
_vin150cars_
Posted 15 January 2008 - 11:35 AM
got your email john
measure the overall height off lobe,
then measure how wide and take that figure away from height,
then you will have valve lift at lobe, do it with vernier's or get someone's help,
i dont know about camshaft figure's
allso clive cams told me that wade cams made all the cams and
G.M.H STAMPED THEM
#61 frash da bucket
frash da bucket
  • 1,890 posts
Posted 16 January 2008 - 10:58 AM
Hi vin150cars,My local engineer is measuring my cam lobes for me,will have the results for you today,John.
#62 _threeblindmice_
_threeblindmice_
Posted 16 January 2008 - 03:12 PM
Frash has pulled out his cam because.
Can't wait to see the cam gear
#63 _threeblindmice_
_threeblindmice_
Posted 16 January 2008 - 04:22 PM
Cam gear pictures have arrived,cam gear has damage in only two spots at 180 degrees apart.
#64 frash da bucket
frash da bucket
  • 1,890 posts
Posted 16 January 2008 - 05:54 PM
Hi All,
Thanks to threeblindmice for posting my pictures,of my cam gear,and crank gear,I just want to have your opinion as as what happened to my crank gear its damaged on the back of the gear towards the block,I drove the xu-1 for 7years like that,it only had a noise when the engune was hot,didn't affect the performance of the car,and the the oil pressure,was not affected either,regards,John.
#65 rodomo
Posted 16 January 2008 - 08:27 PM
Whatever caused that is either in the sump or lost on an oil change.
#66 frash da bucket
frash da bucket
  • 1,890 posts
Posted 16 January 2008 - 10:03 PM
Hi Rodomo,Never could find it in the sump,i got a magnatized sump plug,I had problems with this guy in a work shop 7 years ago,i think he damaged it with a slide hammer,never found metal in the sump,well down the track a lot of things happened to him,his car caught on fire,burnt to the ground,and another was stolen of him,i strongly belive in karma,John.
#67 rodomo
Posted 17 January 2008 - 12:16 AM
It looks like something fell into the gears? Is there any scoring on the face of the block?
#68 _LGN347/24C_
_LGN347/24C_
Posted 17 January 2008 - 03:50 AM
thats very odd ,is the oil feed nozzle still there?maybe he dropped the crank, and thought 'ah f*ckit' and put it together anyway,i doubt a puller would do that.daz :huh:
#69 frash da bucket
frash da bucket
  • 1,890 posts
Posted 17 January 2008 - 05:47 AM
Hi Daz, oil nozzle has not been touched,cheers.
#70 frash da bucket
frash da bucket
  • 1,890 posts
Posted 17 January 2008 - 05:55 AM
Hi Rodomo,There is no scoring on the face of the block,removed crank gear yesterday,with help from threeblindmice,cheers.
#71 _LBW_
_LBW_
Posted 17 January 2008 - 08:07 PM
Would anybody like to have a copy of the original GMH CAM profile drawings for the GMH part No 9929247 as identified in the Fiv Antonio book?
I have a copy of the actual drawings ex-factory specifying part number 9929247 with the complete set of profiles.
LBW
#72 _vin150cars_
_vin150cars_
Posted 18 January 2008 - 09:17 AM
yes we would all like to see them posted on here
#73 frash da bucket
frash da bucket
  • 1,890 posts
Posted 23 January 2008 - 06:06 AM
Hi all.
Fitted new camshaft gear,and crank gear,torana is running much better than before,and fixed,fauly vacuum advance unit diaphram,much better,Happy Australia Day weekend to everyone,cheers.
#74 _Ozzie Picker_
_Ozzie Picker_
Posted 13 June 2011 - 06:44 PM
LBW
looks like LBW has flown the coop,
anyways,i,ve got my 73 xu-1 150 engine running again after a very long time and its running to smooth,so i,m guessing the cam is not correct,so i,m going to replace it with something very lumpy.
could someone help me with a grind for this kind of engine please.
been looking at clive cams and ivan tighe cams.
#75 _sunburst73-xu1_
_sunburst73-xu1_
Posted 13 June 2011 - 06:55 PM
Craig I can get you this cam and running in my car at the monment(Very Happy)
Based on the 72 Bathurst cam
48/84
duration@50thou
226 inlet
227 Exhaust
430 value lift
110 lobe serperation angle
and its 2 degrese advance.
cheers Dane
