dattoman's brake upgrade kit
98 replies to this topic
#76 _CHOPPER_
Posted 10 March 2007 - 11:08 AM
What I forgot to add was that I need the measurement "B" ( from the DBA catalogue ) to be between 71 mm and 106 mm.
#77 dattoman
Posted 10 March 2007 - 02:52 PM
Staying with Commodore discs
You can get a VT style hub drilled in your required pattern
Using this and any of the larger VT onwards discs you will have the same dimension "B" as the 019's
DBA5055 343mm
There is also a 362mm and larger again if you get real keen
These are 32mm thick though..... so the CP5200 which suits 28mm would need to be bridge spaced in the centre (not advised) or step up to the CP5555 6 pot caliper
Discs can be had undrilled depending on when production runs are done to pull them off the line
#78 _CHOPPER_
Posted 10 March 2007 - 03:44 PM
That was my first thought, except wouldn't you still wind up with a 69.5 mm ( Commodore ) centre bore, as opposed to the 71.5 mm centre bore of the Ford? Or can some places deal with that too? I'm guessing I'd be heading to Race Brakes in North Melbourne or BGT in Burwood Rd. Hawthorn for that? I know it's going to cost more money, but isn't that half the fun? The other half of the fun is explaining the extra expense to your wife. But since I haven't had a wife for over 12 years, it looks like I'll miss out on that bit.
#79 _LX8VD69_
_LX8VD69_
Posted 10 March 2007 - 03:48 PM
hi neil i just found this thread and back in one of your first posts you mention trying to find another way to sort out the hand brake issue when running a later model commodore disc brake rear end, does that mean youve sorted it out with the earlier style? i am running VN disc brake set up that ive adapted to the banjo diff and im still trying to sort out the hand brake, as you are probbaly aware the sedan hand brake cable is too short, apperantly the wagons cables are supposed to fit but i cant see how when sedans and wagons are exactly the same until after the diff. ive been wondering if crewman hand brake cables may be longer but i suspect they would be the other set up any way so no gain there. any advice/ ideas?
cheers adam
#80 _CHOPPER_
Posted 10 March 2007 - 03:55 PM
Talk to your local brake place, as they should be able to measure and order custom length cables for you.
#81 dattoman
Posted 10 March 2007 - 05:10 PM
Make some spigot spacers to get the centre bore you want for your wheels
Dave 355LX is having some made for his now as he is running Toyota (I think) wheels on his (Ford pattern but 12mm studs.. so not actually Ford)
Handbrakes I haven't got to yet
#82 _CHOPPER_
Posted 10 March 2007 - 08:09 PM
So where would I go in Melbourne for some spigot spacers?
#83 dattoman
Posted 10 March 2007 - 08:12 PM
I think you'll have to go see someone with a lathe
Dave is getting his made by his diff shop
#84 makka
makka
    A møøse once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 11 March 2007 - 07:16 PM
cheers adam
Adam, wagons have a longer wheelbase than sedans, as do statesmans
#85 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 11 March 2007 - 10:06 PM
Yeah had some rings made to slip over the hub of the disc's and the axle hub's on the back as well. Very basic, any machine shop will do them with ease.
Easiest thing is to take all your bits and peices in (rims hubs etc) that need adapting, then you'll be sure no drama's. Oh and I'd suggest telling them what depth you want too, mine I think are a little too shallow, only about 5mm seating face for the centre of the rim hubs now, but better than nothing.....
Dave
#86 _TOBES_
_TOBES_
Posted 12 March 2007 - 10:05 AM
Was talking to Ian from Rare Spares in Christchurch on Friday, sorting the dispatch of my new rear axle for the VL wagon, and asked him to send me a second disc brake hand brake cable for the Torana. He told me they were the all the same length. He checked his GM parts listing while we were on the phone and they only list one cable for sedan and wagon...???
Keen to find out if this is correct.....
#87 _CHOPPER_
Posted 16 January 2008 - 10:10 PM
Today I picked up my pair of DBA 019's. How are the adapters going Neil?
Two years later...
Is there much of an update on this?
#88 _rorym_
Posted 16 January 2008 - 10:46 PM
Probably not...unlike b4...when he was sitting on the lounge watching porn...he hardly comes on now...some bullshit excuse of the business is hot and he is too busy to talk to us... :cry:
#89 _CHOPPER_
Posted 16 January 2008 - 11:08 PM
Since this is related to his business, I would think it would be on his list of priorities. In any case, I have a template I will probably play with if Neil is too busy. I also must do something about this project this year, it's getting a bit long in the tooth.
#90 dattoman
Posted 16 January 2008 - 11:19 PM
Sorry guys
I have had some issues
Failed relationships
Changing jobs a few times
Business starting then going broke leaving me $40k in the red
Girlfriend murdered in August (stranged to death by her jealous ex)
I haven't touched any of my projects in nearly 2 years
So I've kinda had a few things on my mind
Currently unemployed too
355LX Dave has a set of calipers but hasn't decided on what disc to use yet
The-GTS has this setup already on his car and made his own brackets
Maybe he can assist
#91 _CHOPPER_
Posted 16 January 2008 - 11:28 PM
In that case I won't bring it up again, unless you update this thread Neil. Sorry to hear about the happenings of late.
#92 _rorym_
Posted 16 January 2008 - 11:40 PM
Jesus Neil as usual I was joking...
Anything you need / we can help with PM the guys...You know who.
#93 dattoman
Posted 16 January 2008 - 11:58 PM
I know rory... no harm done
I'm getting over things slowly and dealing with some issues
I'm just in limbo at the moment
Off to USA for an escape in Feb... you could send money.... lol
#94 _the gts_
_the gts_
Posted 17 January 2008 - 02:41 AM
Guys I have a mate that has just started up a machine shop. If you need brackets I can probably get him to make some. Not sure what he will charge But he would be able to copy mine exactly.
My car is apart so wouldnt be too hard to pull mine off
#95 GML-31
Posted 17 January 2008 - 07:41 AM
thats quite a list Neil... keep your chin up... and sorry cant send money, save your money and move back to qld.
#96 dattoman
Posted 17 January 2008 - 10:59 AM
Now thats funny !!
Thanks GML I needed that
I've never lived in QLD
Just passed thru a couple of times
I was going to enter the "Who had the crappest year" thread but thought it best to keep to myself
Further down the road now and think I'm getting ontop of a few things
OK... don't send money... maybe just a maid and gardener... this place is a mess
#97 _rorym_
Posted 17 January 2008 - 05:11 PM
Roundup is in the mail...thats the garden done! :clap:
#98 _CHOPPER_
Posted 17 January 2008 - 11:03 PM
Neil, I'll send you around my ex. She's a nut case, but at least it will keep her away from the kids.
#99 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 29 March 2013 - 08:49 PM
AP 4 pot (CP6607 I think)
DBA 4049
Harrop drum adaptors
Thats kinda the plan anyway
I did a Google search and found this thread. What I couldn't find was any info on those AP calipers you mentioned, was that a typo?
