310 replies to this topic
#76 kudu
kudu
  • 1,492 posts
  • Car:LH SL/R 5000
Posted 11 July 2009 - 07:21 AM
In this conversion it used the sunbird handbrake setup. I don't want to remove the centre console and want to keep the floor handbrake. Can this still be done?
#77 76lxhatch
Posted 11 July 2009 - 08:17 AM
Yep I kept the standard hand brake setup. Used the Skyline cables at the diff, cut the bracket on the outside of the lower arm mounts off and welded on a new one a few inches further back to suit the slightly shorter Skyline cables. Then it was just a matter of finding a cable to complete the loop, I had collected so many diff parts by that stage that I found a Falcon one did the job nicely but it would be very easy to get one made.
#78 _mowie_
_mowie_
Posted 29 October 2009 - 03:40 PM
So i can put my commodore brakes on these diffs but might have issues with them fouling on the shocks. I know everyone will say to use the skyline brakes but i already have new rotors and have rebuilt the calipers.
Tom
#79 76lxhatch
Posted 29 October 2009 - 04:08 PM
Bolt one on and find out, won't take long. If it clears the shock and you can get the handbrake cable to it, should be fine.
#80 _brett_32i_
_brett_32i_
Posted 30 October 2009 - 06:35 AM
without sticking my head under the car, if the calipers hit the shocks you could try swapping the backing plates left to right and put the calipers on the front of the axle?
the skyline and commodore bolt pattern for the backing plates/bearing retainers is the same, but are at different angles, so the commodore backing plates will need to be redrilled. (i remember one hole will line up)
#81 76lxhatch
Posted 30 October 2009 - 06:51 AM
I think he is talking about mounting the Commodore brakes on the Skyline angle without modification. I just went and had a look at the old discs though, and the Commodore ones are a lot deeper offset so I'm pretty sure the calipers wouldn't fit around the shocks. Dunno what would happen if swapped left to right, they'd be sitting very low...
#82 _mowie_
_mowie_
Posted 30 October 2009 - 10:46 AM
Thanks guys, ill just have to have a look when i get home in a week to see. 76lxhatch, wouldn't the mounting position for the calipers need to be different in order to take the deeper offset of the rotors? (is that what you mean?)So the issues with rotating the tube end caliper mounts would be that the hand brake would need to be altered and the bleed nipple would be in the wrong position?
It's probably worth me just rebuilding the skyline brakes. Oh well...
Edited by mowie, 30 October 2009 - 10:47 AM.
#83 76lxhatch
Posted 30 October 2009 - 04:04 PM
The Skyline and Commodore calipers are very very similar, only difference is the built-in handbrake on the Skyline ones, bleed nipples in same place. The Skyline mounting position is rotated maybe 25 degrees (at a wild guess) up at the rear compared to Commodore, no issue with bleeding. The Commodore calipers would sit further inboard due to the disc offset I reckon, although perhaps the axle flange position makes up for some or all of this?
edit: looking at Rory's pic on the previous page, it looks like he has had the flange on the end of the housing rotated almost back to Commodore position, mine are standard R31:
Edited by 76lxhatch, 30 October 2009 - 04:11 PM.
#84 _mowie_
_mowie_
Posted 30 October 2009 - 04:21 PM
Reading some info on these diffs some have mentioned the welds between the center housing and axle tubes were insufficient, i was thinking of having the tubes cut off and welded back on the the mounts vertical on the forward side of the diff, and swapping the calipers left to right.
#85 _rorym_
Posted 31 October 2009 - 02:48 PM
Might just be the angle of the photo, I used R31 mounting plates as well.
#86 Statler
Posted 10 March 2010 - 12:27 PM
Hmmmmm......interesting!
Aussie diffs aren't recommending this conversion anymore!
They seem to prefer the commodore over the skyline.
Silly me!......i thought they were both the same!....but one didn't need shortening?
#87 76lxhatch
Posted 10 March 2010 - 12:46 PM
They are exactly the same housing (besides length) under all the brackets. Maybe something to do with having to change the stud pattern? Seems you'd have to anyway unless you want to be buying custom wheels to get the right offset in Commodore pattern. Narrowing the housing is pretty easy if you just do one side and use both short VN axles - hmm, I wonder if centering the housing like this allows more of the top arm brackets to be welded to the axle tubes rather than the cast centre?
#88 _rorym_
Posted 14 March 2010 - 03:15 AM
NO same same.
R31 Skyline 28 spline axles
Pintara..same diff same everything except 25 spline axles and diff.
incorrect.
auto pintara had 25 spline and 4.11 ratio. manual had 3.9 and 28 spline
We are talking diff housings and splines...not ratios....re-read the question.
#89 rodomo
Posted 14 March 2010 - 07:43 AM
NO same same.
incorrect.
Brett is pointing out that auto and manual Pintara have different splines the way I read it?
Edited by rodomo, 14 March 2010 - 07:44 AM.
#90 _brett_32i_
_brett_32i_
Posted 14 March 2010 - 10:16 AM
correct
#91 _rorym_
Posted 14 March 2010 - 12:25 PM
2 Pintara diffs I pulled both had 25 spline axles..1 manual and one auto....who knows..maybe production line stuff.
#92 _brett_32i_
_brett_32i_
Posted 15 March 2010 - 05:21 PM
mine was 28 spline 4.11:1
cant remember now manual or auto, but its what all the commo guys go for to get the 4.1 ratio..
#93 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
  • Car:76 LX Sedan, 4 seater
Posted 01 April 2010 - 03:20 PM
Hey Col,
how much more do they make in cutting down the diff??? I think there is your answer.
Just supply an R31 diff and they have to sort it for you.
Grant..
#94 Statler
Posted 01 April 2010 - 03:47 PM
Hey Col,
Grant..
Hey Grant,
They prefer the commodore housing......which needs to be shortened. Compared to the Skyline....which doesn't!
#95 _slowlx_
_slowlx_
Posted 01 April 2010 - 09:05 PM
Hey guys great info on this conversion. Does anyone know if one was to get the axles changed and discs redrilled to suit the original torana pattern whether the original 13" torana wheels would fit over the skyline rear calipers?
#96 76lxhatch
Posted 01 April 2010 - 09:17 PM
Don't quote me on this but I doubt it, although I know for sure that 14s will fit
#97 TerrA LX
Posted 01 April 2010 - 09:43 PM
What length are the skyline axles?
i assume they would be the same length as a9x?
#98 76lxhatch
Posted 01 April 2010 - 10:05 PM
I doubt it, long and short axles as with the Commodore Borg Warners, rather than equal length like the Salisburys
#99 TerrA LX
Posted 01 April 2010 - 10:42 PM
Ah, yup. Blond moment sorry.
So does someone have some lengths handy from a conversion?
I seem to remember 660mm as the short one and used a VN short as the long but both being 10mm short overall.
#100 _slowlx_
_slowlx_
Posted 06 April 2010 - 08:02 PM
Hey guys called up 2 well known diff shops in the keysborough and dandenong areas asking about prices to convert the r31 diff. They both said the same thing that they do not recommend this conversion. Their words were that it would not pass an engineer, and that it wasn't the right way to do it. One shop pretty much said he would refuse to change the pattern on the exisitng r31 axles... Their answer was to make billet axles but then just to weld on the brackets and new axles without touching the centre or diff gears would cost almost $1500. They both recommended Cutting down a vn diff to fit quoted me around $900 to do this and weld on the brackets, but then your stuck with commodore stud pattern so dunno now.
