i304 into LH
93 replies to this topic
#76 _rammaLH_
_rammaLH_
Posted 08 February 2011 - 05:07 PM
Hit bit of a wall with it today :(
The nice set of 15 inch simmons with yokohoma tread are no good as the inside of the front rims hit on the ball joints. Will run spacers down the track but wont get through engineers like that so looks like im up for another set of farken wheels just to get certificate done!!! GRRR!!!
anyone else come across this?
Brett
#77 Statler
Posted 08 February 2011 - 06:05 PM
Cant you just replace the inner rim?
#78 _rammaLH_
_rammaLH_
Posted 09 February 2011 - 06:30 AM
Not sure! Would i speak to somewhere that deals with simmons or somewhere like wheelworks?
brett
#79 Statler
Posted 09 February 2011 - 08:40 AM
I think Retro wheels are now selling the 15" rim pieces.
Around $150 + labour/rim.
#80 gtrboyy
Posted 09 February 2011 - 08:26 PM
Could it just be hitting the bleed nipple on top of the ball joint?
#81 _rammaLH_
_rammaLH_
Posted 10 February 2011 - 05:40 AM
had a closer look last night and its actually rubbing on the plate above the ball joint, close to where the bleed nipple is!
Looking into getting some narrower inners for the two front wheels, should get me out of trouble if i can find any! on the right track you think?
brett
#82 gtrboyy
Posted 10 February 2011 - 10:45 AM
Can't quite remember the brand but the was an aftermarket top ball joint that was alot thinner with no bleed nipple that may just get you out of trouble,earlier pics look like you still had the standard ball joints which are quite chunky in comparison to aftermarket ball joints.
With the rims it's more likely that you may need to go to a different offset like a hq.
#83 _rammaLH_
_rammaLH_
Posted 11 February 2011 - 06:02 AM
spoke to retro wheels yesterday. They have narrower inners for the front, $260 bucks a wheel flus frieght up and back from melb :( !!! Considering its something most of us can do ourselves im gunna try figure out a way to get just the inners sent down. If im going to be spending $600 or so ill just buy another set of 16 or 17 inch simmons or something!
Will have a look tonight again but its rubbing on the plate not the ball joint itself!
Brett
#84 Statler
Posted 11 February 2011 - 02:41 PM
Can you post a pic m8 of the offending area?
It might give us a better idea of the problem.
I assume Retro are quoting you the price with labour? They dont think that us [as comsumers] have the ability to sequence torque down the bolts. More to do with legalities me thinks. :)
#85 _rammaLH_
_rammaLH_
Posted 12 March 2012 - 07:21 AM
Well after another long stint of no progress on car i have had some wind blown up my arse to get it done by december for my sister in laws wedding so its back on like donky kong now!
Considering i have gone from drum to disk brake rear end whats by mest booster/master cylinder combo?
Other question i have if if i put handbrake on floor on a lever instead of a pedal will i have any issues with engineers passing it?
Will get some more photos up as i progress but between now and december car WILL be finished and on the road finally. Cant believe it was 2008 when i first posted on the forum about my plans with the car. Understand why it takes people 10 years to do a full resto on a car now!
ramma
#86 bryanw
bryanw
  • 294 posts
Posted 01 December 2012 - 09:17 PM
Well! its December. where is it?
#87 _rammaLH_
_rammaLH_
Posted 10 February 2013 - 07:30 AM
Bit more progress on my project guys,
Rear brakes are now completed, full vs Commodore rear brake set up, disks, calipers pads and brake lines. Handbrake cable getting delivered next week then we will be fixing a few little things and will be off to exhaust shop. Been a bloody long project but I'm nearly there! Will get some pics up when I can figure out how!
#88 _rammaLH_
_rammaLH_
Posted 10 February 2013 - 07:57 AM
Rear brakes :)
#89 _red roar_
_red roar_
Posted 10 February 2013 - 08:40 AM
Brett did you get you front Simmons sorted?
#90 _rammaLH_
_rammaLH_
Posted 10 February 2013 - 08:44 AM
Not as yet mate, need to look again at the options to get that sorted out. Just running some spacers at the moment!
#91 _rammaLH_
_rammaLH_
Posted 04 May 2013 - 03:30 PM
Handbrake cable measured up and ordered, have been doing some club stuff and my LH will be going on a club permit.
After 5 years it is so close now, putting some peddlers springs and shocks in front as the rear already has peddlers gear.
Will be off to exhaust ship in around 3 weeks, tidy up a few small things then get inspected and club plates.
#92 _rammaLH_
_rammaLH_
Posted 01 June 2013 - 08:15 AM
Spent last 2 days working on it. UC handbrake lever mounted on floor, used a vn handbrake cable and modified it to suit. Needs some adjusting but seems to be working ok.
Pumped brakes up and pedal came good after a couple of leaks got sorted.
Booked in for exhaust Tuesday!
#93 _LH mike_
_LH mike_
Posted 22 September 2013 - 06:07 AM
what hub did you use for the front brakes?
#94 _Wattsmini_
_Wattsmini_
Posted 19 November 2013 - 11:17 AM
Hi there do you have any pics of fuel set up
