Commodore booster and Master on LH/X.
144 replies to this topic
#76 _rorym_
Posted 15 March 2009 - 06:27 PM
Thanks Fuzzy...That just did my head in.....
#77 dattoman
Posted 15 March 2009 - 06:34 PM
XD Falcon doesn't have ABS so I never mentioned it
Infact I never mentioned using a Commy master at all
#78 _rorym_
Posted 15 March 2009 - 09:11 PM
Hmmm...so I have 3 commodore master cylinders...I will do ..Eene Meeni Minee Moe...on them...
Send me an address and I will post this thing.
Edited by rorym, 15 March 2009 - 09:11 PM.
#79 dattoman
Posted 15 March 2009 - 09:34 PM
You talkin to me ?
Post it to Tiny
I'm not back till June
#80 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 16 March 2009 - 12:58 AM
I sincerely apologize Rory. :blink:
#81 _rorym_
Posted 16 March 2009 - 05:59 PM
Just trickin...
#82 _rorym_
Posted 17 March 2009 - 05:40 PM
I now have to work out what 1" masters I have ABS or Non ABS. They have 2 lines out of the front I am sure I traced straight to the front discs so that one should be Non ABS..Will check the wreckers at the wekend.
#83 _waz355_
_waz355_
Posted 17 March 2009 - 06:18 PM
I just bought one new from repco PBR for $175. Its a P10050 I think from memory.
Currently doing the same conversion Rory, except mine has the bent pushrod. Already have the dual diaphram booster, just need some rear drum set ups off a HQ or etc. Anyone got any?
#84 _rorym_
Posted 17 March 2009 - 10:13 PM
ABS was introduced on the VP in Aug 1992...so my VN one is OK...Have to check the other one.
Does the P10050 suit rear drums as well WaZ?..Thought it was for rear discs...??
#85 _waz355_
_waz355_
Posted 17 March 2009 - 10:57 PM
I thought they were for both disc and drum in sedans??? Does someone know this for sure??????????
#86 _rorym_
Posted 17 March 2009 - 11:04 PM
I am fitting a bias adjuster to both my rears so no drama for me.
#87 _rorym_
Posted 18 March 2009 - 10:09 PM
OK..I have 2 x VN V8 master cylinders..Non ABS so that all works fine..Didnt get a definative answer on the one line M/C from anyone including PBR. What you are after is the M/C with 3 outlets...2 close together at the front...one larger at the rear. These all have C/P of 2.4...seems to be what you are after...The single lines ones have a C/P of 3.1...later pressure point....= heavier cars...utes,Statesmans etc.
I now have 3 Dual boosters..I will get all 3 cut and shut and one will be for sale...with a 15/16" M/C. PBR says the 1" will require less pressure and promotes more "feel" in the pedal...the 15/16" one is a higher pressure push. They also said..unlike stated above...and I am just quoting what they said...the difference in pedal travel distance in the pedal in 15/16" and 1" will be almost unnoticable...I will look at that when the 2 cars are together and working....
Another thing PBR did tell me...with Nissan 4 spot calipers the only M/C to use is the 1" one due to the increased volume of fluid need to fill the void.
Interesting.....
Edited by rorym, 18 March 2009 - 10:12 PM.
#88 dattoman
Posted 19 March 2009 - 03:07 PM
What single master ?
Pics
#89 _rorym_
Posted 19 March 2009 - 06:03 PM
Attached File  MC.jpg   561.77K   58 downloads
Single line one on the left.
#90 _waz355_
_waz355_
Posted 19 March 2009 - 09:14 PM
Just did a conversion on mine today. VP dual diaphram booster and ford 1" master cylinder. Had the bent push rod booster in mine, tried to swap it over with the new booster, but couldn't. Cut both push rods and welded torana end to commodore booster. Had to change the brake line fittings and re do the double flares. Pretty straight forward really. Brakes are heaps better, but still have the same problem. Because of the size of the cam I have very little manifold vacuum so 3/4 of the way through a heavy application it starts to run out of air, looking into a vacuum tank.
This thread was very healful, here's a bad photo -
#91 dattoman
Posted 20 March 2009 - 06:25 AM
Don't confuse things rory
Thats got 2 outlets not 3
Thats an ABS cylinder off a Commy
#92 _rorym_
Posted 20 March 2009 - 06:56 AM
Yeah Thats what I thought...so the one we need has 2 outlets at the front and one at the rear.
#93 _rorym_
Looks good Waz.
#94 _waz355_
_waz355_
Posted 20 March 2009 - 12:59 PM
Thanks.
I have one sitting here 15/16 with the 2 front outlets and one rear if you want it? In good working order.
Edited by waz355, 20 March 2009 - 12:59 PM.
#95 _rorym_
Posted 20 March 2009 - 06:09 PM
I have 2 x 1" ones here.
#96 _waz355_
_waz355_
Posted 20 March 2009 - 06:14 PM
Are you sure you don't need 3, it will stop really well!
#97 _rorym_
Posted 20 March 2009 - 10:28 PM
2 x race cars
2 x boosters and M/Cs..
All is good.
#98 76lxhatch
Posted 21 March 2009 - 05:47 AM
So aside from ditching the proportioning valve, what do you gain with the newer master cylinder? Or is the booster the main reason for the change?
#99 antelopeslr5000
antelopeslr5000
  • 1,022 posts
  • Car:1977 LX SL/R 5000
Posted 21 March 2009 - 06:43 AM
I'm led to believe that the dual diaphragm booster (late LX to VR) is essentially the same item internally, just different push rod lengths and mounting position for master cyclinder.
#100 _rorym_
Posted 21 March 2009 - 09:02 AM
Its newer,deletes the prop valve..one less thing to fail...and the M/C is specifically designed for rear discs to give near correct pressure proportioning....and up to 1" to help with the 4 spot fronts.
