Commodore Booster to LH/X Rear Discs
108 replies to this topic
#76 _gsh253_
_gsh253_
Posted 04 June 2012 - 02:14 PM
HI
I know this has proably been stated before but can not find it.
all imformation is for commodore booster, thought the same as torana.
will a p10050 m/c fit a v8 torana dual diaphram, and if so
what other mods apart from b/lines and push rod lenght.
am running hq front brakes hz rear disc.
#77 dattoman
Posted 04 June 2012 - 02:28 PM
The P10050 bolts diagonally
So the front booster cannister needs to be changed or modified to suit
Or just contact this guy and get a rebuilt one ready to bolt on that you know will fit and work
http://www.hydroboost.com.au/index.htm
#78 TUF 308
TUF 308
  • 169 posts
Posted 14 June 2012 - 07:27 PM
I just completed this conversion myself, what a difference.the pedal feel is so much better and the brakes feel like they are working now.
front brakes are HQ cast iron and rear are R31 Skyline.
#79 _Torrie_Man_
_Torrie_Man_
Posted 30 June 2012 - 12:57 PM
Does any one know if you can bolt on a commodore booster with a straight rod to pedal if the Torana booster had a bent rod to the pedal? Or do i have to get a different pedal to suit? Im urgently needing some advice. Thanks.
#80 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 30 June 2012 - 01:42 PM
Can you weld? here's what I did - http://www.gmh-toran...00/page__st__50
Commodore rod is way too long and needs cutting down anyway, you might as well weld on the end of the bent rod...
#81 _a.vas_
_a.vas_
Posted 03 July 2012 - 01:31 PM
would it be easier to just change over the torana booster arm into the commo booster instead of shortening it?
#82 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 04 July 2012 - 08:57 AM
^^Easier to shorten it,they are a prick to get apart and the internals probably differ as well.
Como booster is slightly larger diamater i think.
#83 _a.vas_
_a.vas_
Posted 05 July 2012 - 05:11 PM
yeah i looked at it and didnt even want to attempt to take it apart! ended up just grafting the torrie arm on to the commodore one
#84 _Torrie_Man_
_Torrie_Man_
Posted 10 July 2012 - 07:15 PM
Just did the conversion, cut the bent arm off the torana booster and welded (carefully and kept shaft cool) to the Commodore booster shaft. I used a 15/16 Commo disc/disc master cylinder. I run Girling UC front calipers and R31 Skyline rears. All i can do is sing praise about this conversion. I now have an AWESOME pedal and feels/stops great.
#85 AbsynthHatch
AbsynthHatch
  • 765 posts
  • Name:Mark
Posted 10 July 2012 - 08:15 PM
Johnno
You got any pictures of your handbrake cables where they attach at the calipers
#86 _Torrie_Man_
_Torrie_Man_
Posted 11 July 2012 - 08:26 PM
Johnno
No, sorry not yet. I don't have a hand brake hooked up yet. I'm going to get some custom made very soon. I will post up some pics when they're done.
#87 IMORAL
IMORAL
    Bored
  • 2,569 posts
  • Car:LX SS HATCH - IMORAL
Posted 23 July 2012 - 02:11 PM
@ lx-ss ... new cylinder or second hand ?
Could be any number of reasons.. .and you need to slowly and individually check the car to determine which wheel , wheels or master are giving fault
Its new. WHen you did the mod did you have to do anything to the push rod between the booster and master cylinder?
I also noticed my m/c is on a slight angle but when its filled as high as it can go the ports are covered. It just feels like I still have air for some reason.
#88 _L32M20_
_L32M20_
Posted 25 July 2012 - 11:05 AM
it shuold move 33 to 35 mm out from booster in to mc.
#89 IMORAL
IMORAL
    Bored
  • 2,569 posts
Posted 29 July 2012 - 08:10 PM
Thanks.I will check it out.
I did find the front rh caliper to be flexing due to wear and the pistons retracted back after appliciation.
I managed to find a wilwood caliper to fit which is a 4 spot. ( I rang hopperstoppers and they told me only the hq caliper would fit my set up)
Any way the pedal has improved allot but what I have now noticed is when you push the pedal down firm the booster flexes out. (pushes the master cylinder foward) Can any one else that has the vn set up tell me if your does it?
I also noticed with the engine not running the pedal will not pump up rock hard like it normaly does on other cars
#90 _L32M20_
_L32M20_
Posted 29 July 2012 - 08:17 PM
my firewall flexes also
#91 _slaaar_
_slaaar_
Posted 21 August 2012 - 04:08 PM
does the pushrod on the master cylinder side of the booster have an adjustable screw end? Can you wind it back a bit?
#92 _76lxJAS_
_76lxJAS_
Posted 10 August 2013 - 01:48 PM
hey guys not long finished this hatch build
. ive got vt fronts
vp rears.
i think vk dual booster that bolted strait in. ( no mods) ??
vn ss 1" master
everything is brand new. i have bleed over 4 ltrs of fluid thought the system
yet my peddle is still spongy???
why does the booster rod need shorting?
mine reached the torana peddle perfect and fitted fine???
they are working but not 100% and the peddle is to spongy.
ppl say they need to bed in and it will firm up???
ive done approx 50km with as much stop and go as i can from 60km to 0, they have got a bit better stopping power but the sponge stays the same?
how do i attach pics here to show ppl the install??
#93 _76lxJAS_
_76lxJAS_
Posted 10 August 2013 - 05:50 PM
my appoligies the booster rod was cut to suit.
#94 _76lxJAS_
_76lxJAS_
Posted 11 August 2013 - 12:39 AM
sorry to keep on this one.just need to sort my spongy peddle asap.
any1 else here running this set up??
is bedding them in longer going to help?
#95 dattoman
Posted 11 August 2013 - 01:56 PM
How have you adapted VT fronts ?
Since they don't fit on there very well and are a shit caliper
Maybe some pics of your setup would help
#96 _76lxJAS_
_76lxJAS_
Posted 11 August 2013 - 03:17 PM
it was a conversion from romac in melbourne.
#97 dattoman
Posted 11 August 2013 - 03:37 PM
Oh gawd... so its a UPC-Mr Spares ebay special ?
How about some pics mate... lets see what the thing is and see if we can help
Have you tried isolating the issue to a single wheel or axle of the car by clamping off all the lines and trying to get a firm pedal to start.. .then drop a clamp at a time and see where the problem is ?
The rear backing plates might be bent
The hoses might be swelling
The front kit might just be a pile of mismatched doo doo
Pop up a new thread... lets try keep this one about what its about... since your issues going to go beyond the scope of this threads intentions.
#98 _m_att_
_m_att_
Posted 12 August 2013 - 01:36 PM
Hi guys, after some clarification .
I have an early model LX (4/76) originally a 6cyl. I am putting a 5litre VS engine and T5 into it.
I am having trouble sourcing a Straight arm V8 torana booster as everyone else seems to be.
My master cylinder is a P7210. Can I use this with the above mentioned boosters in this forum.
Which booster is easiest/best for conversion.
I will be running the drums on the back for now, until I do diff upgrade.
I have a mate with some exc condition HQ cast calipers, so may just have some discs turned down and re drilled torana pattern.
Any thought, or tips greatly appreciated.
This is my first build so a bit of a novice, and stupid questions will follow!!
#99 _m_att_
_m_att_
Posted 12 August 2013 - 01:50 PM
I want to keep my 14 inch hotwires
#100 dattoman
Posted 12 August 2013 - 07:59 PM
No you can't use the commodore booster with your Torana master as the bolt patterns are different
But a booster rebuilder might be able to use the front can from your Torana on the Commodore booster
Pushrod would need to be set up at the right length to suit too
