My newer Monaro
#301
Posted 16 January 2009 - 07:09 PM
Your car sound good and if you take it to the drags and dump it at the diff you wont want to change it back. Your video was in a shed which echos the sound, how loud is it outside? If its to loud you may have to change the mufflers but c what the DB is. Keep up the progress on the car as it will be great when finished.
Chears Neil
#302
_jabba_
Posted 16 January 2009 - 10:05 PM
I didnt actually push it outside but thats a good point... Ill just leave it until its finished, still alot quieter than off the extractors
#303
Posted 16 January 2009 - 10:13 PM
Have you got a crossover pipe in the exhaust at all? That might make it a bit different too.. even if it's not a merge X pipe, but just a balance pipe!
#304
_jabba_
Posted 16 January 2009 - 10:31 PM
#305
_jabba_
Posted 18 January 2009 - 10:22 PM
Edited by jabba, 18 January 2009 - 10:23 PM.
#306
_jabba_
Posted 22 March 2009 - 09:11 PM
#307
_jabba_
Posted 13 April 2009 - 04:55 PM
Also fitted the bonnet.
Edited by jabba, 13 April 2009 - 04:59 PM.
#308
_jabba_
Posted 04 June 2009 - 11:59 PM
No pics, ill take some when i've done a little more photo worthy but this is what i've done since i've last posted.
What i've done today...
I've stripped the fuel tank and painted gloss black with por15 and fitted it
fitted fuel line and brake line up to the front of the car
Had 2 braided brake hoses made up for the front calipers
Fitted the calipers with new front brake pads
Hooked up the auto transmission cooler and filled with fluid
Jobs for tomorrow...
Connect up the proportioning valve
Buy some vacuum hose to run from gearbox to manifold
Install throttle and brake pedals
Bleed brakes
do a skid
After that the car should be *drivable* under its own power.
I'm waiting on a few clips from rare spares, mainly the ones that hold the fuel and brake lines to the chassis
Ill post some pics when i've done the above list
Edited by jabba, 05 June 2009 - 12:00 AM.
#309
_mello92_
Posted 05 June 2009 - 01:30 AM
cheers mate, im keen on seeing this finished now!
#310
_jabba_
Posted 05 June 2009 - 08:49 AM
#311
_torriechick_
Posted 05 June 2009 - 04:10 PM
#312
_jabba_
Posted 05 June 2009 - 11:26 PM
I finished connecting the brakes up and bled them, everything went well exept the front left brake caliper is locked on. Ill pull it back off and see if i can free it up, i havent painted the calipers yet since i will still probably put a kit through them.
Pics arnt very exciting but here they are, excuse all the dirt and dust ill have to give everything a good wash...
I couldnt find a hose to use while bleeding so i made abit of a mess
Edited by jabba, 05 June 2009 - 11:28 PM.
#313
_jabba_
Posted 06 June 2009 - 11:14 PM
I had some weird problem trying to get fuel up to the carby, at first i thought it wasnt drawing the fuel up from the tank but after i removed the hose in the engine bay fuel slowly ran out. I ended up cracking the big nut on the rochester carb until fuel started running out of there and now its working fine, it must have had an airlock or something
Anyways...
#314
Posted 07 June 2009 - 11:36 AM
Congratulations Jabba!
You must be stoked mate
Well done mate!
#315
_jabba_
Posted 07 June 2009 - 08:45 PM
#316
_doogs_
Posted 18 August 2009 - 09:50 PM
#317
_jabba_
Posted 17 January 2010 - 08:03 PM
A mate came around and we fitted a shifter and a b&m shift kit to the gearbox. I didnt have the linkage that bolts to the gearbox so i straightened the shifter linkage off a 3sp gearbox, cut it in half and drilled a hole in it. Now i wont have to crawl under the car to change gears!
The b&m shift kit was extremely easy to fit, i just have to pickup a new filter and some auto fluid and it will be finished.
#318
_jabba_
Posted 21 February 2010 - 09:03 PM
<edit> if the above made no sence, i have actually painted the body completely once before but i wasnt happy with the job so i sanded it back and used that as the base for this new paint...
The doors/guards bonnet and nose cone all came out perfect, its just the body that i didnt re-prime that has a few small problem areas. Anyways its not a huge deal, just more sanding
This is all in base coat, no clear hence the lack of gloss
Here's the crazing...
#319
_@milco@_
Posted 21 February 2010 - 10:04 PM
#320
Posted 22 February 2010 - 02:11 PM
Do whatever it takes to get rid of that crazing mate.
Any aera that has come up needs t obe completely stripped, and etch primed again from scratch.
If you dont.. Your car will end up like mine. F*&Kd Paintwork!
Mine did the same thing, but that's what happens when you spray 2 pack over acrylic.......
Trust me, Spend the time now to get it right mate... you will kick yourself later if you leave it!!
and just for the last time about my car.
#321
Posted 22 February 2010 - 04:35 PM
#322
_jabba_
Posted 22 February 2010 - 07:40 PM
Jabba:
Mine did the same thing, but that's what happens when you spray 2 pack over acrylic.......![]()
As soon as it started to craze up i stopped painting and started swearing, i had enough paint to do the car without stuffups now i have to buy more
It cant be too bad on your car, it looks very tidy!
#323
Posted 23 February 2010 - 05:18 PM
My Whole roof, the scuttle panel and a few spots on the body itself are compeltely crazed with crows feet and cracks!
It's because the paint below is still ( and always will!) move, making the hard 2 pack crack.
In the booth as mine "fried up" when the 2 pack hit it, the painter just wiped off the crap paint and hit it with more base!! ARGH!!!!
I'm no painter mate, so i cant give you any ideas, but I would make sure whatever caused the crazing is removed ( and a bit around to make sure!!) and then i would probably re-etch prime it, sand it back and give it another go.
Just my amateur opinion!!
Cheers!
#324
Posted 23 February 2010 - 06:04 PM
Once you get that crazing sorted out its gonna look awesome.
Can't wait. So hurry up!! But don't rush it.....
#325
_jabba_
Posted 27 February 2010 - 09:27 AM
