hawks uc sunbird
954 replies to this topic
#601 N/A-PWR
Posted 08 August 2014 - 07:11 PM
Ok UC,
thank's for that.
#602 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 08 August 2014 - 08:05 PM
thanks but I don't have a choice standard valves are to small and they have already had inserts previously
#603 _mick74lh_
Posted 09 August 2014 - 08:39 PM
Hey Steve, the 253 doesn't need bigger valves. In fact I believe that in most cases it should be more responsive with the smaller standard valves, as the baby V8 draws greater air speed through them.
And someone may like to verify this, but I believe you may run into problems if you go larger valves in a 253, where the top of the bores need to be notched to clear the valves. And doing this can also be detrimental to performance. Larger valves are okay on a 308 because they can clear the larger diameter bore.
By the way, I'm glad to hear you're keeping the car again.
#604 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 10 August 2014 - 04:26 PM
thanks might get my other heads looked over and see if standard valves in them will be ok.
have a pic below of engine fans, which one is best?
also painted up a few more bits
and I need to figure out the wiring at the plug in the bay as my wiring has been played with a lot in the past and I have never had working oil pressure of temp gauges. I have the max elerys manual but it doesn't have uc in it and is hard to follow. theres4 main plugs and I know what two do and some wires on the others also correct me if im wrong.
-pink ?
-orange?
-brown ?
-green ?
-blue ?
-yellow  =coil
-pink   ?
-red   ?
-purple  ?
-brown  ?
-yellow      =heater
-red
-white
-light green
-dark green      =wiper motor
-black
-yellow
I grouped them as the separate plugs cheers
#605 _mick74lh_
Posted 10 August 2014 - 05:44 PM
I'm only guessing so don't take my word for it but the top plug could be turn signals/hazards. The next one down could be horn? Or could also be wiper washer pump? I don't have a manual or wiring diagram with me here so just some ideas. If you can't verify it with a manual, you might be able to untape the bundles if wire running out of these and follow them to find out where they run to.
Were the senders for oil pressure and water temp connected to any wires before you pulled the 202 out?
#606 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 10 August 2014 - 06:33 PM
no it was all random relays and stuff for electronic dizzy and the thermo fans the plugs arnt horn or turn signals or lights I left those out as there all fine, I know there for sensors and also go to the starter. there are some that go to a relay but I don't have any idea what it does(sits near the heater fan but isn't connected to the heater wiring).
#607 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 10 August 2014 - 08:27 PM
Top plug is -
Red - Main 12v+ (batt) from starter
Purple - Starter wire from ign
Yellow - Coil
Blue - oil pressure
Green - temp sender
Pink - 12v ign for the varajet idle solenoid IIRC?
Brown - Alternator light
2nd plug I'm having one of those increasingly more common 'senior moments' and cant quite remember - I'll have a look in the morning if no one else knows...
#608 _mick74lh_
Posted 10 August 2014 - 08:42 PM
Righto well there ya go. Sorry if I was more than a little off with that Steve. Cheers for the correct info Garth.
#609 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 11 August 2014 - 06:22 PM
All i can say about the 253 and cam/big valves is from having had a sunbird that the Mrs drove around in,yella tera heads and only a mediocre cam
and it was dead,and the neighbor also had a very similar set up in his one toner,put it this way...i drove both cars and my shity bog stock 253 with a
stromy would out pull both..a half decent 202 with stock heads and bit of a cam and triple SU's probably would have left us bot for dead. :)
#610 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 11 August 2014 - 06:37 PM
thanks spoke to the engine builder today and he said hey only need the slightly bigger valves and that they should be fine, but now I face the choice of either going with these heads and the 4 barrel manifold and rochy or my other heads with the 2 barrel manifold and carb.
#611 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 11 August 2014 - 06:40 PM
#612 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 16 August 2014 - 02:57 PM
slowly getting it stripped. the areas circled in black are the main bits I want to give some attention.
also there is a pic of where I hope to attach the carbon canister to hide it
#613 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 18 August 2014 - 06:24 PM
stripped some of the bay back to metal then etched to seal it up. it will all go back to metal and etched again before paint.
#614 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 18 August 2014 - 06:47 PM
She will clean up ok,bloody brake fluid destroys stuff don't it..same color as mine...Flamenco? :)
#615 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 18 August 2014 - 07:01 PM
Actually,i been sort of thinkin,if you want those head gaskets,you can have them for the cost of freight,i don't need them,as long as you use them.
if you want em, PM me post code of  where you would like them to go,if not no probs.  :)
#616 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 18 August 2014 - 07:06 PM
cheers would appreciate that, but will wait till after I have the block checked over which is a while off
#617 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 21 August 2014 - 02:10 PM
yeah its flamenco here is a pic of my tag can anyone tell me if its right for flamenco and the cream sl/e trim?
got a bit more done just doing a bit at a time.
#618 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 21 August 2014 - 02:13 PM
if I remove the upper and lower lips on the firewall will it cause any problems and would I have to strip the interior do do it?
#619 Neils LX
Neils LX
  • 2,074 posts
  • Name:a
Posted 21 August 2014 - 06:46 PM
How come your going with 253 and not 308?
#620 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 21 August 2014 - 08:14 PM
not sure, at the time all I could find locally was a 253.
#621 _A9X UC_
_A9X UC_
Posted 22 August 2014 - 09:08 AM
Hey hawk i have and old UC manual with wiring diagrams in it
Let me know if you if you need them and i will scan them and email to ya
#622 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 22 August 2014 - 05:39 PM
that would be great thanks could you please email them to me at stevhawk@gmail.com thanks
#623 _mick74lh_
Posted 22 August 2014 - 07:48 PM
Nothing wrong with the 253. Mine goes great in the light Torry with a four barrel manifold and manual.
#624 N/A-PWR
Posted 23 August 2014 - 02:54 AM
Hey Steve,
they are both V8's,
so the choice is yours.
I know nothing about the lips on the Firewall sorry.
#625 308mate
308mate
  • 523 posts
  • Name:scott
  • Car:76 SS hatch (Royal Plum, Chevron Chamois interior), HQish Van (Orchid Metallic)
Posted 23 August 2014 - 07:22 AM
Wouldn't remove the lips without some serious additional reinforcing (could be easily done from the inside on the lower - don't know how you would do it on the upper) These lips add significant strength. I've found that straightening them up, grinding back the inconsistencies & filling them with a sandable sealer can bring them up quite nicely. Also that lower lip is handy for running wires....
Good luck
