* * * * * 2 votes
RoDoMo's LJ build thread
564 replies to this topic
#501 rodomo
Posted 12 June 2020 - 10:32 PM
I've scrapped all the deadener off the inside of the guards, tapped them up, and started fitting the left one.
I used a piece of timber quad to line up the rib and worked from there.
I had to "move" too many folds to make it work but it got there.
#502 rodomo
Posted 12 June 2020 - 11:00 PM
So after cracking the shits with this (I feel you pain Marty) I thought I'd pull the calipers apart to see if they needed pistons
Yep, no worries, compressed air, pop the pistons out? :spoton:
Not :angry:
This car has been idle for 16ish years?
The residual brake fluid had turned into crud, clag, varnish, poo...……….call it what you like but the pistons wouldn't be moved.
I even tried pushing them back in and soaking them in brake clean. :banghead:
So.…………...The RoDoMotive (I don't throw anything out) Caliper piston wedge-o-matic piston puller was developed.
First I tried a slide puller, shaped washer which was cocked in the piston bore.
This was working but it destroyed the thread on the end of the puller...………… :furious:
Proto-type II was successful!
It was a wedge, basically, that gripped the inside of the piston which enabled it to be pulled out.
The sleeve that fitted inside the piston was an inner wheel bearing that I had removed. You'll see the crack.
The top and bottom washers are Holden rear upper shocker mound washers ground to the task.
The washers spread the bearing and grip the inside of the piston.
The bolt is 3/8 UNF with ample pulling power.
The spacer is made from an old tail shaft.
Edited by rodomo, 12 June 2020 - 11:02 PM.
#503 rodomo
Posted 18 June 2020 - 09:50 PM
New pads
New XU-1 slotted rotors
New XU-1 caliper spacers
New brake hoses
Ned pedal pads
New indicator cancelling springs
Feels like Christmas! :spoton:
#504 LC69GTR
LC69GTR
  • 2,761 posts
Posted 19 June 2020 - 05:38 PM
:spoton: now turn around lol
#505 rodomo
Posted 19 June 2020 - 10:23 PM
Bitch
#506 rodomo
Posted 25 July 2020 - 10:03 PM
Final lap? The last bit of rust repair.
Next is the form work.
Then I'll call Readymix :spoton:
#507 sibhs
Posted 26 July 2020 - 09:42 PM
Hi Rob, Getting there mate I'll try that quad idea when I get back onto the front end of mine. Those Rares lower guard repairs are super frustrating.
Thanks again for the you-know what. I'm getting more enjoyment out of fixing the rear-end rather than the front.
#508 rodomo
Posted 05 August 2020 - 11:15 PM
Thanks Marty, I still haven't finished the guard pictured above...………….getting close now though.
3 piece repair cos I'm a tight arse. :spoton:
#509 rodomo
Posted 30 September 2020 - 10:54 PM
Front is almost tacked on. Every second spot weld at the moment as my argon is getting low and I'm not allowed to travel. :huh:
Calipers done. I cant find in 2 manuals what the tension for the 4 bolts that hold them together are?
One manual virtually said "you're a dickhead, we know more than you, you will never be enough qualified to touch this component" :ph34r:
Also the steering column has had the RoDoMo lower bearing mod. All switches (ignition and indicator) dismantled contacts cleaned, lubed and reassembled.
I got no keys with the car but while banging around a magnetic "key safe" fell out of somewhere...……..search back in this thread...……………..I can't remember? :fool:
It turns out that my first road car (EH) door key fitted the ignition lock with a bit of a mod. :spoton:
The previous owner had butchered the Ignition and boot locks as he never had keys either.
#510 S pack
Posted 01 October 2020 - 07:31 AM
Hi Rob, I did my caliper bolts to 70ft lb. That was the tension at which the bolts cracked when undoing them so that's what I did them back up to.
#511 rodomo
Posted 01 October 2020 - 11:47 PM
I checked other bolt tensions with the same thread and 35 Ft Lb was the maximum? Rotor to hub for example.
Starting friction is more than moving friction when tensioning bolts.
Edited by rodomo, 01 October 2020 - 11:50 PM.
#512 rodomo
Posted 05 October 2020 - 10:20 PM
Billet door check straps.
#513 rodomo
Posted 01 April 2021 - 11:56 PM
Boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin n boggin n rubbin is nearly done!
Might get some undercoat on it over easter?
#514 LX2DR
LX2DR
  • 1,763 posts
Posted 02 April 2021 - 04:21 PM
One more boggin and there won't be any tin to rust again, winning!
#515 rodomo
Posted 02 April 2021 - 10:13 PM
I'm hangin for paint.....................then it will fly together..............boggin not my trade :angry:
#516 rodomo
Posted 25 May 2021 - 09:05 PM
Pics
#517 Heath
Posted 26 May 2021 - 10:26 AM
Sweet!
#518 RallyRed
Posted 26 May 2021 - 08:14 PM
Better than I could ever do. Nice work.
#519 purrlx
purrlx
  • 1,332 posts
  • Name:Danny
  • Car:LX hatch
Posted 27 May 2021 - 07:43 AM
Looking good, lots of work to get to that stage.
#520 claysummers
Posted 27 May 2021 - 04:06 PM
Body work is a slog. Well done Rob.
early Holden nut
#521 rodomo
Posted 27 May 2021 - 09:26 PM
Thanks yoose...........................it's progessed more than this................these pics are some weeks old...............getting there.
#522 Cook
Cook
  • 1,535 posts
Posted 28 May 2021 - 11:00 AM
Good going Rob, and our political friends have given you another week to concentrate on it. Cheers Ron
#523 micklx
micklx
  • 1,785 posts
Posted 29 May 2021 - 07:28 PM
I've heard of a long term project but this is getting out of hand...... :stirpot:
#524 rodomo
Posted 29 May 2021 - 10:36 PM
Show off! Gidday Mick!
#525 rodomo
Posted 29 May 2021 - 10:38 PM
I'm up to the bit where I squirt a bit of primer and see all the repairs I missed  :banghead:
