* * * - - 4 votes
Tuxedo Black LH SLR 5000
1377 replies to this topic
#1151 hanra
Posted 10 July 2014 - 12:58 PM
Ahhhhhh bugger.. No wories mate. That might explain why its so hard to find any decent sets around? They have all been just to hard to remove safely...
#1152 arrimar
arrimar
  • 3,134 posts
Posted 10 July 2014 - 05:50 PM
A bottle opener flicks them off pretty well.
#1153 hanra
Posted 10 July 2014 - 07:12 PM
Does that work in reverse??? Hahahaha
#1154 _Bomber Watson_
Posted 10 July 2014 - 08:19 PM
Well if a bottle opener works to get them off, surely one of these would work to get them on.
Cheers. :P
#1155 arrimar
arrimar
  • 3,134 posts
Posted 11 July 2014 - 10:01 AM
Its best put in park with the brake on but you can try it in neutral and let us know how you go.
#1156 Statler
Posted 11 July 2014 - 12:46 PM
They actually come off quite easily IF you know what you are doing.
#1157 LS1LX
LS1LX
  • 1,931 posts
Posted 12 July 2014 - 03:39 AM
Would you care to share your knowledge? I've seen a lot of people damage them trying to pry them off
#1158 Statler
Posted 12 July 2014 - 09:31 AM
All i use is a 4" paint scraper. Preferably of good quality.
There is a ridge on the underside of the mould, that's where you want to be bumping it off from ..... NOT ON THE EDGE OF THE MOULDING.
Tap the handle of the scraper with the palm of your hand  just hard enough to release it, not hard enough so it bends up into a pretzel & lands on the neighbours roof. Work your way along the mould from back to front until it has seperated from the gutter.
When re-fitting, lock the corner (bend) part if first so that both 'planes' are secured at the top hook/lip, then bump on with the palm of your hand. Work along the piece & job done.
Make sure that the 'C' pillar gutter mould fits IN TO  the top gutter mould first.
#1159 Oysterhead
Oysterhead
  • 72 posts
  • Name:Marcus
  • Car:LX Torana
Posted 12 July 2014 - 10:03 AM
My panel beater uses a brick bolster.seen it done,works well.hooks perfectly behind bottom lip and doesnt crease the trim.
#1160 hanra
Posted 12 July 2014 - 10:50 AM
Can you please clarify this bit so I fully understand.
#1161 Statler
Posted 12 July 2014 - 12:50 PM
The long gutter mould fits over the short C-pillar piece.
#1162 hanra
Posted 12 July 2014 - 12:55 PM
Ahhh ok. So ensure the C pillar trim is in place first and that it fits into the trim before getting halfway through installing. Thanks mate.
#1163 Statler
Posted 12 July 2014 - 04:35 PM
No, you can slip it on before bumping on the last 6".
#1164 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 14 July 2014 - 01:23 PM
When you say drip mouuld? Do you mean the C pillar section that runs almost vertical behind the rear door?
I've got those sections, I'm chasing the ones that run up the A pillars and along the roof line.  When I got my car back off the charlatan that pulled it apart, these were in the list of parts were missing.
#1165 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 14 July 2014 - 01:31 PM
Hey mate. Get friendly with yout local Supercheap Auto store or Mackay Rubber stockist. Purchase as many hoses as you can carry and spend some time with trial and error... Make sure you keep all your receipts so you can return all the hoses that dont fit! Thas what I had to do....
I might have it written down somewhere? Not sure.... the Supercheap Auto receipts fade to nothing after a few months... And cant be read.
Looks like Mackay part number CH1614 is what I'm after for the front hose. Just have to trim it to fit but the curved bit looks like it should fit well. The rear heater hose can be substituted with CH1326. Once I fit them to the car I'll confirm there suitability just in case anyone else has to replace these.
Deadly looking arrows there to!
Gotta be careful they don't pierce those hoses  :D
#1166 arrimar
arrimar
  • 3,134 posts
Posted 14 July 2014 - 03:57 PM
Mackay were making the short hose again, I bought one about 12-18 months ago. CH942 ? Runs from thermostat housing to manifold (not to heater).
#1167 hanra
Posted 14 July 2014 - 04:14 PM
Yep your right!!!!
http://www.onlineaut...Statesman-CH942
#1168 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 14 July 2014 - 07:32 PM
Hopefully Bursons will swap the CH1614 for a CH942.  When I went to the Mackay site they didn't list this hose under Torana applications and under HQ they don't even list any heater hoses ??? but under HJ they have it listed there.
mugginz
#1169 hanra
Posted 14 July 2014 - 07:36 PM
Yep. The gutter trim that everyone seems to be chasing.... One would think RSP would re-make these? There are trims for LJ's re-made.
#1170 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 15 July 2014 - 05:18 PM
I get the feeling the LC/LJ series gets a little more love from the reproduction guys at the moment.
#1171 hanra
Posted 16 July 2014 - 12:52 PM
Yeah I think I have to agree with you on that one.
#1172 _sjp67m_
_sjp67m_
Posted 08 May 2015 - 12:08 PM
Just read through this whole thread, what amazing work you have done
It is a shame that without flares and a chev it doesn't get the attention that it should
#1173 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 08 May 2015 - 07:23 PM
Use Brads thread as a great source for my build.
Edited by mika03au, 08 May 2015 - 07:31 PM.
#1174 hanra
Posted 09 May 2015 - 05:01 PM
Hahahahahaha. Don't forget the drop tank!
#1175 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 09 May 2015 - 06:17 PM
Geez first the flare bit got me, then you mentioned Chevy......please don't do that again.  This car probably would get more looks at a show than the equivelant flared/cheved up version.  A credit to Brad for going stock....
