Spent the day down at work on the car but not all of it was working on the car. Got1UR1 and Green Taxi came over to say g'day, was good to catch up with them. I also had a 2 other visitors who are into Torana's. Spent a bit of time shooting the breeze talking stuff which was nice. Green Taxi also helped me a bit with the drivers window glass which was nice.
So today I got 3 of the 4 door glass in, I only have the front passenger to fit now. It all went in ok, just have to follow a methodical order. Like I found out that fitting the window belts in the rear door after the glass has gone in isn't going to happen. So out comes the window, fit the 2 belts, put the glass in and then slide the divider down. Works easy enough if you follow steps.
In the 3rd photo I have put 2 arrows on the picture. The smaller arrow shows where I relocated the door handle to when I realized it was going to clash with the roll cage.
What I didn't think about was the window winding mechanism. As you can see below the larger arrow is the arms for the winder and they travel right across where the wire rod that connects the door handle and door catch goes. I only realized it when the window would not travel up very well and come out of the bailey channel. The wire rod wasn't a problem when the window was down but caught on the arms as the window was wound up.
When I took the door handle off and I adjusted the window winder the window now travels up and down smoothly.
Now I have to relocate the door handle to another spot.
