They're not usually very good in that respect. Originals had a spring washerYes if the cotter pin thread is hardened properly
IPRA 4 Door LX
#951
Posted 04 December 2014 - 07:58 PM
#952
Posted 05 December 2014 - 06:02 PM
How cool does that look.
#953
Posted 06 December 2014 - 04:31 PM
This is going to get interesting.
The passenger side looks like it will be a tad easier!!
#954
_prule_
Posted 10 December 2014 - 08:59 AM
Hi mate,
Make sure you have enough room between the upper control arm and the extractors.
With a Torana running A050 tyres. you'll need 4.5 - 5.0 degrees of negative camber which moves the upper control arm a lot closer to the pipes. (Up to 6 deg with some tyres)
I can see from the pics that you have it currently set with hardly any camber.
Passenger side looks OK, hard to tell from the pics, but the driver's side might be an issue.
Probably pay to dummy it up with a lot of camber.
Paul
#955
_LS1 Hatch_
Posted 10 December 2014 - 09:42 AM
If you need anyone to test it out, it would look pretty nice on my Edelbrock intake I supposeThrottle Body arrived today. 95mm bore.
#956
Posted 10 December 2014 - 10:47 PM
Hi mate,
Paul
Cheers Paul, will certainly look at that before going much further. Appreciate the tip.
How are you going? Your car going well? I watch the YouTube stuff you post off and on, keeps me motivated.
Haha Jeff, It would look super tough on your manifold.If you need anyone to test it out, it would look pretty nice on my Edelbrock intake I suppose
#957
_prule_
Posted 11 December 2014 - 08:34 AM
Hi Craig,
Going well. Just finished the worlds longest engine rebuild. Converted the Group A 304 to a 355 stroker. Will be taking it for a test run this Saturday.
Have been following your car build with interest. Looks like its getting close. Keep up the good work.
Paul
#958
Posted 17 January 2015 - 12:36 PM
First 2 are tacked to flange, now for the second 2.
#959
Posted 17 January 2015 - 07:35 PM
Hey Paul,Hi mate,
Paul
Thanks for the tip. Will keep the rear of the upper arm as free as I can when snaking the pipes past there.
I see Peter is bringing his red Torana out of retirement, great news.
I really need to push this thing along and get out there myself. Been long enough, 36 bloody pages on this thread!!
#960
_Viper_
Posted 17 January 2015 - 11:51 PM
Not been on here for a little while, you have been busy Craig ![]()
Doing well with the pipes!
#961
Posted 19 January 2015 - 06:20 PM
Looks good Craig, watch the starter motor, you may need to make a heat shield or wrap the pipes in that area as I have had issues with mine getting hot due to heat soak. Have you worked out what you are going to do with the muffler yet?
BTW who did you end up getting the Jerico through again, I want to upgrade mine from the 4 to 5 speed...
#962
Posted 19 January 2015 - 08:42 PM
1 more cut and it should be ready to fully tack.
Bit hard to see in the photos now.
#963
Posted 19 January 2015 - 11:29 PM
Hey Sam, hope you had a good Christmas.
Yeah the heat from the pipes will be a massive concern, I am going to get them coated and wrap what I can to minimise the heat transfer.
The Jerico came direct from Jerico in North Carolina. I emailed and spoke to Scott, but that was a few years back, LOL.
The number I used to ring the was 0011 1 704 782 4343
I can email you the work order I filled out for them to manufacture my gearbox if you like??
I can also share the invoice if you need a point of reference for price.
#964
_LS1 Hatch_
Posted 20 January 2015 - 01:41 AM
#965
Posted 20 January 2015 - 02:00 AM
Aeroflow do a neat looking heat shield for LS engine starters too...
$_57.JPG 52.37K
6 downloads
http://www.ebay.com/...657f69a&vxp=mtr
...but I'm not sure if it'd fit your Tilton starter?
I'm sure there would be many other companies doing these too.
#966
Posted 20 January 2015 - 08:03 AM
HPC coating will reduce the heat transfer as well.
Dearer than tape of course
#967
Posted 20 January 2015 - 09:35 PM
Nice work big fella! Will have to check that out...
Re the gearbox, cheers Craug I'll get in touch with them - still recovering from getting the new helmet/hans/seat/harness I needed to upgrade for this year, so it might not be for a little while...lol
#968
_The Baron_
Posted 22 January 2015 - 01:29 PM
One word (sort of).......ARGHHHHHHHHHHHHHH!
#969
Posted 23 January 2015 - 05:26 PM
#970
_LS1 Taxi_
Posted 23 January 2015 - 05:59 PM
Your starter will get hotter from heat soak through the block than it will from a 10mm air gap between the starter and your pipes.
I wouldn't bother with wrapping...need to show off them sexy welds ☺️
#971
Posted 23 January 2015 - 07:02 PM
Bit easier this one.
#972
Posted 23 January 2015 - 07:03 PM
Air isn't a good conductor of heat.
Yeah but a header pipe gets ten times hotter than the block?
I meant to ask earlier eyepeeler, where did you get the extractor kit from? And would you say it had everything you needed or will you have to buy extra bends?
Also, what are your plans for getting that driver's side header in and out, will you just have to remove the two steering knuckles or will the column need to be withdrawn back into the cabin?
#973
Posted 23 January 2015 - 09:10 PM
Hi BigFella, I just went to my local exhaust shop and asked if he could sell me some mandrel bends and some pipe. I bought 180 degree and 90 degree bends.
To get the header out I will have to do as you say, remove steering knuckle and column then drop the sub frame out of the car with engine on it.
I don't think there will be room enough to get them out without dropping the sub frame out.
Craig
#974
Posted 23 January 2015 - 10:37 PM
Thanks Craig,
That's a PITA but I hopefully it will only need to be done once!
So where did you get the flange plates that bolt to the heads, I'm assuming they must be custom made for 2" primaries?
#975
Posted 23 January 2015 - 10:53 PM
Thanks Craig,
I got that from the exhaust guy as well. They had to laser cut them for 2" pipes.
If you had the dimensions you could approach a laser cutting business directly? That's what I am going to do if I need more.
