IPRA 4 Door LX
#976
_LS1 Hatch_
Posted 24 January 2015 - 02:42 AM
#977
Posted 30 January 2015 - 06:52 PM
#978
Posted 30 January 2015 - 07:14 PM
Nice work, but i recon your going to have some pretty serious racing rattles there ![]()
#979
Posted 30 January 2015 - 07:49 PM
Or is that Rubbings Racing...
I'm confused.......
Not sure how else I could have done it? I know that my feet will get hot!! Might have to do a bit of shielding.
#980
Posted 30 January 2015 - 07:51 PM
Na mate your right how you did it is pretty well it i recon.
But she is gonna hit, such is life. Possibly tappa tappa tappa the floorpan a bit more.
#981
Posted 30 January 2015 - 08:32 PM
thats some crazy pipe paths there. well done on the patients !!
i would have cracked it long ago,
#982
Posted 31 January 2015 - 01:37 PM
#983
Posted 31 January 2015 - 01:43 PM
Nice work, it was always going to be a pain getting the pipes through.... I ended up with tri-y as well, but with very short primary pipes, yours look much better.
By the way, I cant make out from the pic, but you can now solid mount the subframe to the body shell - regs update here:
http://www.ipraforum...php?f=2&t=10298
check point 9.3 -
Makes a big difference to the stiffness of the body - also might help because you have your pipes running so close to that outrigger bush, it would probably melt!
#984
_LS1 Hatch_
Posted 31 January 2015 - 01:54 PM
(Pipes are coming along..I know what a pain it was when I built mine as well!)
#985
Posted 31 January 2015 - 04:22 PM
#986
_LS1 Hatch_
Posted 31 January 2015 - 04:25 PM
#987
Posted 31 January 2015 - 04:39 PM
#988
Posted 31 January 2015 - 07:41 PM
check point 9.3 -
Cheers for that Sam, will replace the bush with a solid bush. Any other things you spot??
I figure I better get the tail shaft in before fabrication of the X merge in the pipes, don't need it to clash!
#989
Posted 31 January 2015 - 09:35 PM
Don't look now, but your nut to bolt ratio is way off...
I guess you could day I haven't lost my nuts.....
For some odd reason that comment reminded me of the AC/DC song Big Balls... bahahaha, funny song that one.
#990
_LS1 Hatch_
Posted 01 February 2015 - 01:21 AM
Oh, and while you are going along, don't forget to try plug wires on each plug to make sure the pipes are not going to be in the way, same for getting a spark plug socket on each one as well..don't want to find out after the fact it's super hard to get to them because of the way the pipe happened to route...
#991
Posted 01 February 2015 - 05:20 AM
I was gonna mention earlier that you'd better remember the bungs for the O2 sensors as well... but I figured you probably had it under control.
Which got me thinking, I wonder if the ECU treats each bank as a separate entity AF ratio-wise, or whether it averages both O2 sensors and makes adjustments to the AF ratio for the motor as a whole?
And what about the Commodore LS engines that have four O2 sensors, two in each bank, one before the catalytic converter and one after, how does that work?
VE 6.0 Left & Right Catalytic Convertors 65mm Outlet_sml.jpg 84.49K
7 downloads
#992
Posted 01 February 2015 - 11:16 AM
Thanks Andrew, that just made me think! Will ask the bloke doing the motec engine management what he needs.
There are a crap load of sensors on the engine, to be honest I didn't think of what was needed on an exhaust system.
Cheers mate,
#993
_LS1 Hatch_
Posted 01 February 2015 - 11:33 AM
#994
Posted 01 February 2015 - 04:14 PM
I was thinking about the quad sensor setup and I wonder if they're required for the newer ethanol "Flex-Fuel" engines ( L77 / L99 ), apparently they're supposed to have "extra sensors in the engine to enable them to be able to detect how much ethanol is in the petrol mix"?
Either way it's irrelevant here, I'm sure the second set of O2 sensors will only serve some emissions requirement and aren't required as Jeff said.
#995
_LS1 Hatch_
Posted 02 February 2015 - 02:23 AM
#996
Posted 02 February 2015 - 08:52 PM
Geat work i could never see myself having the patience to fab those headers coming along nicely
#997
Posted 03 February 2015 - 10:43 PM
For those other comments the rear o2 sensors, most don't control fuel from rear o2 but on some cars they do control fuel trim of the engine.
That ethanol sensor is a standard GM part, a number of aftermarket computers are comparable to use it so you can tune to run ethanol and unleaded but does require about double the amount of dyno time to tune for both fuels.
#998
Posted 08 February 2015 - 09:42 PM
#999
Posted 08 February 2015 - 10:04 PM
Rear O2 sensors came in around Cat3 spec
You definitely won't need them on a racecar... don't even have to run cats do you ?
#1000
Posted 08 February 2015 - 10:38 PM
How good is that, great news. Bad part is that you'll be out there before me, LOL.Hey craig it is official they are have a sub class in IP to allow targa cars to run, so ther is a few of us looking at having a run.
When you head out for an IP meeting, let me know.
