Got the accelerator pedal mocked up so I can get an alloy one made.
Made a mock up jig for the pulley that replaces to power steering pump pulley.
Again, going to make it out of alloy.
I am also in the process of finishing all the oil lines.
Posted 12 December 2015 - 08:06 PM
Posted 13 December 2015 - 01:32 AM
Instead of making that setup from scratch, you can just move around the idler pulley and reroute the belt a bit different from memory and not need the extra stuff..
Posted 13 December 2015 - 01:36 AM
Posted 13 December 2015 - 01:39 AM
Posted 13 December 2015 - 01:52 AM
Why do they insist on running the water pump off the back of the belt anyway? It's such a PITA...
Why has nobody designed an LS water pump that spins in the opposite direction so you could bolt up a standard (ribbed) pulley and run a short belt around the crank. alternator and WP in the traditional triangular pattern?
Posted 13 December 2015 - 02:54 AM
After some more research I've found that "6MC" LS2 should be one of those very early "Franken-engines" that, while technically a Gen IV motor, still had the 24x Crank Reluctor and 1x Cam Trigger etc. from the Gen III?
Correct, the LS2 has the 24 tooth reluctor and cam trigger from the LS1 but used a drive by wire throttle body, different knock sensors mounted on the side of the block and a E40 ECM.
You can run a LS1 ECM and cable throttle body on the LS2 if you fit the LS1 knock sensors and a cable throttle body with LS1 TPS and IAC.
Edited by ls2lxhatch, 13 December 2015 - 02:55 AM.
Posted 13 December 2015 - 09:56 AM
Just found these really quick, sort of gives you the idea maybe ?http://www.ictbillet...ete-551550.htmlOr pic I had just found online really quickly..
Posted 13 December 2015 - 10:40 AM
Posted 13 December 2015 - 11:16 AM
Eyepeeler did you know that you can buy that bracket your trying to make from CRS ..not sure on price thou
Posted 13 December 2015 - 12:52 PM
Makes sense ! And be cool to see how the pedal and bracket do turn out.
Posted 28 January 2016 - 12:24 AM
image.jpg 86.71K
2 downloads
image.jpg 127.54K
1 downloads
image.jpg 120.3K
2 downloads
image.jpg 101.27K
2 downloads
Posted 28 January 2016 - 12:30 AM
image.jpg 93.5K
0 downloads
image.jpg 109.65K
0 downloads
image.jpg 90.16K
1 downloads
Posted 28 January 2016 - 10:54 AM
Bit of meat there... should be able to really stand on it ![]()
Posted 28 January 2016 - 11:51 AM
Well, he does have those extra 2 doors to get moving.. ![]()
Posted 28 January 2016 - 11:56 AM
This is what I came up with. Turned out really well and very happy with it.
Just noticed your fuel line...so will you just have the feed on one end and return come out the other end?
When I had talked to Aeromotive about setting up my fuel system, they said the "better" way to do it (and how I did) is to Y off the feed and have the feed going into each fuel rail and return out of each end....supposed to be more balanced fuel delivery that way I think. For just stock standard type stuff I know a lot of people just do it with feed in, loop around and out the other end though, but I figured I would go the route they talked about.
Posted 28 January 2016 - 11:23 PM
Posted 28 January 2016 - 11:30 PM
image.jpg 109.17K
3 downloads
image.jpg 105.99K
1 downloads
image.jpg 113.44K
1 downloads
image.jpg 114.98K
0 downloads
image.jpg 105.2K
0 downloads
image.jpg 122.1K
0 downloads
Posted 29 January 2016 - 07:27 PM
epic stuff man on this build.
well done.
G
would you be able to run this car in TCM category
Edited by Agent 34, 29 January 2016 - 07:28 PM.
Posted 29 January 2016 - 10:02 PM
coming up very well I envy your efforts but the reservoirs look like a b1tch to fill lol
Posted 29 January 2016 - 11:16 PM
Posted 30 January 2016 - 09:28 PM
love this build, clever bloke!
Posted 31 January 2016 - 11:00 AM
well done.
G
Wow what a read. I've been in and out of this thread for a while. But I just binge read from the middle of 2014 I think it was to present day.
I've got to say you are a bloody champion doing all this work to such a high standard. Nearly made me go out to the shed and look at my car, but a beer was closer and easier to finish so I did that instead
Cheers Greg, appreciate it mate.love this build, clever bloke!
Posted 05 February 2016 - 11:46 PM
Posted 20 March 2016 - 01:14 PM
Its been a while since i updated this thread.
I have working on it, just not posting. Tapatalk not working makes it harder.
I decided to re-make the panel which the keypad is mounted to , wasn't happy with the design after I moved it from the trans tunnel.
Made it out of alloy.
01.JPG 197.88K
0 downloads
02.JPG 113.55K
0 downloads
03.JPG 131.8K
0 downloads
04.JPG 142.97K
0 downloads
Pretty happy with the result. It will be easy to reach and very functional.
05.JPG 85.21K
0 downloads
06.JPG 125.88K
0 downloads
Edited by eyepeeler, 20 March 2016 - 01:15 PM.
