Tacked 2 plates together to make the flange and the lid.
Made up a baffle for the oil returning to the bottom of the tank.
Posted 17 September 2015 - 08:05 PM
Posted 17 September 2015 - 08:40 PM
you pinched that last bit from frasers mechano set didn't you ?
Posted 18 September 2015 - 12:32 PM
Does the oil pickup from the tank have a mesh filter over it?
Just a little concerned one of the nuts on the baffle could come loose and make its way into the oil system. You could hammer over the end of the bolts over to prevent the nut from escaping if you have already done so.
Edited by ls2lxhatch, 18 September 2015 - 12:32 PM.
Posted 18 September 2015 - 02:22 PM
Liked minded Andy, was going to put a weld tack on them.
I have Loctite them on, but though the same last night driving home, just weld it was the answer.
Posted 20 September 2015 - 10:40 AM
Thanks for the shed tour yesterday Craig. I'm sure you had plenty on your plate, so to give me some of your time was great mate.
Thanks also to Dave Mac for escorting me around the big smoke. I got to see some awesome cars and a shed any hairdresser would be proud to own. ![]()
Posted 20 September 2015 - 04:38 PM
anytime dude
Posted 13 November 2015 - 04:19 PM
Been a while................................need some help?
Posted 13 November 2015 - 04:30 PM
Other priorities I'm guessing... (too much time spent working on inferior engines!)
Edited by Bigfella237, 13 November 2015 - 04:33 PM.
Posted 13 November 2015 - 05:51 PM
LOL, watch it...........you will start up Bomber Watson!
BTW the 186 was the best red.
Posted 14 November 2015 - 12:04 PM
I think Craig has gone about this all wrong anyway. He should rip the V8 back out of the racer and transverse mount the 202 in there. Much better weight distribution and he could do the timing on the run through a hole in the firewall.
Posted 14 November 2015 - 12:52 PM
YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES
Posted 14 November 2015 - 07:05 PM
Hey Darky, Since getting back from Adelaide I have been pushing to get the shed built.Been a while................................need some help?
Posted 14 November 2015 - 07:23 PM
Because six is the godly number.
Posted 14 November 2015 - 09:24 PM
Ah no... six is the complete opposite of Godly
Six is two thirds of the correct number
Posted 14 November 2015 - 09:38 PM
Posted 14 November 2015 - 09:44 PM
Just goes to show how smart VEEEAAATTTTEEEEEE champions are.
Posted 14 November 2015 - 09:53 PM
DOH!
Posted 14 November 2015 - 09:59 PM
Um Dah look me at me big veeate man hav drink my vb in my flanny and rip a skid. Dat six no beat me he cheat. Six never beat veeate in fare race with veate having 15 sec headstart.
Posted 14 November 2015 - 10:10 PM
Posted 19 November 2015 - 09:28 AM
Classic V8 envy, you need help Bomber, get help quick before your stuck with little sixes forever.
Posted 19 November 2015 - 07:22 PM
I will race ya when both of our cars are going again ![]()
Posted 20 November 2015 - 03:36 PM
Engine: LS2 6 litre
Built by SRE and said HP is 550.
Any suggestions welcomed..
G'day Craig,
I was doing some more research on LS engine numbers and I remembered this thread, so I found one of your photos that looks like the first part of your engine number is 6MB05305xxxx
If my research is correct then that's not actually an LS2, it's one of the very first L76 6.0L engines built by Holden (on the 1st of November 2005) and this one left the factory in an early 2006 VZ Series II Commodore with an auto trans.
Not that there's anything wrong with that, the L76 is the same block casting as an LS2 except they have extra oil passages drilled for the DOD/AFM, which I assume SRE would have removed and blocked off?
They also had better cylinder heads than the LS2, yours has the "5364" cast # L92 rectangular port heads.
Do you have any specifics about what SRE threw in there?
Posted 02 December 2015 - 11:19 PM
~ I bought the engine way back a few years ago, came with the standard water pump and an ATI Super Damper fitted.
Turns out the Super Damper is the wrong offset for the pump, serpentine belt is not in the right position!!
Frustration goes a small way to describing it.
Okay back over here then... yep there's three different depth balancers on LS engines...
LS Balancers.jpg 46.33K
4 downloads
...don't quote me on this but I *think* Commodores get the middle one from the Camaro?
But looking at yours I'm guessing it's a completely custom offset because of the scavenge pump drive? Which no doubt means the alternator won't line up either so there's gonna be a custom bracket needed there too?
Maybe a Moroso electric water pump might be an easier option? Plus it gets rid of that damn ugly LS water pump!
Moroso LS engine Electric Water Pump 2.JPG 44.28K
4 downloads
EDIT:
Either that or try and buy a water pump off a "truck" motor as they must have a longer snout (obviously you would still buy a new one as a spare part, not a dirty old truck one)?
EDIT 2:
Actually, you could just have some alloy spacers machined up to space your current pump out away from the block the required amount, similar to how the Moroso pumps fit...
mor2.jpg 61.9K
6 downloads
...but it's all starting to snowball because then you're up for custom brackets for the idlers/tensioner pulleys as well.
Edited by Bigfella237, 02 December 2015 - 11:31 PM.
Posted 02 December 2015 - 11:47 PM
Posted 03 December 2015 - 12:51 PM
You can buy water pump spacers so you can run a Camaro style water pump with a truck harmonic balancer.
There are lots of different suppliers.
http://www.ebay.com/...g-/221225080146
http://www.dirtyding...p?cPath=379_384
I was considering running a Truck harmonic balancer to make more room for an A/C compressor.
