206 replies to this topic
#76 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 15 February 2012 - 11:31 AM
Thanks for posting. Simliar set up to mine as well. I also agree that the strokers are the way top go to achieve bigger numbers but I am a staunch 308 fan and wanted old skool 308 power as not too many go down that path anymore simply because of the relatively cheap prices for the stoker kits nowadays.
#77 _AD_75_
_AD_75_
Posted 16 February 2012 - 06:57 PM
Gerry,
Just some reading material for ya on standard stroke 308 combo's i found over at Aussie V8, pretty interesting read.
http://www.aussiev8....-challenge.html
#78 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 17 February 2012 - 11:44 AM
Ta, good read indeed. Fair bit more HP than mine though, 400 out of a non stroked 308 is pretty full on. Some big cam choices in there.
#79 boblhslr
boblhslr
  • 199 posts
Posted 26 February 2012 - 08:24 AM
Hi guys just thought I would add my combo. Don't have any hp figures but its best at willowbank is 12.20@110mph.
Stock stroke 308. standard bottom end with flat top pistons .060 over. Heads are red hq hreads, ported to roughly l34 spec 1.94 intake valves and 1.6 exhaust. Crow cams solid. Stripmaster manifold. 2" hvh carby spacer. 750hp street carby down jetted. Roller rockers. comp was 11:1 static.
Before the 750hp street carby I had a 650dp holley with a best of 12.40@108mph bolted the 750 on and dropped 0.2 and picked up 2mph. Had to drop 3 jet sizes all the way around but thats it.
Edited by boblhslr, 26 February 2012 - 08:25 AM.
#80 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 26 February 2012 - 07:44 PM
Good times indeed. I managed to snap an axle in mine yesterday...Time for some billets I think..More money :-(
#81 _LH SLR 3300_
_LH SLR 3300_
Posted 27 February 2012 - 04:55 PM
A combo i know of in an LX hatch.
VN 304 stock crank & rods
Ported stock heads
Camtech solid flat tappet cam, roller rockers
Harrop single plane manifold 750HP Holley carb
Re-graphed Bosch HEI distributor
Stock 5/16" fuel line, OzRace mechanical fuel pump.
Off the shelf Pacemaker headers, dual 2 1/2" exhaust
Built by Ned Sassine from Hercules Competition Engines, it made around 480+bhp on pump fuel (98) & running a Top Loader trans, 3.7 gears & full exhaust this car recently ran an 11.2@124mph with a slipping clutch. A forum member disputed this claim not long ago in another thread but i know a few other members who seen this car in action on the day & also know it was driven to the track & the only changes made were to fit slick tyres before bolting the radials back on to drive it home. I can post pics for those interested as the owner is a friend of mine.
#82 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 27 February 2012 - 08:53 PM
Wow impressive. Must of had some good compression to get those sorts of figures? Any cam specs?
#83 AbsynthHatch
AbsynthHatch
  • 765 posts
  • Name:Mark
Posted 27 February 2012 - 09:43 PM
boblhslr very similar combo and times to my Hatch, was interested if you knew the cam specs at all?
#84 boblhslr
boblhslr
  • 199 posts
Posted 28 February 2012 - 10:46 PM
Hi AbsynthHatch, The cam is a crow cam # 5803. Duration 282, duration @ .050 in-246 ex-246, L/C 108 and valve lift is .540 in both.
#85 ozyozyozy
ozyozyozy
  • 953 posts
Posted 03 March 2012 - 01:29 PM
i havent added to this for a while. been busy with the car.
i`ve rebuilt my engine, just a freshen up, new rings and bearings, i had hurt the mains, but caught it in time.
dont know if a mentioned sprint event i did, i actually got oil surge, 1st time this has happened with the sump i was using(high energy pro circuit),
well after chatting to some people, and some sponsor help, i have fitted a dry sump setup to my engine.
oil pressure is the best it has EVER been.
just finished running in the engine, and have been sorting some teething issues.
if all goes well i plan on hitting the track ( for the perth people, its the twilight sprint at kwinana)
so fingers crossed, been almost 6 months since last event, im hangingfor this.
#86 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 03 March 2012 - 07:02 PM
Make sure you post up some figures if you get ti dynoed...Be good to keep this thread rolling along!
#87 _fryzem_
_fryzem_
Posted 06 March 2012 - 07:43 PM
we just put togeather an engine for my brothers gemini, its stock stroke 308, bushed rods with floating hypertech pistons, hq big valve heads, mild port job, 286 hydraulic cam and 10.5 comp, with the dual plane manifold and a 950hp methanol holley it made 187kw at the wheels at 5500 and climbing but popped a head gasket, round 2 is about to begin , we have put a single plane manifold now and locked the dizzy up as its a skid car but hoping for around the 210kw mark at 7000. will let you know.
#88 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 07 March 2012 - 11:31 AM
Good starting point. My only comment though is with the 286 crane you are lucky to develop power after 6k so 7k would not happen. I swaped from the 286 to the 304 Crane (next one up) and the power started rolling over at 5600rpm. The cars certainly revs a lot harder than 5600rpm on the road. Mind you that is what the Performer dual plane manifolds are rated to so perhaps that is why power stopped climbing. Mine made 210 RWKW @ 5600.
Be interesting to see what you end up with. Post up your results. Keen to see.
#89 _ljxu1torana_
_ljxu1torana_
Posted 07 March 2012 - 11:51 PM
holden 308 loves fuel,put a 800 holley on it.my friend had a 800 holley spreadbore double pumper.cc300 crane cam.top loader nine inch 3.5 diff gears,ran 11.6 @119mph in a holden hg ute 25 years ago.back in those days most people used manuals.i am a big belever in using manuals as it teaches people how to race a car at the drags.back 25 years ago these were quick times.thanks jason.
#90 warrenm
Posted 08 March 2012 - 07:25 AM
Go the STICK SHIFT.
#91 _ljxu1torana_
_ljxu1torana_
Posted 08 March 2012 - 09:21 PM
and i forgot to say that he drove the car from his home to the drag strip and back 8 hours in total,but super fuel was about 50 cents a litre back then.a few years later with the same motor he put a bigger cam in a cc300a in his hj 1 tonner.but never raced the 1 tonner.thanks jason
#92 _Bear74_
_Bear74_
Posted 15 March 2012 - 05:22 PM
Hi everyone, my name is Graham. Just new to this forum so introducing myself and my toy. I have a HZ well back ute 355 , turbo 400 and 9", haven't had it on th dyno yet but should do in the next month or so. This ute has been an ongoing project for the last 18 years. Just had the stroker built it has all the good gear 304 block, crane roller cam, -9 alloy heads, Harrop single plane intake, 750 HP Holly, MSD ignition. It is a lot of fun to drive. I like reading about other peoples projects and am keen to get to now some of you .
#93 _torana355_
_torana355_
Posted 15 July 2012 - 10:55 PM
vp 304 block
come 355 stroker crank
5.7 come rods
30 tho over mahle forged pistons
dual valve springs
2.02 & 1.6" valves
vn heads
cam is a custom billet from usa 242@.050
high rise dual plane torque power manifold
750 hp double pumper
6aL ignition
yella terra roller rockers
11.0.1 comp
made 453hp at 5500rpm and 446.9 ft-lb at 4400rpm
#94 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 16 July 2012 - 12:21 PM
We have our annual dyno day in a couple of weeks so it will be interesting to compare notes on another dyno. We have some very staunch engine combos in our club so will be an interesting day indeed.
#95 _fryzem_
_fryzem_
Posted 16 July 2012 - 07:22 PM
gday all the little gemini i posted about a couple months ago ended up making 218.6kw at 6400 rpm, i think the methanol helped it maintain the power up that high, and the high comp. very impressed for a budget basic build.
#96 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 17 July 2012 - 12:23 PM
Nice effort. Surprsising result using the 286 camshaft. Big power jump from your last combo too.
#97 _LHSL308_
_LHSL308_
Posted 10 November 2012 - 03:01 AM
Been getting my 308 rebuilt for the last 6 months and is actually due to go on an engine dyno tomorrow.
Standard 308 crank
308 Block to 30 thou
VN Rods
Auscar forged flat tops
HQ L34 heads
Dual valve springs
Crane CC280-2 Solid cam 244 @ .050
Proflow high volume fuel pump
Regraphed Bosch Dizzy
Yella Terra roller rockers
Edelbrock performer manifold
Holley Ultra HP 650 cfm carby with Mech secondaries-Just bought this today actually http://www.ebay.com....=item25689f52f2
Pacemaker extracters Try y's
Expecting around 370 FWHP but we will see.
Car is running a 4 speed Saginaw gearbox with 3.55 in the 9inch. Many people say the Sag wont stand up down the track and I would like to change it to a muncie but it will do for now.
Edited by Gonedeaf, 10 November 2012 - 03:03 AM.
#98 _gmlj6_
_gmlj6_
Posted 11 November 2012 - 12:42 PM
a friend of mine has a nice and simple combo.
come 355 crank
eagle I beam rods with arp 2000s
probe forged pistons
10.5:1 comp pump fuel
crane h286 (230/230)
stock VN heads
YT bolt on rockers
Torque Power Single plane manifold
750 vac sec
curved bosch hei msd 6al
t5 and a borg warner with 3.9s in a vk commodore
made 240rwkw or 320rwhp ran 12.1 114
https://www.youtube....e&v=TVp1tNVqkOw
#99 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 12 November 2012 - 11:46 AM
Any power figures Wayno, keen to see your results.
After seeing my two mates run their cars at the drags yesterday and post good quarter times, I kind of wish i went for a small solid cam now like the CC280. Maybe next time :-)
#100 _LHSL308_
_LHSL308_
Posted 13 November 2012 - 09:40 PM
Standard 308 crank
VN Rods
HQ L34 heads
Dual valve springs
Actually the dyno only ran today due to some teething problems fitting the engine on the dyno and the guy being busy. It ran 398HP @ 6300RPM and he was expecting around 370HP so all in all pretty happy. I managed to go there this arvo before he had to pull it off the dyno and actually here it run since March this year and I must say it sounds even more angry than it used to. Had a CCH314 hydraulic cam before but with a shot lifter and a spun crank bearing. Still ran pretty well spinning in 2nd gear back then but definately sounds better now. I cant wait to have it back into the car and run it down the 1/4.
Heres the link to it running today on the dyno, not a HP run though just to show me it running.
