Moving an LC/LJ diff forwards
#26
_Macka_
Posted 01 November 2011 - 09:13 PM
#27
Posted 01 November 2011 - 09:52 PM
Pinion angle is the relationship of the diff pinion and the rear of the gearbox. The diff pinion should be parallell to the output shaft of the gearbox (and ergo paralel to the centerline of the crankshaft of the engine) but not in a strait line.
My understanding is they should be parallel under acelleration, as the diff twists upwards under load. Anyway, within 2 degrees is apparently OK.
#28
Posted 01 November 2011 - 10:56 PM
Im getting to used to working on industrial gear
If you have a rubber mounted diff then 2 degrees down from parallel.
Posted 02 November 2011 - 06:50 AM
Hence the questions lol.
im going to look at the.chevelle uppers and maybe mcdonalds brothers lowers.
#30
Posted 03 November 2011 - 04:45 PM
A force is a push or a pull upon an object that results from its interaction with another object. Forces result from interactions! As discussed in Lesson 2, some forces result from contact interactions (normal, frictional, tensional, and applied forces are examples of contact forces) and other forces are the result of action-at-a-distance interactions (gravitational, electrical, and magnetic forces). According to Newton, whenever objects A and B interact with each other, they exert forces upon each other. When you sit in your chair, your body exerts a downward force on the chair and the chair exerts an upward force on your body. There are two forces resulting from this interaction - a force on the chair and a force on your body. These two forces are called action and reaction forces and are the subject of Newton's third law of motion. Formally stated, Newton's third law is:
For every action, there is an equal and opposite reaction.
#32
Posted 06 November 2011 - 09:06 PM
#33
#34
Posted 07 November 2011 - 10:12 PM
#35
Posted 07 November 2011 - 10:36 PM
I deliberately bought three Fords, two of which was brand new.
#36
Posted 08 November 2011 - 05:20 PM
#37
Posted 08 November 2011 - 07:55 PM
#38
_coupe202_
Posted 19 November 2011 - 07:18 PM
#39
_LXSS350_
Posted 21 November 2011 - 03:33 AM
My god is there is no greater sin than owning a Fraud???
That sort of thing gets you a one way ticket to Purgatory.
#40
Posted 21 November 2011 - 08:22 AM
Two of the Fords I bought brand new.
#41
_LXSS350_
Posted 21 November 2011 - 05:35 PM
#42
Posted 21 November 2011 - 06:34 PM
#43
_LXSS350_
Posted 21 November 2011 - 06:42 PM
Get him into the heart of the Lion.
As we know Henry Frauds are only good for simsmetal collection. LOL
#44
Posted 21 November 2011 - 06:52 PM
#45
_LXSS350_
Posted 21 November 2011 - 07:00 PM
#46
Posted 21 November 2011 - 07:13 PM
#47
_LXSS350_
Posted 21 November 2011 - 07:37 PM
#48
Posted 22 November 2011 - 02:18 PM
#49
_wblje_
Posted 02 December 2011 - 07:02 PM
#50
_ballrash_
Posted 01 January 2012 - 11:53 AM
Ben
