I finally got the old radiator support panel off and have clamped/teched the new one in place.
I had to use the fence strainer again to pull the chassis rail in 6mm to line up with the bumper hole on the left side. Ill leave in place untill its all welded together as it set with this helping.
Im still waiting on the front vallance, so I will not weld inplace until I get that and make sure all is well.... Its on its way..
I will also weld in some patches to make the panel look like an original LC support.. Ill do when all together so it doesnt move.
I tell you what guys.. Its a job making sure everything is lined up... It has taken all day to get right.. I also changed the bonnet catch plate as the chrome one was bent.. and it also had cable release. My car never had cable release.. The new/old one is as it should be.
Seems all the chrome pieces are stuffed....
Now I will have a go at fixing the inner guard. Its a mess as you can see. It doesnt look too hard to do, a little thought and take my time.. should work out fine..
Mike
Edited by mikecatts, 25 September 2012 - 08:46 PM.
