LC S Coupe Rebuild
674 replies to this topic
#576 _judgelj_
_judgelj_
Posted 11 March 2014 - 07:40 PM
Ok so what i got from that is hotter plugs are more suited for stock engines that are not under heavy loads. Cold plugs are used for race and heavy load applications. The thing is if my plugs are not dissipating heat enough and allowing these deposits to coat the tip, wouldnt i want a hotter plug anyway?
Is pre ignition and issue with the holden 6 with say one heatrange difference?
#577 _threeblindmice_
_threeblindmice_
Posted 11 March 2014 - 07:49 PM
I never got into plugs much , just figured if it's modified to near an XU1 use XU1 plugs
#578 _threeblindmice_
_threeblindmice_
Posted 11 March 2014 - 07:57 PM
My silver one used to fowl plugs , in stop start traffic , it went that well , I just put up with it ,two miles of open road and they cleaned themselves .
#579 TerrA LX
I wass under the impression they needed to be replaced. How can i clean them? They are charcoal black.
Don't clean them if they are dirty, only fouled (fuel) can be cleaned easily and without damage.
Sounds like 9/10ths of your problem is old plugs, stop all tuning and throw a new set at it and see how it goes.
#580 TerrA LX
Posted 11 March 2014 - 08:00 PM
It's the opposite, hot plugs dissipate less heat...
Sorry I missed, what is exactly building up on your plugs if it is not fuel it must be oil.
No amount of hotter plug will fix engine wear and will only make tuning a real PITA.
#581 _judgelj_
_judgelj_
Posted 11 March 2014 - 08:47 PM
Fuel. They are becoming sooty. And its had 3 new sets through it. First set before the tune, second set put in a few days prior to the car being taken in for tuning, and the third just recently until it started missing and i pulled them out to find they were completely black again.
#582 _judgelj_
_judgelj_
Posted 11 March 2014 - 08:56 PM
And bruce i had a look and it seems like NGK recommends a BP6ES for the LC XU1.
Im running HEI, new coil, module, curved dizzy and spiral core leads. I'm thinking maybe i should try the colder plug and stuff around with the gap? is 1mm the norm?
#583 S pack
Posted 11 March 2014 - 09:12 PM
I've been running NGK BP6ES plugs in the 202 for years without any problems.
With the Bosch HEI ignition the recommended plug gap is 1.5mm.
#584 _threeblindmice_
_threeblindmice_
Posted 11 March 2014 - 10:17 PM
It's not your plugs , the car is set up to run well after 70 MPH , and your running it around town out of its comfort zone .
#585 _judgelj_
_judgelj_
Posted 11 March 2014 - 11:32 PM
Yeah maybe you are right, but I do usually give it a hard time so that must compensate for the stop start traffic. Could possiy explain why it was missing the whole 50min drive to the car show but not on the way back (all freeway). Maybe they cleaned themselves?
But anyway I think I'll go for the bp6es gapped appropriately, it's worth a shot. What about using b6es without the protrusion? I was lead to beeline it's not needed with HEI?
#586 TerrA LX
Posted 12 March 2014 - 09:37 AM
Just for shits and giggles, get a clean plug (if you don't have a spark tester) and open the gap right up (i mean bend the ground electrode right back), bung it in a lead and clamp the plug to a good earth, start the car and look for a nice big blue spark jump the gap.
If you go colder plugs the condition will worsen, hotter plugs might detonate if it runs well on the express way.
Select the right plug (reach) to suit your head with a 1.2mm to 1.5mm gap for the HEI.
If the plug burn feels good on the express way check the burn on them (you may have to pull over somewhere and let it cool before you foul them again) on the ground electrode to check heat range.
#587 _judgelj_
_judgelj_
Posted 12 March 2014 - 06:35 PM
I do have a spark tester. Am i checking for strong ignition?
Thats the thing. Why are colder plugs more suited to race applications and hotter plugs to every day situations, when a colder plug does less to burn off excess fuel? Or is that not relevant when poor tuning is a factor?
I agree that a colder plug wont help me. If the XU1 ran a "6", i must have issues if i am fouling "5's". I'm thinking about trying a 4 but i dont want it to go bang!
#588 _judgelj_
_judgelj_
Posted 12 March 2014 - 06:39 PM
what about protruding electrodes?
#589 FNQ
FNQ
  • 118 posts
  • Name:Darryl
  • Car:lc
Posted 12 March 2014 - 07:11 PM
When you say it was tuned , was it running well throughout the rev range,    it sounds as if you are too rich for the first part of the needle ( idle probably okay but then too rich , and then gets right again under a bit of load.
Do you know what profile needles are in the Sus ? , ( i don't know settings for Holden sixes but do play around twin SUs in my mini...  I would be tempted to get hold of a portable AFR meter and find out if the profile is right / giving reasonable AFRs...   as a fudge, you could dial the needles up the jet a known amount ( so you can revert back to stock if required and keeps them all in sync) and if it improves things in the stop , start , idle stakes  then it shows your needle profiles are set for blatting rather than all round   as suggested by 3 blind mice above   Darryl
#590 S pack
Posted 12 March 2014 - 08:06 PM
Racing engines are regularly working in the upper rev range so combustion chamber temps are high for long periods of time so a colder plug is required to dissipate the heat quickly. The same race engine would foul it's plugs very quickly if driven on suburban streets at the posted speed limits. Besides the fact it would be a real pig to drive around town anyway.
Darryl
^^^ I somewhat agree.
Edited by S pack, 12 March 2014 - 08:07 PM.
#591 _judgelj_
_judgelj_
Posted 12 March 2014 - 10:43 PM
It ran well except for around 3.5-4k where it would hesitate, but this stopped occurring after a rotor button change. Im pretty sure they are OA6 needles if memory serves me. If that doesnt make sense i will double check.
So dave in my case where i need to buy a set of plugs that will probably foul anyway (just to get me about in the meantime), is one range hotter going to be that risky or should i be asking someone who has tried it?
I suppose BP6 is pointless in my case?
#592 TerrA LX
Posted 13 March 2014 - 06:59 AM
Yes, you should have a nice big fat blue spark, if it is yellow in any way then they will not be firing correctly.
Higher cylinder pressures(temperature) and tune etc (usually in race conditions) can overheat a standard plug and going to a colder plug brings plug operating temp back to a normal range to prevent detonation etc (caused by the plug overheating, these conditions are normally bought on by too much comp for fuel, poor ignition timing, lean tune and incorrectly set idle stop).
Cooler plugs can foul easier at idle and off idle cruise conditions, not something that really concerns a racer.
You can check easily if you need a colder plug by looking at the burn on your current plugs.
I'm thinking you have a weak ignition and or a rich idle, off idle cruise condition.
FWIW BP6EFS-13 (1.5mm gap) is what is used in the VC-VH blue motor HEI.
As I said before, check new plugs against the oem plug for that head, some are longer and will screw in past the combustion chamber.
NGK list carbon fouling causes as rich fuel mixture, clogged air filter, faulty choke system, prolonged low speed driving or idling, faulty ignition system, over-retarded ignition timing and spark plug heat range too cold.
I hope this helps you better understand.
#593 _judgelj_
_judgelj_
Posted 13 March 2014 - 02:57 PM
Yeah i think all this information has educated me a fair bit. The question now is what do i need for my application. Im leaning towards a hotter plug just as a band aid to get me through some driving, but im worried about pre ignition.
#594 _threeblindmice_
_threeblindmice_
Posted 13 March 2014 - 08:07 PM
I never had a problem when I was running Avgas ,grey pipe grey plugs all the time , pity it's illegal .
#595 _judgelj_
_judgelj_
Posted 13 March 2014 - 08:28 PM
no one has to know, bruce !
#596 TerrA LX
Posted 13 March 2014 - 08:40 PM
Even just 300mls of the stuff in a tank does wonders...
How does the spark look?
#597 _judgelj_
_judgelj_
Posted 14 March 2014 - 01:25 PM
Well i did what you said and bent the electrode right back. Nothing impressive. spark looked like a human hair with a bit of orange here and there.
Spoke to NGK and they reckon the VB is a 0.9 gap. Recommended i try 1mm first. Ill clean the plugs this time around and try. At the same time ill do the timing again. What i noticed was a lot of black on plugs from cylinder 1,2,5,6, whereas 3,4 were more brownish in colour.
#598 TerrA LX
Posted 14 March 2014 - 01:54 PM
VB had points, that's why the gap is 0.9mm.
Even 1mm would be the bare minimum, they run a 1.5mm gap with HEI, as per the plug I suggested earlier, I would suggest starting at 1.5mm in the correct plug to suit your head (as the commodore plug may screw too far into your combustion chamber) and close it up to 1.2mm if you have high comp and you have experiencing high end miss.
I would be looking harder at cyl 3 and 4 slightly lean and test/substitute the coil and or HEI module to rectify weak ignition.
Edited by TerrA LX, 14 March 2014 - 01:56 PM.
#599 TerrA LX
Posted 14 March 2014 - 01:57 PM
What part number coil do you have and is it getting full battery voltage via the ignition LT wire (yellow/pink ignition wire)?
#600 _judgelj_
_judgelj_
Posted 14 March 2014 - 08:02 PM
The coil is the next best chinese replacement as i couldnt a bosch coil they are not in production anymore. The module is brand new bosch. I had a suspicion that the VB may have been points as 0.9 didnt sound right. Is it worth going from 1mm  - 1.5mm if my spark seems weak? And the coil has 12v directly from the cranking side of the ignition. I have a few pics to put up i will do it when i can.
So i basically pulled the plugs out, gave them a clean and car fired up beautifully. I set the timing to rule that out (wasnt far off). I then pulled the rocker cover off and replaced every single rocker nut as they were a bit touch and go. This took a while of idling the car to do all the pre load adjustments after which i pulled a plug from number one and it was black. So what im thinking is obviously this car cant be left to idle. I then took it for a long drive at which point i noticed it was running like a bag of crap. Missing through all the gears until i got it on the highway and opened her up for a period of time. Seemed to clean them out and it reduced the missing the a bare minimum. Car was pretty smooth after that but still not 100%. My next question is could my SU's mixtures fall out of adjustment? These were completely reconditioned fyi.
I also replaced my fuel reg and still no response on the gauge. It must be busted. I chucked an external pressure gauge on and it was running at 3psi no regulator. Does this seem right? Shouldnt it be 4psi out of the mechanical pump?
Edited by judgelj, 14 March 2014 - 08:02 PM.
