LH SLR Rims
81 replies to this topic
#1 hanra
Posted 20 August 2012 - 06:45 AM
Whas there any distinguishing features of a standard steel rim to suit SLR and also the SLR hubcaps?
What was the width of the rim?
#2 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 20 August 2012 - 07:14 AM
5.5 inch Brad with the option of 6 inch.
The hubcap takes special wheelnuts I thinks rares sells them.
Phillip
#3 hanra
Posted 20 August 2012 - 07:47 AM
Hmmm righto mate. I better check availability of wheel nuts other wise Im wasting my time...
#4 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 20 August 2012 - 08:47 AM
You wont have a problem finding any of the components brad. the hubcaps come up NOS on ebay occassionally.
#5 hanra
Posted 20 August 2012 - 12:39 PM
Ok. How do I tell if Im looking at 13s from a LC/LJ or LH/LX? Is there a particular offset these wheels should be???
#6 hanra
Posted 20 August 2012 - 11:16 PM
Is any part of the rim seen once the hubcap goes on? If so, I guess I'll have to do some more painting....
#7 hanra
Posted 21 August 2012 - 12:48 PM
Is the P/N stamped into the standard rims at all?
#8 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 21 August 2012 - 01:38 PM
The number on spare rim/s I have is GM 22 3411 if thats any help
#9 hanra
Posted 21 August 2012 - 02:50 PM
Thanks for that info NOBALLS. Need to some how determine if the the rims used on other early Holdens such as LC LJ also suit LH? I have no idea if they are the same or not....? Some one must know.
#10 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 21 August 2012 - 02:58 PM
Same rims brad they just need to be 5.5 inch wide. LC - UC will do the job.
Phillip
#11 hanra
Posted 21 August 2012 - 03:03 PM
Good one Philip. Thanks for your input. I will see what I can track down.
#12 hanra
Posted 22 August 2012 - 08:53 PM
What would be a well suited size tyre to fit onto a 13? 205 all round? or 195 up front? No flares fitted.
#13 _CHOPPER_
Posted 22 August 2012 - 09:13 PM
195/70R13's are EXTREMELY hard to get. They were unavailable new in Australia in 2004. Somebody might be bringing some cheap Chinese/Taiwanese crap.
#14 hanra
Posted 22 August 2012 - 09:21 PM
Is that what the stock size was? I was thinking 205/60/R13?
#15 _CHOPPER_
Posted 22 August 2012 - 09:34 PM
BR70H13 was stock for an SL/R 5000, 195/70R13 is the metric sizing. 205/60R13 is probably the easiest size tyre to get that would be suitable. Don't think that 205/60R13 and 205/65R13 won't be discontinued. The market share is just too small.
#16 hanra
Posted 22 August 2012 - 09:55 PM
Pizza cutters!
#17 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 22 August 2012 - 10:00 PM
Stock size would be 185/70 in my opinion. 205's are too wide for a 5.5 inch rim in my opinion. Looks like a pregnant wombat.
#18 _LH8VD69_
_LH8VD69_
Posted 23 August 2012 - 12:12 AM
I thought u weren't going to run with the stock rims n hubcaps Brad ?
#19 hanra
Posted 23 August 2012 - 06:19 AM
I wasn't going to. But I've had a brain fart and decided to change.
#20 _sstorana_
_sstorana_
Posted 23 August 2012 - 08:36 AM
Hi Brad,
just so you know, the part numbers for the rims are;
13 x 5.50 2813815 Same number for LC/ LJ/ LH/ LX/ UC
The only one that is different in 13 x 5.50 is the LJ XU-1's that had a different part number (2823863).
13 x 6.00 9929130 Same Number for LH/ LX (N/A for UC)
The only one that is different in 13 x 6.00 is the LJ XU-1's that had a different part number (9928167).
Mick
#21 hanra
Posted 23 August 2012 - 10:07 AM
Good one Mick. Thanks for the info!
#22 hanra
Posted 23 August 2012 - 06:29 PM
What should I expect to pay for a old set of 5.5in rims?
#23 _CHOPPER_
Posted 23 August 2012 - 07:24 PM
Some people virtually give them away. I sold a set of 5 for $50 about 4 years ago.
#24 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 25 August 2012 - 02:27 PM
Found these, are they what you are after.
http://www.ebay.com....4#ht_500wt_1413
#25 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 25 August 2012 - 03:34 PM
Or these.
http://www.ebay.com....9#ht_688wt_1180
