* * * * * 4 votes
LX GTR Hatch
turbo awd
817 replies to this topic
#601 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 24 March 2018 - 04:07 PM
Painted the switch block and fitted the switches to see how it looked, still need to engrave two plates to say what each switch does.
Attached File  A9X_0134_resize.JPG   206.49K   39 downloads
Attached File  A9X_0135_resize.JPG   205.19K   38 downloads
#602 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 02 April 2018 - 08:54 PM
Wasn't happy with the washer bottle/catch can, decided to make it a bit lower and and raise the bottom to hide the washer pump and boost control valve.
Attached File  A9X_0137_resize.JPG   345.95K   30 downloads
Attached File  A9X_0139_resize.JPG   300.01K   28 downloads
Attached File  A9X_0141_resize.JPG   284.54K   26 downloads
Welded in some tabs to mount the panel that has the ECU, fuses and relays on it.
Attached File  A9X_0138_resize.JPG   202.77K   29 downloads
Patched the fan duct hole which had some rust around it.
Attached File  A9X_0142_resize.jpg   208.05K   25 downloads
#603 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 15 April 2018 - 06:05 PM
Welded up the fan duct hole and gave it a hammer and sand. Also started hammering some of the dints  in the floor.
Attached File  A9X_0148_resize.JPG   228.53K   25 downloads
Made up the battery holder with isolator switch. This will hold a Full River HC44 battery.
Attached File  A9X_0150_resize.JPG   213.67K   25 downloads
Attached File  A9X_0152_resize.JPG   229.33K   23 downloads
Attached File  A9X_0154_resize.JPG   263.1K   27 downloads
Remover the hatch hinges and the body sealant and just some surface rust.  :D
Attached File  A9X_0160_resize.JPG   183.23K   24 downloads
#604 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 25 April 2018 - 08:18 PM
Decided to make a trolley to hold the stud welder a few of my hammers and dollies so there at arms reach while I do the body work.
Also started to get all the engine parts together to take to JPC to get rebuilt.
Attached File  A9X_0171_resize.JPG   259.78K   27 downloads
#605 myss427
myss427
  • 1,636 posts
Posted 26 April 2018 - 09:58 AM
Problem with this build is most of the really cool fabricated bits will never be seen, started with a really good shell, can't wait to see it finished!
#606 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 29 April 2018 - 06:58 PM
Had to make one good ignition switch from three.
Attached File  A9X_0172_resize.JPG   377.17K   25 downloads
Painted the column.
Attached File  A9X_0173_resize.JPG   162.75K   27 downloads
#607 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 02 May 2018 - 08:45 PM
The door trims, roof lining and the trim kit for the top of the doors came today from Cools Auto Trim, had them done in black instead of slate.
Attached File  A9X_0174_resize.JPG   154.35K   30 downloads
#608 rodomo
Posted 02 May 2018 - 10:30 PM
Bit of a let down?????????????..................... I thought a bloke like you could make 7 switches from 3?
#609 Heath
Posted 03 May 2018 - 02:06 PM
Ahhh, your hatch interior comes together in the same order as mine I see... I've been keeping my door trims secret though hahaha
#610 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 06 May 2018 - 04:58 PM
Stripped the engine covers and gave them a satin finish.
Attached File  A9X_0175_resize.JPG   140.75K   30 downloads
#611 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 31 May 2018 - 06:52 PM
Not finding much time at the moment to get far on the body work so just buying some more parts like new brakes.
355x32 discs with 6 piston front and 4 piston rear calipers, it might be a bit over kill when the hatch originally come out with 13" rims
and now is going to have 14" discs.
Attached File  A9X_0178_resize.JPG   271.17K   44 downloads
#612 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 02 June 2018 - 08:51 PM
Have 12mm clearance between the spokes and the caliper and 6.5mm between the inner barrel and the caliper.
Attached File  A9X_0182_resize.JPG   227.22K   36 downloads
#613 SHEEL
SHEEL
  • 353 posts
  • Name:Daniel
Posted 04 June 2018 - 12:33 PM
wow. that'll hurt your eyeballs when you pull it up!
#614 Shiney005
Posted 04 June 2018 - 08:55 PM
At 25 pages, the thread is starting to get a bit long to go back through for stuff I can't remember. Are you incorporating the ABS from the donor car Glen?
#615 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 04 June 2018 - 10:13 PM
No ABS.
#616 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 22 July 2018 - 07:11 PM
Started on panel gaps and sort out which is the best nose cone to use, then need to modify the front section of the front flares and front spoiler.
Attached File  A9X_0201_resize.JPG   287.82K   28 downloads
#617 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 29 July 2018 - 06:11 PM
Gave to engine covers a better polish and fitted some Mine triple flow cam baffles.
Attached File  A9X_0206_resize.JPG   240.96K   21 downloads
Attached File  A9X_0222_resize.JPG   274.33K   21 downloads
#618 Shiney005
Posted 30 July 2018 - 08:18 AM
Cam baffles Glen?
#619 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 30 July 2018 - 08:44 AM
The RB engines have a tendency to fill the cam covers with oil then push it out the breathers these help separate the oil.
#620 Shiney005
Posted 31 July 2018 - 08:38 AM
Very nicely explained. Something similar could work in high revving 308s as well.
#621 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,429 posts
  • Name:facebook dave
Posted 01 August 2018 - 07:51 PM
glen it will be fast and you need to stop it
#622 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 12 August 2018 - 05:17 PM
Gave the starter and alternator a clean up and some new bearings.
Attached File  A9X_0225_resize.JPG   236.46K   26 downloads
Attached File  A9X_0228_resize.JPG   289.04K   27 downloads
Attached File  A9X_0230_resize.JPG   263.36K   26 downloads
Attached File  A9X_0232_resize.JPG   221.85K   26 downloads
#623 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 22 September 2018 - 06:54 PM
Playing around with extending the front of the front flares to spoiler.
Attached File  A9X_0234_resize.JPG   242.29K   27 downloads
#624 Rockoz
Posted 23 September 2018 - 10:19 AM
May have missed it in the thread.
Any reason the flares sit so high?
Crappy flares or mods for different sized wheels?
With the seat supporting it I almost though you were going to extend the bottom lip.
Would look different and good if you did.
Have seen photos of alod race cars with an extended lip.
Look good with it.
#625 308 Sunbird
308 Sunbird
  • 976 posts
  • Name:Stuart
Posted 23 September 2018 - 04:56 PM
Better check in with your doggy Glen, looks a bit concerned with something he has seen.  :P
