Would have to think a 2 door would be more rigid than a 4 door as less openings where bending (seals) would occur. Hatch has mostly the same opening as the boot, be it a foot or 2 longer, but has fairly thick frame arround, where the 4 door just has parcel shelf and extra roof. Would be interesting to know the real differnces between the two.
#551
Posted 04 October 2017 - 01:07 PM
#552
Posted 04 October 2017 - 01:28 PM
I think I remember reading somewhere when they were testing the A9X the sedan was more rigid then the hatch but not by much.
#553
Posted 15 October 2017 - 08:06 PM
Got the sun roof patched but will need a bit more tapping.
Brought a stud welding a while ago finally got around to converting the hand piece to take pins and made up a slide hammer
from the nose of a rivet gun.
The car had been rust treated from the dealer so scraped out all the body deadener to start working on the rear quarter panels.
#554
Posted 16 October 2017 - 07:44 AM
Done a great job on the roof!
#556
Posted 18 October 2017 - 07:46 PM
I like slapper dollies too......................but I'm ol' skool............... ![]()
#557
Posted 19 October 2017 - 09:55 PM
#558
_Romper_
Posted 23 October 2017 - 07:42 PM
as per usual amazing work mate, did teched have all the torsion testing equipment at there premises and how long did the actual test take ?
not cheap is it ?
Is there only the the one torsion test or is there a second test required when the car is all back together ?
#559
Posted 23 October 2017 - 07:51 PM
Test testing was done at Lionel West Fabrications, he has all the equipment there, it took about 6 hours to do with me helping to lift in and out all the weights.
There is only one test needed.
I have also re-add all the photos to the build thread.
#560
Posted 05 November 2017 - 06:49 PM
Started working on the rust in the drivers door.
A9X_0008_resize.JPG 256.23K
23 downloads
A9X_0009_resize.JPG 316.81K
20 downloads
Rust cut out.
A9X_0010_resize.JPG 282.32K
20 downloads
A9X_0011_resize.JPG 265.83K
20 downloads
Making up the replacement pieces.
A9X_0015_resize.JPG 299.71K
19 downloads
Front half done.
A9X_0019_resize.JPG 316.33K
20 downloads
#561
Posted 06 November 2017 - 08:19 AM
I hope one day I can learn the skills to bend a length of angle like that.(The way it curves around the bottom of the door) You make it look too easy Glen. ![]()
Edited by Shiney005, 06 November 2017 - 08:20 AM.
#562
Posted 06 November 2017 - 09:32 AM
Amazing. Glen what is your recommendation to coat between the two layers of metal when welding them together like that so the rust doesn't start again??
#563
Posted 06 November 2017 - 07:41 PM
Brett, I usually hit the rust with a 3M strip and clean disc then use a rust converter, I use bondall Ranex rust converter from bunning.
When that dries i then spray over that with a copper base weld through primer.
#564
Posted 07 November 2017 - 09:02 AM
Cheers Glen.
#565
Posted 11 November 2017 - 07:19 PM
Machined the face of the manifold.
IMG_20171106_092133_resize.jpg 579.42K
26 downloads
Decided to cut a larger section out of the bottom of the door. Made up some dies to form the bead at the bottom of the door.
A9X_0036_resize.JPG 330.79K
24 downloads
A9X_0029_resize.JPG 249.39K
27 downloads
A9X_0025_resize.JPG 207.61K
24 downloads
A9X_0028_resize.JPG 216.35K
24 downloads
Found some rust in the door skin, this door is turning into a bigger job then I thought.
I wish someone would make some ADR compliant carbon fibre doors.
A9X_0034_resize.JPG 186.71K
29 downloads
A9X_0032_resize.JPG 142.81K
28 downloads
Edited by turbo76lx, 11 November 2017 - 07:20 PM.
#566
Posted 11 November 2017 - 07:27 PM
frOck yes.
#567
Posted 12 November 2017 - 04:44 PM
Mark
#568
Posted 13 November 2017 - 11:32 AM
Hmm, that mill looks familiar. . .
#569
Posted 13 November 2017 - 02:38 PM
I have no idea what you are talking about Peter. ![]()
#570
Posted 16 November 2017 - 11:27 PM
Spectacular work as always. God I love this thread.
#571
Posted 17 November 2017 - 03:12 PM
Nice work Glen, any chance of making more of the lower door section as a rust repair piece. Happy to compensate for the work involved.
Mark
Hi Mark, I,m not that happy with how the repair piece come out, I think I need to re-machine the dies to make
it closer to the original shape before I gave any thought about selling them.
#572
Posted 21 November 2017 - 07:18 PM
No worries Glen, let us know if you decide to do that. Cheers!
#573
Posted 26 November 2017 - 08:35 PM
Haven't done much more on the door, waiting for new lower half door skins to arrive.
Started cleaning up the windscreen wiper motor.
A9X_0041_resize.JPG 380.24K
27 downloads
Blasted off the paint.
A9X_0042_resize.JPG 374.47K
29 downloads
Also decided to convert the Pullmax to a single phase motor.
A9X_0040_resize.JPG 321.2K
24 downloads
#574
_pepperjack_
Posted 27 November 2017 - 02:04 PM
Hi there Glen it sure looks like you have a well equipped workshop,
is the Pullmax basically a power hammer that you just change the tools to either cut, shape and planish ?
Mal
#575
Posted 27 November 2017 - 07:54 PM
It's similar to a power hammer but the tools are not made to hit each other. They can preform a heap of different operations from cutting, beading, joggling, doming, louvering and making flanges.
General →
General Discussion →
Factory 202 Turbo option and id plateStarted by _Holden red sponge_ , 06 Dec 2018 |
Holden Tech →
Engine →
Phenomenal 202 buildStarted by _RedKobra_ , 10 Jan 2016 |
Holden Tech →
Engine →
Poll
ENGINESStarted by N/A-PWR , 04 Sep 2015 |
Holden Tech →
Engine →
Heat proofing manifolds / wiringStarted by RallyRed , 01 Aug 2015 |
Holden Tech →
Engine →
Strata turboStarted by _luva15_ , 27 Jan 2014 |
