#51
_niterida_
Posted 25 December 2012 - 06:43 PM
For 2 reasons :
1. Great idea and will be an awesome build
2. You are getting very positive response on here and I got slammed when I posted ideas about doing something similar and mine was oinly going to be cutting up a UC !!
Now I have an LX as well so will be watching your progress eagerly.
Good Luck.
#52
Posted 25 December 2012 - 08:09 PM
#53
Posted 25 December 2012 - 08:51 PM
#54
_niterida_
Posted 25 December 2012 - 10:16 PM
He also said I was not allowed to modify the firewall in any way whatsoever - is your engineer ok with your flat firewall ?
#55
_Emu_
Posted 25 December 2012 - 10:55 PM
Will watch and patiently wait
#56
Posted 26 December 2012 - 07:42 AM
Ken, the fire wall is just a flat sheet stiched welded over the original fire wall.
In the rear there is no cutting of the chassis rail only need to make a small depression ( about 2mm) to clear the top link arms on the subframe.
IMGP2026.JPG 141.85K
10 downloads
The front needs the folds in the wheel arch where the coilover is needs to be removed. The engineer in happy with this.
IMGP1758.JPG 159.06K
6 downloads
Edited by turbo76lx, 20 October 2017 - 07:05 PM.
#57
Posted 26 December 2012 - 10:27 PM
#58
Posted 26 December 2012 - 10:31 PM
Speaking of your sedan, any progress on that lately? I was frothing at the last lot of pictures of it.
#59
Posted 27 December 2012 - 07:36 AM
#60
_The Baron_
Posted 27 December 2012 - 08:08 AM
#61
Posted 27 December 2012 - 02:08 PM
#62
Posted 27 December 2012 - 06:17 PM
When is the kit version due?
Never say never. Doing the subframe isn't to hard, the cut outs for the coilovers is the hard part.
If you had a custom set of coilovers made that had a smaller diameter so the would fit into the original shock mounts, it
would reduce the amount of work needed to do a conversion and would also reduce the width if the wheels you could run.
The shock towers would probably still need a small amount of extra renforcement.
#63
Posted 27 December 2012 - 07:45 PM
Made up a bracket on the subframe to mount the ATTESA pump (the hydraulic pump for the 4wd system).
IMGP2042.JPG 153.25K
6 downloads
Also started mounting a clutch master cylinder under the dash. Using a master cylinder from a toyota hiace.
IMGP2044.JPG 110.79K
9 downloads
IMGP2046.JPG 103.84K
7 downloads
IMGP2047.jpg 113.5K
9 downloads
Edited by turbo76lx, 20 October 2017 - 07:11 PM.
#64
_LS1 Hatch_
Posted 28 December 2012 - 02:01 AM
#65
Posted 28 December 2012 - 06:43 AM
Don't think i'll be driving it far at the moment.
IMGP2048.JPG 128.46K
6 downloads
Edited by turbo76lx, 20 October 2017 - 07:12 PM.
#66
_LS1 Hatch_
Posted 28 December 2012 - 07:14 AM
#67
Posted 28 December 2012 - 05:49 PM
Got the clutch master cylinder done. Made up a comp plate to pick up the brake and clutch pivot bolts, which will also
help transfer the position of the mounting holes to the hatch. The big hole is the outlet port.
IMGP2050.JPG 124.9K
8 downloads
Needed a bit of clearance around the banjo nut.
IMGP2049.JPG 118.37K
9 downloads
Added another adjustable pedal stopper, i only needed 25mm of travel in the master cylinder to match the nissan master cylinder.
IMGP2053.JPG 147.08K
9 downloads
The pedal
IMGP2055.JPG 102.18K
8 downloads
If anyone was going to copy this set up it probably will work with the foot park brake. The part number for the master cylinder is JB1521.
IMGP2051.JPG 144.95K
7 downloads
Edited by turbo76lx, 20 October 2017 - 07:23 PM.
#68
Posted 28 December 2012 - 06:50 PM
After repeated use and abuse (especially with a bottom stop) I've found that my pedal keeps bending/twisting across the section where the pivot bolt goes through. I reinforced it with an extra piece of steel across the back (toward the firewall) to partially box that section and seems to be good now, might be worth doing while you're at it.
#69
Posted 28 December 2012 - 06:58 PM
#70
_Emu_
Posted 28 December 2012 - 07:13 PM
#71
_niterida_
Posted 28 December 2012 - 07:33 PM
Would it be possible to do the rear subframe and leave the front stock torana. And still use the standard motor like a 202 or 308 with a custon driveshaft or would the driveshaft angle be wrong? Or foul without tunnel mods
I thought that but then you don't get easy access to bigger brakes and wheels and coilovers, not to mention POWER STEERING
#72
Posted 28 December 2012 - 07:37 PM
#73
Posted 01 January 2013 - 12:06 PM
Got the rear floor patched to allow the 50x50 angle for the rear subframe mount to sit against the floor and put the subfame in.
IMGP2062.JPG 169.14K
10 downloads
Looks like i will be able to mount the coilovers on the original shocker mounts without cutting in the wheel arch.
IMGP2065.JPG 163.96K
8 downloads
IMGP2066.JPG 161.21K
8 downloads
Edited by turbo76lx, 20 October 2017 - 07:28 PM.
#74
_2wild4u_
Posted 02 January 2013 - 12:47 AM
far out havnt been on here for a while, some big modifications happening
#75
Posted 02 January 2013 - 07:18 PM
Made up some more of the rear coilover mount, covered in the old spring mount to add some strength.
IMGP2068.JPG 137.54K
8 downloads
Edited by turbo76lx, 20 October 2017 - 07:30 PM.
General →
General Discussion →
Factory 202 Turbo option and id plateStarted by _Holden red sponge_ , 06 Dec 2018 |
Holden Tech →
Engine →
Phenomenal 202 buildStarted by _RedKobra_ , 10 Jan 2016 |
Holden Tech →
Engine →
Poll
ENGINESStarted by N/A-PWR , 04 Sep 2015 |
Holden Tech →
Engine →
Heat proofing manifolds / wiringStarted by RallyRed , 01 Aug 2015 |
Holden Tech →
Engine →
Strata turboStarted by _luva15_ , 27 Jan 2014 |
