* * * * * 4 votes
LX GTR Hatch
turbo awd
817 replies to this topic
#76 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 14 January 2013 - 07:33 PM
Got the rear mounts welded and the rear coilovers sorted, using R32 BC racing coilovers with R33 lower mounts.
Also started the fuel tank.
Attached File  IMGP2071.jpg   151.1K   10 downloads
Attached File  IMGP2075.jpg   140.6K   8 downloads
Attached File  IMGP2069.JPG   123.19K   7 downloads
Attached File  IMGP2073.JPG   144.07K   7 downloads
The gap between the fuel tank and subframe is where the fuel pumps and surge tank will go.
Attached File  IMGP2070.JPG   134.76K   7 downloads
Attached File  IMGP2072.jpg   153.67K   7 downloads
Edited by turbo76lx, 20 October 2017 - 07:39 PM.
#77 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 14 January 2013 - 07:40 PM
looking good ive been waiting eagerly for an update
#78 _niterida_
_niterida_
Posted 14 January 2013 - 08:25 PM
Looks almost TOO easy :D
#79 _The Baron_
_The Baron_
Posted 14 January 2013 - 08:34 PM
Just to get an idea, can you run an estimated hours for this. ie just add a rolling tally everytime you post.
Might give everyone an idea as to how many hours are really involved with this job. Your photos make it look to easy!
#80 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 15 January 2013 - 07:47 PM
To put the rear end in the hatch i would say about 30 hours but i spent 100+ hours fitting the rear end in the yellow sedan,
trial filling the R32 and R33 rear ends. The R33 rear end does make for a good diff conversion option.
If i was to put one in another torana i would just use the original front subframe mounting point and make a bracket on the
torana subframe in front of the back wheels. Just remember doing this conversion you will need to fill in the spare wheel well in
the back floor, build a custom fuel tank, run a single exhaust and make the skyline hand brake work with the torana system.
#81 _The Baron_
_The Baron_
Posted 15 January 2013 - 07:58 PM
So a minimum 130hrs to this point?....not bad.
Keep adding them hours up because understanding what is really involved with a project like this will help others before they leap!
#82 _niterida_
_niterida_
Posted 15 January 2013 - 08:29 PM
Off-topic but I have been keeping a running total of the hours I have spent modifying my Brumby to take WRX suspension front and rear. So far I am up to 160hrs but I have found the same thing as Glen - it takes a lot of time to figure things out and try them out before you find the right way of doing it. Now that I have done one Brumby I reckon it would take me about 40hrs to do another one.
#83 76lxhatch
Posted 16 January 2013 - 06:24 AM
Why the single exhaust? I presume it would run beside the diiff housing in the middle, is that offset to one side a bit?
#84 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 16 January 2013 - 03:04 PM
The rear sway bar has a bend in it on the passenger side to clear the exhaust, you may be able to get a custom sway bar made or not run one at all.
#85 _PB.72.LC_
_PB.72.LC_
Posted 18 January 2013 - 09:54 PM
every time i click on this build to see your progress i am amazed at the progress and skill you have, many of us torana fans are saying ohhhhh how are you doing that, but at the same are saying, man your a legend for actually doing it. im very much hoping you finish it with the same quality as the rest of the build. if you do it will be one F*** off torana!
#86 _SS Hatchback_
_SS Hatchback_
Posted 19 January 2013 - 03:23 PM
awesome work, when i first seen the start to this thread i was questioning how is this all going to fit, well not only did you get it to fit but it looks like its meant to be , job well done . Need some more popcron to finish watching the show
#87 _ultrabluea9x_
_ultrabluea9x_
Posted 22 January 2013 - 05:48 PM
fuxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx orsome
#88 _PB.72.LC_
_PB.72.LC_
Posted 02 February 2013 - 06:37 PM
god damn your good!
#89 _greenmachine215_
_greenmachine215_
Posted 12 February 2013 - 08:42 PM
MORE!!!!!
#90 _Bomber Watson_
Posted 12 February 2013 - 08:50 PM
Mmmoooaaarrrrrr!!!!!
Considering my intense disliking for nissan, im really liking this. Kinda like that vl that was done a century ago, was cool to.
#91 orangeLJ
Posted 13 February 2013 - 10:42 AM
I hear they make conversion kits to adapt 2J to the AWD running gear...... :D
#92 _Bomber Watson_
Posted 13 February 2013 - 01:34 PM
Yep r33 box behind a proper engine (2j) is pretty common.
#93 _adz2332_
_adz2332_
Posted 13 February 2013 - 02:43 PM
Just awesome mate!!
Your moulding together two cars that i own!! i have a 380rwkw r 33 GTR as my daily and building a LH torana!
Very jelous!
#94 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 13 February 2013 - 09:09 PM
Ok bit of a update, ordering fuel pump and fittings before finish welding the fuel tank and converted the speedo to electronic.
A 2j would be good but i think i will stick with the RB if only to annoy bomber.
To convert the speedo i used a VDO electronic speedo.
Attached File  IMGP2094_resize.JPG   151.91K   7 downloads
Attached File  IMGP2095_resize.JPG   118.47K   7 downloads
Removed the glass with a screw driver.
Attached File  IMGP2097_resize.JPG   109.1K   6 downloads
Attached File  IMGP2098_resize.JPG   193K   7 downloads
The rod for the trip metre needs to be cut off flush with the speedo face and the small yellow button it pushes on needs two wires soldered
on the back for a remote button that will be mounted under the dash.
Attached File  IMGP2099_resize.JPG   158.39K   7 downloads
Attached File  IMGP2102_resize.JPG   136.69K   6 downloads
Attached File  IMGP2104_resize.JPG   166.38K   7 downloads
The plastic housing of the VDO speedo needs to be cut down to fit into the instument cluster housing. The pocket for the high beam
needs to be filled with resin to mount a smaller globe holder and needs to be ground away to clear the speedo.
Attached File  IMGP2108_resize.JPG   122.64K   7 downloads
Attached File  IMGP2107_resize.JPG   114.67K   7 downloads
Glue the blue high beam globe cover back in and also grind to clear the speedo.
Attached File  IMGP2109_resize.JPG   112.44K   7 downloads
Place the torana speedo face over the VDO speedo mark the two screw hole and drill. Screw the original screws into the plastic
face of the VDO speedo. The odometer window needs to be filed to suit.
Attached File  IMGP2103_resize.JPG   119.66K   7 downloads
The needle from the VDO speedo needs to be ground it fit into the back of the torana needle.
Attached File  IMGP2105_resize.JPG   79.32K   7 downloads
Attached File  IMGP2106_resize.JPG   82.3K   7 downloads
Attached File  IMGP2110_resize.JPG   129.1K   8 downloads
Attached File  IMGP2111_resize.JPG   137.38K   7 downloads
Edited by turbo76lx, 21 October 2017 - 12:17 PM.
#95 _mick74lh_
Posted 13 February 2013 - 10:38 PM
Neat as. Nice 'how to'. And nice project by the way. I'm quite blown away by it!
#96 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 14 February 2013 - 12:39 AM
Wow, great job on the speedo conversion. As well as the car itself.
#97 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 08 March 2013 - 06:22 PM
Finished the fuel tank, using a holley blue for the llift pump to the 4 litre surge tank then to a bosch 044 pump.
Attached File  IMGP2140_resize.JPG   123.72K   7 downloads
Attached File  IMGP2141_resize.JPG   95.74K   7 downloads
Attached File  IMGP2143_resize.JPG   56.06K   7 downloads
Attached File  IMGP2144_resize.JPG   109.21K   7 downloads
Attached File  IMGP2146_resize.JPG   69.06K   7 downloads
Edited by turbo76lx, 21 October 2017 - 12:22 PM.
#98 _BARRY JACKPOT_
_BARRY JACKPOT_
Posted 08 March 2013 - 09:30 PM
Holy fabrication batman! What a neat job, well done.
#99 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 13 March 2013 - 08:03 PM
Pulled the motor and gearbox out of the skyline and took the head off and sat it on the rb30 in the test mule.
Left the twin turbos on but will be running a single.
Attached File  IMGP2184_resize.JPG   172.52K   6 downloads
Attached File  IMGP2178_resize.JPG   164.75K   7 downloads
Will be using a modified torana brake booster with commodore master cylinder.
Attached File  IMGP2176_resize.JPG   170.75K   7 downloads
Edited by turbo76lx, 21 October 2017 - 12:26 PM.
#100 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 13 March 2013 - 08:15 PM
So about how much would it cost for an R33 complete IRS?
