Torana power steering kits.
172 replies to this topic
#51 axistr
axistr
  • 1,239 posts
Posted 05 November 2013 - 08:10 PM
I have been asked if they will suit SBC, I think the accessories bolt holes on the head is different but I will double check the hole spacing.
#52 A9X
Posted 05 November 2013 - 08:31 PM
Hello Lenny.
Thanks for thinking of me.
When you say standard factory extractors you mean for the commodore ?
How do they sit in the engine bay / k frame / firewall regarding clearance.
certainly appears to be plenty of room.
I'm currently waiting on that yank mob that andy put me onto for the uni joint adaptor.
only info missing re the brackets is the cost of the pump.
again, thanks for all your efforts . i'm really keen to get over this minor hurdle and move on.
#53 axistr
axistr
  • 1,239 posts
Posted 06 November 2013 - 05:51 AM
Hi Welby, yes the extractors are from the commodore. I didn't do any mods to the drivers side extractor, and only a small mod to the left one as it got close to the rail at the collector.
I didn't include the prices on the pump as I am waiting for my supplier to confirm the current cost.
#54 Dr Terry
Dr Terry
  • 3,359 posts
Posted 13 November 2013 - 03:46 PM
I can also supply brand new genuine Sagnal power steering pumps. There is a Chinese knock of copy which is cheaper by around $65.00 which I can also supply on request, or I can reco your pump if you have a spare one floating around. I personally would go the new Genuine Sagnal pump but if your on a budget the choice is yours.
Do you mean Saginaw brand pumps, (not Sagnal).
Dr Terry
#55 axistr
axistr
  • 1,239 posts
Posted 13 November 2013 - 05:12 PM
So all these years I have been spelling it wrong.?
#56 Dr Terry
Dr Terry
  • 3,359 posts
Posted 14 November 2013 - 02:19 PM
It does look that way.
These pumps are made by the same division of GM as the Saginaw gearboxes, as seen in HK/T/G V8s.
Dr Terry
#57 _devojr62_
_devojr62_
Posted 10 January 2014 - 06:48 AM
Hi ho
How do I contact you to order one kit please..
Brian
Hi ho
Brian
#58 _LS1 Hatch_
_LS1 Hatch_
Posted 10 January 2014 - 06:53 AM
Dr Terry
Saginaw is a town in Michigan actually...probably where the company started out... (Saginaw stuff was used in various makes here as well.. GM and Mopar, cars and trucks, etc)
I sold a VH Charger 770 to a couple there actually. Oddball factoid of the day, ha ha..
#59 axistr
axistr
  • 1,239 posts
Posted 10 January 2014 - 11:57 AM
Gee LS1 Hatch you must have not liked them much to sell them a charger.
Devojr62, Brian you can contact me on 0417678066 or email me direct axistr@people.net.au
Thanks Lenny.
#60 _LS1 Hatch_
_LS1 Hatch_
Posted 10 January 2014 - 04:08 PM
Oddball factoid part II...I had brought that car over in the same container back in 2000 as my red hatch.
:D
#61 _joecoelho70_
_joecoelho70_
Posted 26 January 2014 - 08:16 AM
Hi Lenny,
Could you tell me what is the difference betweem the variable and standard racks?
Joe
#62 axistr
axistr
  • 1,239 posts
Posted 27 January 2014 - 12:32 PM
G'day Joe,
The Variable ratio rack I use is mechanical variable. The teeth cut on the main rack shaft between the centre section and outer ends sections are machined so the teeth are at different varying angles. The varying angles of the teeth allow the rack ratio to increase as the steering wheel is turned towards left or right lock. The benefit of this design is to reduce the total turns lock to lock without making it to quick/direct in the centre section. To quick a ratio in the straight ahead position can cause oversteer: (example) at high speed on the freeway.
The standard ratio rack has the steering rack shaft teeth machined straight cut across the entire gear teeth engagement section.
Below are the two racks both look the same from the outside. The bottom rack in the photo is standard ratio and the upper is the variable ratio. Its not the best photo showing the variable ratio rack shaft, but if you look closely you can see the centre section four teeth are straight then either side they start to angle over and the teeth pitch changes. You can also see how many more teeth there are on the standard ratio main rack shaft in comparison. Its a hard thing to explain but I hope the photos give you a better understanding.
The standard ratio rack has approximately 3.3 turns & variable ratio 2.8 this depends slightly on which steering arms are used. Both racks also give you around three degrease more wheel lock each side reducing the Torana's total turning circle.
I hope I have explained it well enough and haven't confused everyone.
Lenny.
#63 350mick
350mick
  • 12 posts
  • Car:Lx Torana
Posted 15 March 2014 - 04:59 PM
Hi Axistr
I know this is not what the topic is
What model was the sr5 hilux you used for the aircon retro fit to your hatchback
In 1997 there was a change in that year with the hilux
So any info would be good , like what engine was in the vehicle or early 1997 you get the idea
#64 axistr
axistr
  • 1,239 posts
Posted 17 March 2014 - 04:10 PM
P.M sent mick.
#65 350mick
350mick
  • 12 posts
  • Car:Lx Torana
Posted 18 March 2014 - 07:40 AM
#66 _VINESY_
_VINESY_
Posted 12 May 2014 - 09:37 AM
Hey Lenny,
I am looking at fitting one of the after market K frames to my LX sedan. I am assuming that since they are modelled to the original, your power steering will fit?
I am also a candidate for next year.
#67 axistr
axistr
  • 1,239 posts
Posted 12 May 2014 - 05:31 PM
G'day Nathan,
Haven't supplied one of this application yet but if it has the same mounting points and clearances that of the standard K-frame I can't see why not.
#68 _PRO076_
_PRO076_
Posted 31 May 2014 - 02:26 PM
Hi im interested in power steering for my lx hatchback i have a 253 in it but eventually mite upgrade to 308 or small block chev would it matter? Or im i better off waiting untill i have my engine?
#69 axistr
axistr
  • 1,239 posts
Posted 03 June 2014 - 06:01 PM
G'day Nick, Its the same power steering rack so it doesn't matter what engine you are running or going to run, it just means you may have to put the power steering pump in a different mounting position depend on your accessories drive set up.
#70 N/A-PWR
Posted 03 June 2014 - 06:06 PM
Welcome to the Forum Nick,
#71 axistr
axistr
  • 1,239 posts
Posted 21 June 2014 - 08:52 AM
Hi All,
I just got my insurance cover renewal for the power steering racks kits again, I seams that the insurance cover per year is the same as the profit from the rack kit sales over the past 12 months. Due to only selling these kits in limited numbers per year I have decided to have a sale. I have in stock three standard ratio rack kits that I am going to let go at cost $2,450 till the end of the month if any one is interested.
Lenny
#72 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 23 June 2014 - 01:18 AM
PM Sent
(and bump for others)
Edited by Lima31, 23 June 2014 - 01:18 AM.
#73 _bmac1451_
_bmac1451_
Posted 18 September 2014 - 09:47 AM
Just wondering if someone can give me the contact details of the guy making the power steering kit to suit UC model (Lenny) contact bmc79450@bigpond.net.au Thanks Bruce
#74 axistr
axistr
  • 1,239 posts
Posted 22 September 2014 - 08:29 AM
Contact details
Axis Truck Repairs.
Ph: 0417678066
Email axistr@people.net.au
Lenny.
#75 _PAC5000_
_PAC5000_
Posted 05 November 2014 - 02:51 PM
HI LENNI - PLEASE EMAIL ME ASAP ON ANY INFO THAT U HAVE & COSTS PLEASE
arcpeterc@optusnet.com.au
Pac Man
Pac Man
