FIXING THE HOLDEN V8 OIL PRESSURE ISSUES. NEW DESIGN OIL PUMP
57 replies to this topic
#51 shags
shags
  • 23 posts
  • Car:lx sedan - hz ute -
Posted 09 January 2023 - 02:05 PM
well got myself this pump. works great, a bit to well.
have blown out two cam welch plugs.
knocked them in nice an square with a coating of silicone, let dry for a day .
anyone know a way to keep them from leaking short of araldite epoxy.
#52 Rockoz
  • 4,074 posts
Posted 09 January 2023 - 02:45 PM
would it be worth tapping a thread in it and screwing a plug in?
#53 76lxhatch
  • 7,227 posts
Its a common mod to thread tap and use NPT plugs for the oil gallery plugs. If you're talking about the big one at the rear some of them are quite solid - they need a fair amount of force to properly wedge into place but won't move once in.
#54 shags
shags
  • 23 posts
Posted 09 January 2023 - 04:16 PM
im talking the big concaved plug at the back of the engine, have done the small ones at front.
would need a 15/8th tap. then need a very thin plug as the trans flange sits over it.
#55 dron
dron
  • 134 posts
  • Name:Darren
  • Car:UC
Posted 09 January 2023 - 07:28 PM
Concave?   Convex to look at when installed, Atleast before you hit it with a hammer to lock it in. Never lost one myself even with hi volume oil pumps, Should not be a lot of pressour at that spot anyway. Atleast if the oil is getting back to sump as it should.
    Never tried silicone on a welsh plug, Permatex Aircraft grade (Hard setting) may help, I normaly would use permatex 3 for that plug, Not hard setting but have never had a problem
Edited by dron, 09 January 2023 - 07:28 PM.
#56 shags
shags
  • 23 posts
Posted 09 January 2023 - 08:17 PM
yeah might not have done it just right.
ill try again and hope it seals better
#57 rodomo
  • 18,080 posts
Posted 09 January 2023 - 09:08 PM
I wouldn't use silicone. Slippery shit. I've always use No 3 gasket cement.
Don't hit the middle of the welch plug. Lay a flat piece of steel on the rim of the plug and hit that.
#58 76lxhatch
  • 7,227 posts
Posted 10 January 2023 - 03:53 AM
^ The domed one at the back of the cam needs to be hit in the middle to get it to spread and lock into place. Don't be shy about hitting it.
Oh and yes, use aircraft sealant not silicon
Edited by 76lxhatch, 10 January 2023 - 03:55 AM.
