what is RTS
63 replies to this topic
#1 _Shelly`s LX_
_Shelly`s LX_
Posted 22 July 2013 - 04:07 PM
Hi what is RTS radial tuned suspension ...okay
i found out that they put this on toranas lx - uc july 77 onwards
how do i know if my car has it its a 4/77 2 door hatch lx
has having 2 sway bars front and back anything to do with it?
#2 _434LX_
_434LX_
Posted 22 July 2013 - 04:25 PM
You have 4 sway bars ? :P
RTS models have an RTS badge on the glovebox lid (unless the dash has been molested)
#3 _Shelly`s LX_
_Shelly`s LX_
Posted 22 July 2013 - 04:58 PM
LoL i have 1 at the front and 1 at the back i have also found out the rubbers on the lower arm big bushes has 3 lumps/dimples on it yeah the glove box has the rts sticker but not sure if original  if the cars with rts came out in july 77 onwards mine is 4/77 ?
#4 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 22 July 2013 - 05:11 PM
RTS Front subframe will have the upper control arms bolted in the low position and from factory would have some solid tube spacers as well as the fork type alignment shims on the horizontal bolts that hold the upper control arms on.
And a front sway bar too.  The springs were different too from memory but I couldn't tell you the exact difference - I always ditch std springs so I have never paid attention to be honest.
Matt
#5 S pack
Posted 22 July 2013 - 07:36 PM
Interesting read about the differences between LX RTS and UC RTS.
http://www.gmh-toran...-lx-rts-uc-rts/
#6 TerrA LX
Posted 22 July 2013 - 08:05 PM
Matt
You forgot the lower bushes are a different compound :fighting:
#7 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 22 July 2013 - 08:47 PM
Tough to see that one visually though.
#8 76lxhatch
Posted 22 July 2013 - 09:41 PM
According to the GMH brochure for the HZ, RTS includes changes to bushes, anti-roll (sway) bars, spring and damper rates as well as the geometry changes. Its a bit light on the specifics (is only general public marketing) but I would assume that similar applies to Torana RTS.
#9 Heath
Posted 22 July 2013 - 10:22 PM
Solid tube spacers spacing the top inner arms in towards the centre of the car? In addition to the shims? I never knew they came with those. How long were they?
#10 ls2lxhatch
Posted 22 July 2013 - 10:27 PM
The spacer was like a thick washer (maybe 5 mm ) to reduce the size of the shim stack.
#11 _outer control_
_outer control_
Posted 22 July 2013 - 11:36 PM
Called Rubbish Truck Suspension
#12 TerrA LX
Posted 23 July 2013 - 12:14 AM
I thought it was radical tuned suspension.
#13 _Matvex_
_Matvex_
Posted 23 July 2013 - 12:38 AM
return to sender?
#14 orangeLJ
Posted 23 July 2013 - 01:13 PM
Really Tight Slots?
#15 Marks LXTorana
Marks LXTorana
  • 158 posts
  • Name:Mark Grovenor
  • Car:LX Torana
Posted 07 August 2013 - 03:34 PM
Matt
So if my '76 LX has a front sway bar, would that mean it has been modified from standard? The car itself has had many mods (304 efi, 5sp, 9" diff) although I am soon going to dismantle the front end down to give it a freshen up. It has a sway bar and REALLY low springs which i want to lift by an inch or so to give it a bit more clearance.
#16 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 07 August 2013 - 04:02 PM
SS Hatches had front and rear sway bars from their release in Feb 76.  I'd be suprised if the SLR5000s were not the same but I have never owned one, nor looked into it so I am not sure on them.
#17 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 07 August 2013 - 05:56 PM
LH and LX SLR 5000's both had standard front and rear sway bars.
#18 Dr Terry
Dr Terry
  • 3,359 posts
Posted 14 August 2013 - 08:02 AM
RTS first appeared on the Sunbird in Nov 76 & then on the 6 & V8 Toranas in Mar 77.
Only RTS cars got a factory rear sway bar.
Prior to RTS, only the SS & SL/R (& GTR in LC/LJ) got a front sway bar.
Dr Terry
#19 yel327
Posted 14 August 2013 - 12:54 PM
RTS was lots of things in the day and it varied a fair bit between the 3 x types of RTS used on LX and UC, but all that really matters now is that you have the RTS suspension geometry, sway bars and solid steering rack mounts (as per A9X or UC RTS methods, different but does the same job). Rest is all academic as it'll be changed like rubber compounds, springs, shocks etc. You are lucky with U sized Toranas as it is all unboltable stuff and can be changed, but with HZ the suspension geometry was changed within the chassis rails making it harder to adapt to HQ-6/77 HX without changing the rails.
#20 StephenSLR
StephenSLR
  • 6,717 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 14 August 2013 - 01:31 PM
Not necessarily, mine's 9/76 SL/R and came with front and rear 'anti-sway' bars (a.k.a. stabiliser bars) from factory.
It doesn't have RTS.
s
Edited by StephenSLR, 14 August 2013 - 01:37 PM.
#21 StephenSLR
StephenSLR
  • 6,717 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 14 August 2013 - 01:39 PM
LX SL/R's had front and rear too.
Note: They're anti-sway bars people, they don't make the car sway, lol.
s
#22 StephenSLR
StephenSLR
  • 6,717 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 14 August 2013 - 01:42 PM
There were 3 types of suspension but only 2 types of RTS I believe.
LX Torana with standard suspension
LX Torana with RTS (RTS phase 1)
UC Torana all had RTS (RTS phase 2)
s
Edited by StephenSLR, 14 August 2013 - 01:42 PM.
#23 yel327
Posted 14 August 2013 - 03:19 PM
No there is 3:
LX RTS. This is heaps lowered upper control arm mounts, changed suspension components (shocks, rubbers etc) but from memory retained the rubber mounted steering rack. This is what was first introduced on Sunbird and later on Torana as Dr Terry says.
A9X RTS. Used UC type upper arms, arms mounted high again (I think) and LX rack but rubber mounts replaced by solid mounts (alloy from memory).
UC RTS. Solid mount rack and a few other bits and pieces different to A9X.
I'm being prety general with the types, just doing it from memory and listing the major changes, there were other bits and pieces too.
#24 StephenSLR
StephenSLR
  • 6,717 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 14 August 2013 - 03:26 PM
No there is 3:
Ah, okay.
I thought the A9X was still LX Phase 1 RTS but with a few different components whereas the UC RTS was a design overhaul, hence phase 2 RTS.
s
Edited by StephenSLR, 14 August 2013 - 03:26 PM.
#25 yel327
Posted 14 August 2013 - 04:13 PM
A9X was actually closer to UC, it used the UC upper arms and solidly mounted an LX steering rack.
