Thoughts on this 202 combo
#51
Posted 28 October 2013 - 10:07 PM
Might go for the "just enough" & keep it minimal though, if only to save compression.
Posted 03 November 2013 - 10:09 PM
So after finally notching the bores, checking & re-checking clearances, we have moved on...
Eventually settled on bloody close to 30 thou valve to block clearance.
Gave everything a clean & bolted down the head, fitted lifters, pushrods, guide plates & rockers.
Rechecked rocker geometry (had to clearance the back of the rockers for a bit more pushrod room)
Im using a 9.450" Crow moly pushrod, could maybe bring it back a little to say 9.350" to make it sit really nicely on the valve, but it looks damn close for now. Spun it over a few times, rechecked tappets again, got it looking like this...
#53
Posted 04 November 2013 - 07:39 PM
jonesy,
Can you let on a bit more about your head and who did the work, also is there a story with the dividers and and reasoning behind them, i assume it just beats going around a round pipe eh ?
reason is that i have a 161 yella terra , or may be it just has the yt valves with double springs and was thinking of doing it up as a side project and wanted to know some specs like valve size etc as a starting point and any tips on putting a spec together to start working to.
G
#54
Posted 04 November 2013 - 07:58 PM
I have a 12 port head like that with the same inlet dividers and it's a yella terror bathurst 1200 item
#55
Posted 04 November 2013 - 08:25 PM
pretty sure peter he said that it's a 161 and that's why i was asking about the dividers , it's not a 12 port as i looked at his thread, sure looks like a 12 port with thoes dividers though they are pretty neat
I could be wrong
Edited by Agent 34, 04 November 2013 - 08:25 PM.
#56
Posted 04 November 2013 - 08:42 PM
I know plenty of people out there will have made power with the standard post in place, but it's all a bit of - let's try this & see what it does - kind of thing. I had Performance Techniques here in Adelaide do the work. Full credit goes to them.
Valve specs were - inlet 1.72, ex 1.44.
Inlets were custom made & shaped stainless, exhausts are profiled to the same shape HQ items.
Honestly, I went way over where I wanted to go, but it became a project. If I were to do it again, id step it down a little, keep the pole dividers, use 12 port valves, but stay with the high comp head.
#57
_oldjohnno_
Posted 04 November 2013 - 09:03 PM
Yeah I'm guessing a little here but I'd say the dividers somewhat stop the turbulence created by the pole as it goes around it. It's shaped pretty much like a teardrop...
Thats a good guess. Airflow past a cylindrical object (like a head bolt tube) is actually pretty poor; there's a lot of instability and turbulence on the downstream side. The upstream side is fine (no need for any fancy knife edges or the like) but you can pick up quite a bit of flow by extending the downstream side. The ideal shape for a 9 port bolt tube is probably a Kamm tail - being a bit shorter it avoids splitting the port and making it harder for each valve to breathe from the entire port. The only reasons round tubes were used is they were cheap and easy to fit.
#58
Posted 04 November 2013 - 09:10 PM
Kamm Tail?
Sarcasm aside, is that a cut off teardrop?
Posted 04 November 2013 - 09:14 PM
hi oldjohno is there much of a power gain by using 1.6 ratio rocker i have a turbo motor with them on it
#60
_oldjohnno_
Posted 04 November 2013 - 09:35 PM
Kamm Tail?
Yep.
#61
_oldjohnno_
Posted 04 November 2013 - 09:38 PM
TBH I don't know but seeing as any factory headed six is going to be flow-restricted to some extent (turbo or n/a) I'd imagine they would help. But I'd be asking someone who has done it.
#62
_oldjohnno_
Posted 04 November 2013 - 09:43 PM
#63
Posted 04 November 2013 - 09:47 PM
The 9 port seems to like the divider, except in absolutely blown or turbo cases, it was taken out & tried on my head but actually lost flow. One other thing we could have tried on mine (which helped make 206cfm on another 9 port) was chevy style valve guides with the port bowl dug right out from around them.
Looked awesome too.
#65
Posted 11 November 2013 - 10:09 PM
Looks nice, I'd recommend to double up the alternator bracket, I found out the hard way ![]()
#66
Posted 20 November 2013 - 09:55 PM
Ok, so its finally in.
Finished plumbing it up, filled it with fuel, oil & coolant, then kicked her in the guts...
Sounds descent, a lot more cam note than before, still fairly smooth & really responsive.
Time to give it a good tune & clock up some miles before dyno time ![]()
#67
Posted 21 November 2013 - 08:25 PM
looks neat!
#68
_STRAIGHTLINEMICK_
Posted 21 November 2013 - 09:56 PM
Looks good , very little chrome tells me it should go ok !!
#69
Posted 21 November 2013 - 10:51 PM
Well made air cleaner bases.
#70
Posted 22 November 2013 - 07:35 PM
#71
Posted 22 November 2013 - 07:47 PM
Look's tame on the outside Jonesy,
I imagine this one has more than the last one. Dave I
#72
Posted 22 November 2013 - 07:54 PM
Those air cleaner bases are HOT
#73
Posted 22 November 2013 - 07:59 PM
Nice work with the heat shield to isolate the SU's too.
#74
_nostolgia186turbo_
Posted 22 November 2013 - 08:16 PM
I agree , don't throw the triple su carbs mate , I ran a 12.7 with triple 1-3/4 su,s & a C-E solid cam . high comp head . steel crank . Toyota box & 3.9 diff ratio , basic stuff that worked . still have engine though have gone to much larger cam .
#75
Posted 23 November 2013 - 10:25 AM
