Thoughts on this 202 combo
369 replies to this topic
#101 _Inj gtr202_
_Inj gtr202_
Posted 17 December 2013 - 06:37 AM
That's nice work Jonesy,
Pretty much identical power figures to my 202 combo.
Who did the dyno and do you have a print out? I'm interested to compare the torque and power curvs.
#102 SA EH
SA EH
    Another Holden 6 tragic
  • 1,050 posts
  • Name:Jonesy
Posted 17 December 2013 - 04:53 PM
Was yours injected?
I had Specialty Tuning do the work on it, they always have, & Neville does a great job.
I do have a dyno printout but it's still with Nev, I'll have it by the weekend tho.
#103 _Inj gtr202_
_Inj gtr202_
Posted 18 December 2013 - 07:06 AM
yep mine is custom injection.
#104 _Ned Loh_
_Ned Loh_
Posted 18 December 2013 - 12:57 PM
Alrighty then.
So I got the tune up done today, super impressed with the work that went in to making it perform. Had to modify the springs in the dizzy & reset timing again, check & set all carby jets, idle, dashpot oil etc etc. Fitted a richer - read WAY richer - set of needles. Went from my old faithful TP set to RH.
Anyways, got 152.7kw n/a out of it. A bit over 200hp at the wheels in the old scale.
Now let me tell you that was nowhere near the 7k+ rpm I was expecting, it was 32 degrees & we were spraying water over the su bowls to keep them cool.
So on account of it being so f-ing hot, things were against us for running the gas without worrying about everything, so we finished up. Might give it another go in the new year on a cooler day, but for now, time to clock up some km's.
stout - well done.
nice to see a 202 build thread.  There should be more...
#105 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 21 December 2013 - 08:04 PM
Just thought i'd throw up the copmarison between the TP needles (bottom) I was running compared to the RH needles (top).
The AO6 & AO7 needles are the ones in between.
And the dyno printout - yeah i know its not 152.7 but this was the cleanest run...
#106 adam_73LJ
adam_73LJ
  • 72 posts
Posted 23 December 2013 - 09:58 AM
Did Performance Techniques provide any flow figures for the head work? I'm looking for a good place to do my head in Adelaide that really now their stuff.
Cheers, Adam.
#107 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 23 December 2013 - 04:58 PM
Yeah Adam they got 198cfm @ .550 lift out of it, more than enough for my combo, quality work too.
As far as knowing their stuff, I'd be interested to see who knows more...
#108 MictheAussie
MictheAussie
  • 236 posts
  • Name:Mic
Posted 24 December 2013 - 05:42 AM
Nice Jonesy!
I knew that combo had 200RWHP in it. It will be interesting to see how it likes cooler weather and some gas.
#109 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 24 December 2013 - 10:01 AM
I think it will like it REAL good...
Just doing the post dyno stuff at the mo, changing plugs, oil & filter, adjusting tappets, fixing teeny coolant leaks, stuff like that.
While it was getting dynoed, worked out we weren't getting accurate readings at the tailpipe so had an o2 sensor bung welded in just after the extractors.
So now I'm thinking of making or getting some kind of gauge running off a sensor to see what's happening under load. More so for tuning the gas while I'm doin nothing....
#110 _Bomber Watson_
Posted 24 December 2013 - 10:50 AM
Jump onto summit and pick up a LM2.
While your there just to top up the package grab a Gtec Pro SS as well.
Best money you will spend.
#111 _Bluejinx202_
_Bluejinx202_
Posted 24 December 2013 - 05:37 PM
I've bought one of those lm2's but haven't got around to using it, have you used one with any success in your old boat? Would the gtech work for me with the rise of the hull on launch?
#112 _Bomber Watson_
Posted 24 December 2013 - 06:10 PM
The LM2 is how i tuned the old boat. It would still be sitting there running on four spluttering when you tap the throttle if it wasnt for it.
The Gtech works a bit funny on boats, very hard to do the quarter mile thing because the Gtech demands you get totally stationary, this generally takes about 2 minutes of floating there waiting lol. The HP runs are usefull though, though probably not totally accurate on water.
#113 warrenm
Posted 25 December 2013 - 05:52 AM
Be careful where you place the O2 sensor in a boat, as the sensor will not last long if hit with water while it's in use.
If you need to purchase Innovate stuff, try this http://highway66spee...pe=2&sortItem=7
There prices are similar to the USA but less the freight.
#114 _Inj gtr202_
_Inj gtr202_
Posted 02 January 2014 - 04:13 PM
I did all my own tuning with the o2 sensor just after the extractors. Best thing you will ever buy.
just for comparison here is my dyno sheet showing very similar peak hp.
I have since tweaked the tune a fair bit since this was done but I imagine the peak hp would still be the same.
Edited by Inj gtr202, 02 January 2014 - 04:17 PM.
#115 warrenm
Posted 04 January 2014 - 09:12 AM
Similar dyno results as mine, within a couple of hp.
#116 _Inj gtr202_
_Inj gtr202_
Posted 06 January 2014 - 12:47 PM
Warren,
Does the shape of your curve look more like Jonesy's?
You run tripple su's as well don't you?
It's interesting to see how the different induction and head packages behave.
It looks like the 9 ports really come on hard in their sweet spot, whereas the 12 port is more of a constant increase.
#117 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 06 January 2014 - 02:05 PM
That looks like a fairly strong top end you've got there Adam, I still haven't driven mine since it was on the dyno so I can't really tell you how good mine is! I have got an Innovate digital gauge/sensor coming so I can do my own tuning, aswell as one of those colour tune thingamajigs.
Where's your printout warren?!
#118 warrenm
Posted 07 January 2014 - 06:44 AM
This was with the 12 port head, 2" SU's, Armours manifold, 256° cam & 10.8:1 cr. This setup ran 12.7@105 on the 1/4. I'll have to look for the print out for the current combo.
Attached File  Image (600 x 436).jpg   47.22K   12 downloads
Edited by warrenm, 07 January 2014 - 06:45 AM.
#119 _Inj gtr202_
_Inj gtr202_
Posted 07 January 2014 - 11:50 AM
Very interesting Warren, looks almost identical.
Obviously one dyno will ready different to another, but the shape of the curves are pretty damn close if you scale them together.
Jonesy I imaging with the well sorted stall converter yours will be damn fast, remember mine and Warrens are stick shifts.
#120 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 07 January 2014 - 04:25 PM
You're right Adam. I hope the converter is enough for n/a & spot on for the gas.
BTW is yours 9 or 12 port? Are there any pics floating around of it?
#121 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 07 January 2014 - 04:48 PM
And nice 1/4 time with a stick there warren...
#122 warrenm
Posted 07 January 2014 - 05:54 PM
It now runs 12.51@108 with a different cam, 12.5:1 cr, 9 port head & still a stick car.
#123 _Inj gtr202_
_Inj gtr202_
Posted 08 January 2014 - 09:51 AM
http://www.gmh-toran...ction-manifold/
#124 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 08 January 2014 - 05:47 PM
That - is - awesome! Great fabrication work bud, very impressive. It makes the project all that more worthwhile when you put that sort of work into it, well done son!
#125 _gmlj6_
_gmlj6_
Posted 16 January 2014 - 05:37 PM
i think this should go high 10s on nitrous pretty easily. my 11.5.1 hydraulic 248* cam 9 port 1 3/4 su 202 made 134 kw through a trimatic and 3500 converter and ran 13.5 @ 101. then on a realistic 75 hp of nitrous ran 11.5 118.
