LS1/LS2 conversion into a WB Statesman
190 replies to this topic
#126 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 15 April 2015 - 07:28 PM
There is non on my model VY. I think the VZ was the first with fly by which was a few months later
#127 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 15 April 2015 - 07:52 PM
Ill see if you can delete yours and use LS1 TB
#128 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 20 April 2015 - 05:07 PM
Nobody has been able to get back to me about wiring diagram but is the VZ 6.0 the same as VE 6.0?
#129 BIG KEV
BIG KEV
  • 1,221 posts
  • Name:Kevin
Posted 20 April 2015 - 06:06 PM
Not to sure Bart
From what I know my motor is 07/08 yr if that helps
#130 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 23 April 2015 - 09:59 AM
According to this the L98 comes with the E38 ECU. The E38 ECU does come from VZ 6.0 but ill make sure.
Other wise these guys sell the converted loom but i dont know the price
http://www.ultimatec...p?categoryid=17
#131 _monman71_
_monman71_
Posted 08 May 2015 - 07:58 AM
Who did you buy the sump from? Cheers
#132 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 08 May 2015 - 11:12 AM
Mast sump from the US, Including dip stick and gasket
#133 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 09 May 2015 - 02:25 PM
http://www.mastmotor...id=160&c=49&s=7
#134 _monman71_
_monman71_
Posted 09 May 2015 - 08:32 PM
I have been talking to them on Facebook, they will have stock with in the week, they want $225 freight so looking at $624 U.S.
#135 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 09 May 2015 - 10:23 PM
Yeah that's about right, make sure you get gasket, dip stick tube, dip stick and oil pick up and you're all done. The oil filter is just normal commodore ls1 filter.
Pick up tube should include O ring
This is where I got mine, bit cheaper depending on the freight cost http://paceperforman...st-oil-pan.html
Edited by Bart, 09 May 2015 - 10:28 PM.
#136 BIG KEV
BIG KEV
  • 1,221 posts
  • Name:Kevin
Posted 11 May 2015 - 02:57 PM
Bart what reluctor wheel are you running on your crank
#137 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 11 May 2015 - 03:47 PM
Im not sure what it is mate. Is this regarding the wiring?
Did you want to use the LS1 computer?
I think your computer for the 6.0 is E38 which i can get wiring for but im not 100% if all E38's are the same from VZ to VE. If anyone can confirm thats great
Also, do you need the security disabled? I know a guy who can do it around $100
Edited by Bart, 11 May 2015 - 03:48 PM.
#138 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 11 May 2015 - 03:50 PM
http://www.ls2.com/f...heels-Explained
#139 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 11 May 2015 - 04:29 PM
Changing  the wheel sounds like a big job but apparently there is a converter
http://forums.justco...ut-ls1-l98.html
#140 BIG KEV
BIG KEV
  • 1,221 posts
  • Name:Kevin
Posted 11 May 2015 - 07:55 PM
I have to change the reluctor wheel because I am going to run a LS1 computer and harness
A ls2 has a 58 tooth reluctor and ls1 only has the 24 tooth
#141 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 12 May 2015 - 01:06 AM
Ok, if youre going LS1 computer I can definitely help
#142 Bigfella237
Posted 12 May 2015 - 11:20 AM
Yes Kev, take Bart's advice and get the converter box, it's about $250 compared to major engine surgery.
To change the reluctor wheel, the crankshaft needs to come out and have the wheel pressed off and on, and of course you need to swap the sensor itself (24x is black, 58x is grey)...
...but there are other changes between the two ECU's as well...
The cam sensor also changed and was moved from the rear of the block (under the manifold) to the front (in the timing case). The early version was a simple 1x trigger machined into the cam that let the ECU know when the engine was on No1 firing stroke; the later version is a 4x trigger cast into the cam drive gear designed to let the ECU know the position of the cam for the VVT option which started with the L92 motors.
In the picture below, A & B are the two 4x trigger sprockets for the two different cam designs (note the centre bolt / three bolt fixture), C is a 1x trigger for a front sensor, and D is used with the early rear cam sensor.
Also I believe the knock sensors (under the valley cover) changed and cannot be swapped without drilling and re-tapping the bosses.
#143 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 12 May 2015 - 11:25 AM
Converter box seems the easiest way or VE computer, but Big kev sounds set on the LS1 computer so converter box is needed
#144 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 12 May 2015 - 11:36 AM
Or sell off your current computer and buy an after market like Haltech? I know a guy using one in an LS2 turbo
#145 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 12 May 2015 - 11:46 AM
http://files.haltech...v_1_website.pdf
#146 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 12 May 2015 - 04:20 PM
Have you got the LS1 engine loom? You will need that for an LS1 computer.
What gearbox you running?
Im hoping the LS1 loom fits on the sensors, injectors, coils etc??
#147 Bigfella237
Posted 12 May 2015 - 04:56 PM
I doubt the loom would connect straight up, there are three different injector connectors that I know about alone, early LS1 injectors had a different connector to later engines, and the higher-flow flex fuel injectors have a different connector again.
#148 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 12 May 2015 - 05:10 PM
Hmmmm
Ok do we know what others have done with LS2 engine on LS1 computer?
#149 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 12 May 2015 - 05:14 PM
Yes looks like the connectors are a bit different
http://www.ls1.com.a...-L76-conversion
#150 Bigfella237
Posted 12 May 2015 - 08:06 PM
Just looking at these converter boxes, I had wrongly assumed that the converter would replace the E38 ECU, then connect to the earlier LS1 PCM, that way you could use the correct wiring loom for the engine, but it seems the converter box connects to the individual sensors themselves...
http://www.lingenfel...egory_Code=C163
Attached File  L460065397_900.jpg   348.97K   1 downloads
Attached File  DSCF6278_900.jpg   147.23K   0 downloads
So it looks like you must use the loom that came with the computer and adapt all the other connectors to suit the engine?
Edited by Bigfella237, 12 May 2015 - 08:06 PM.
