1102 replies to this topic
#851 _livo74_
_livo74_
Posted 05 August 2017 - 09:15 PM
cheers covert!! thank you!
#852 _livo74_
_livo74_
Posted 05 August 2017 - 09:42 PM
ah, gotcha! so can run 2 senders! cheers andrew and gtr, and jason, think thats what you were trying to tell me too.
was my idea of tapping out of the wire as it leaves the sender no good cus it "halves" the signal??
have found some tee's
trying to suss out ones with right size holes/threads for a vb/vc 253 oil sender unit
think?? am on right track?
iIF this is the sender
http://www.ebay.com....zsAAOSwt0FZCGyA
..it says it's thread 1/4 18npt
so...
i need
well, i don't know?
cus this seemingly has the correct 1/4 top and bottom, but only a 1/8 side.
and i cant find one with all three as 1/4's
anybody seen one?
why the fook the smaller 1/8 out the side?
jas, you mentioned "smaller ones"
like a 1/8 that i screw into the side?
tried the rod adjust, think i may not of put my console brackets in right spot??
am able to move shifter forward half a 1/2 cm, i think? might try and move it.
and NO BANJO BANGO gtr!! lol
#853 _livo74_
_livo74_
Posted 05 August 2017 - 09:48 PM
have just cottoned on to the fact if i use a t piece, i can plug in my existing "gauge/sender" to one port, and run to the aftermarket gauge
and by a proper oil "switch" for on the other port, for the instrument panel "light"
#854 _livo74_
_livo74_
Posted 05 August 2017 - 09:57 PM
never mind, a little looking and seems the ACTUAL oil pressure "switch" for an lx torana is... 1/8 th !
so will screw the 1/4 VB COMM sender into the end of the t piece, and screw the 1/8th torana switch on the side.
http://www.ebay.com....L4AAOSwYIxYAsBp
woo hoo!
Edited by livo74, 05 August 2017 - 09:58 PM.
#855 Bigfella237
Posted 05 August 2017 - 10:59 PM
The thread in the oil pump on a Holden V8 is 1/4NPT aka 1/4BSP aka 1/4 inch "gas" thread, whatever you want to call it (all the same thing).
Note that IT'S A TAPERED THREAD so don't over-tighten it or you will split the alloy oil pump casing.
Nearly all oil pressure switches/senders come in either 1/8NPT or the larger 1/4NPT, but I'd say the 1/8NPT ones would be more common, not that it matters here.
The T-piece and 1/8NPT switch you pictured above look okay, that would get your dash tell-tale light working properly. That switch is rated at 0.3bar, which is 4.35psi, so that sounds reasonable. A loose old engine might well dip down that low at idle when hot, but a quick double-check of the gauge will tell you if you still have some (any) oil pressure?
Then you just connect your new gauge sender in the 1/4NPT fitting that's spare.
I know I'm spending your money for you but you can't be too careful when it comes to oil pressure, and it's not uncommon to suffer oil surge with these rear-hump un-baffled sumps (that means if the oil level is low enough, and you corner or hit the brakes hard enough, the pump sucks a big gut-full of air and your oil pressure goes bye-bye).
#856 _livo74_
_livo74_
Posted 05 August 2017 - 11:55 PM
Spend away!
I don't have a clue what's best to be done.
Thanks Andrew for taking a look at the specifics of the parts I posted. I don't know "specifics" to darn well!
(Forgive me when I buy the cheap stuff though.
It's gonna happen a lot! Very few 5times more expensive brand products will be on this car.)
No point stopping now. More money to be spent!
The temp "sender", as is presently in the car now, will run to my (soon to buy) triple gauge kit also.
(Will take off the present wire ..the to "dash lamp", and run new wire the the gauge)
And.. buy a temp Tory "switch", and mount in the spare bung in manifold, and use the harness dash "lamp" wire obviously
Imagine way to go, rather than using a tpiece again. That'd be chunky hangin off the front of the manifold!
Quick question.. or two
Are these all GROUNDS I'm using as signal?
Know the temp is, but the oil?
Now .. how to hook up the battery signal that's the third gauge? Hmmm.
The other two gauges needed "senders" as such...
But the battery gauge???
#857 Bigfella237
Posted 06 August 2017 - 12:08 AM
Yep, the switches and senders all allow a certain amount of ground (earth) to reach the gauges via the single wire.
All the gauges, including the volts, will need a positive feed from somewhere in the ignition circuit (so the gauges only work when the ignition is on), plus the volt gauge will need a full time earth, it simply senses the voltage in whatever circuit you connect it to.
If you want the volts super-accurate you probably should run a feed wire from the positive battery terminal direct to the gauge (via a fuse) but I wouldn't bother myself, probably better off reading the voltage of the ignition circuit anyway.
Apart from that there's only the bulbs that light-up the gauges themselves, not sure whether they're LED or incandescent, or whether they're dimmable in either case, but probably easiest to tap into your grey wire under the console, the one that lights up your PRND21
#858 _livo74_
_livo74_
Posted 06 August 2017 - 09:35 AM
champ! i can do all that
(hmm. didn't look into the gauges to see if/how illuminated. will do. if aren't led i will look for another)
#859 Bigfella237
Posted 06 August 2017 - 09:43 AM
Nah doesn't matter if they're not LED, in fact they will probably blend in better with the rest of your dash if they are just normal bulbs.
The only reason I mentioned LEDs is because some aren't dimable (remember how you turned the headlight switch) and might flicker (which is very annoying) if connected to the same circuit as the centre console light.
If you get LEDs that can't be dimmed then you would need to tap into the park light circuit somewhere instead of the dash lights, which is just an extra PITA!
#860 _livo74_
_livo74_
Posted 06 August 2017 - 09:51 AM
just figured led so last longer. but imagine not hard to replace a bulb as where am mounting gauges is easily accessible.
will contact seller and ask if bulb or led, and if dimable are led.
and.. yep. don't have a great interest in tracking down the park light when GREY is so accessible
#861 _76lxJAS_
_76lxJAS_
Posted 06 August 2017 - 12:06 PM
you could go this way also, these will give u 3 extra spots,
leave your current sender were it is,
i run 1 of these and never had any issues with leaks etc,,
http://www.ebay.com....yMAAOSw4CFYzRY1
#862 _livo74_
_livo74_
Posted 06 August 2017 - 03:09 PM
ha, never seen that before.
took me a while to work out where it goes!
cheers for the heads up!
#863 _livo74_
_livo74_
Posted 06 August 2017 - 03:30 PM
all windows and rubbers done.
phew!!
#864 _livo74_
_livo74_
Posted 06 August 2017 - 05:51 PM
quick wipe with a bucket and wet rag. first wash its had in a looooong time
#865 Bigfella237
Posted 06 August 2017 - 06:55 PM
Not brave enough to put the hose on it?
#866 _livo74_
_livo74_
Posted 06 August 2017 - 06:59 PM
used the hose to rinse.
..not that it's watertight! anyone else have drips coming in, or just me.
maybe just me  :(
#867 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 06 August 2017 - 08:14 PM
depends on where the water is getting in ? , usually once the screens were installed a "mastic gun"was used to squeeze some "d mastic"
windscreen sealant (green tube) between the outer seal lip and body of car  before the lock strip was installed , there used to be a "special tool" to install the lock strip . Once the the lock strip was installed this shit would ooze out and get cleaned up with turps and
plenty of clean rag.
The other problem is that the mylar lock strip (pictures of it around here somewhere?) available now is only for the "early" pre box TORANA and is a different profile and is a pain to install on the boxes  without much cursing and swearing , what a shame it's 2017 and they can't even get something like that right ? :)
#868 _livo74_
_livo74_
Posted 06 August 2017 - 09:18 PM
Heya eunuch, sealed the front and rear, no leaks there.
As for the f&#kin Mylar, started to install, got about 3 inchs in and .. after a lot of screaming and cursing.. walked away. Lol
Drop leaks front driver and pass rear door tops, darn it
#869 Shiney005
Posted 07 August 2017 - 12:13 AM
Those flares are looking shmicko Mat. Well done!
#870 _livo74_
_livo74_
Posted 07 August 2017 - 01:20 PM
Cheers shiney!
Like anyone who's done it knows.. they SUCKED making fit
#871 _livo74_
_livo74_
Posted 10 August 2017 - 08:39 PM
Yay!!! moved one tooth, still out. started from scratch, rechecked top dead, moved another tooth, timing done to 6 degres so am told,
and.. am friggin rapt! (even stone cold starts first time and idles smoothly by itself)
knowing me ..might turn idle screw down to make her lumpier (and probably nearly stalling lol) .
nearly on the road!
well,
if you consider front right caliper seized, can't seem to bleed rear drums AT ALL, makes a gas escaping sound when i press brake pedal, no interior lights work, need to have engineered, shifter playing up and out of place and not starting in park sometimes, and that have not done ANY work to rear suspension/bushes etc "NEARLY", then yes. nearly! lol
(by stroke of VERY good luck, found a local ex-mechanic to give me a hand, a bloke i bought a part off and he said give him a buzz if still have any trouble. so was able to let Daz off the hook... this time ;) )
mylar in.
mylar can get FOOKED.
Edited by livo74, 10 August 2017 - 08:41 PM.
#872 _76lxJAS_
_76lxJAS_
Posted 10 August 2017 - 11:13 PM
nice work again mate,
what would u need engineers for??
as for brake, id just buy some rebuild kits for the calipers and some new slave cylinders, then bleed them all up..
no questions then on there condition etc,,
#873 _livo74_
_livo74_
Posted 10 August 2017 - 11:25 PM
Cheers jas!
Engineers for the 5 seats,
Car plated for beach seat 6
..not that you can read the tags
Too much paint coats for that
Will have a look into the rebuild kits
Brakes.. kinda important I guess;)
#874 _76lxJAS_
_76lxJAS_
Posted 10 August 2017 - 11:31 PM
i wouldnt think u need to have it engineered for that?
the new seats would still be mounted into factory locations yer?
id only worry about that if they picked it for a RWC
#875 Bigfella237
Posted 10 August 2017 - 11:49 PM
Except that all the seats came out of a Subaru didn't they? And the seat belts got changed as well from memory?
If you can't get any fluid whatsoever through the rear lines, it could also be the flexible line between the body and diff too, they can swell shut over time.
I don't suppose you would have bench-bled the master cylinder before installing it?
