1102 replies to this topic
#1076 _livo74_
_livo74_
Posted 17 February 2018 - 09:04 AM
read this in regards to my car rolling when in "park".
"Never engage Park when the vehicle is moving or the Rear wheels will lock and a loss of control of the Vehicle will result. In extreme cases the Pawl will shear off and the Governor Hub will be destroyed causing an expensive rebuild or replacement."
hoping is not the "extreme" case.. as prefer your mention gtr of hearing that it may be a simple fix if can get into gearbox!
anyways, here's the puzzler,.... am quite SURE that the car used to go into "park" and stop rolling!
so am wondering, that now ive fiddled with the trimatic selector again that it's just a tad out still.. and that's why it now "rollls"
that's what i'm hoping, anyways
will post more details when car been to mechanics for the rear brake work.
Edited by livo74, 17 February 2018 - 09:05 AM.
#1077 Davis
Davis
  • 343 posts
  • Name:Drew
  • Car:LC 2 door
Posted 17 February 2018 - 09:10 AM
The rare spares website has a calculator to input your car specs to determine which speedo gear you need
#1078 Davis
Davis
  • 343 posts
  • Name:Drew
  • Car:LC 2 door
Posted 17 February 2018 - 09:14 AM
https://www.rarespar...m-24-teeth-yell
Click on this link and underneath it has a speedo calculator tab
#1079 _livo74_
_livo74_
Posted 17 February 2018 - 09:25 AM
cheers davis! will use that along with the other one was given,
but the problem i have at the moment is my inner gear drive is perfectly "green", or a discolored white? or yellow?
..so am unsure of what details till can count the teeth on it.
once have done that will use the calculator
re "rolls in park"
"check that the linkage or cable is putting in into park properly as i had the same prob in my hz i adjusted the cable and she is locking great now.
get under her while shes in park and see if there is any advance movement that can be made"
again, here's hoping
Edited by livo74, 17 February 2018 - 09:29 AM.
#1080 _Housecat1977_
_Housecat1977_
Posted 17 February 2018 - 11:37 AM
Hopefully you have already tried this but if not...
Have you tried disconnecting the control rod that goes to the box and then put it in park at the box to see if it will still roll?
That will prove what is at fault, the shifter setup or the box.
#1081 Rockoz
Posted 17 February 2018 - 12:01 PM
Often rolling in Park will just be a linkage adjustment.
As someone has said, manually put it in Park. You will probably have to disconnect the linkage to do it.
Then adjust the linkage back to suit the Park position needed.
#1082 gtrboyy
Posted 17 February 2018 - 02:39 PM
Disconnecting shifter rod cheap(free) way to test if shifter issue or auto.
Tbh they're hard to break jamming into park unless done repeatedly or as said above high speeds...most still didn't break (no comment!!!)
If it had serious damage you'd notice when driving it.
*If you can work out what actual diff ratio,tyre size & speedo gear then muck around on calculator untill it matches then you'll know teeth on green gear.
Edited by gtrboyy, 17 February 2018 - 02:42 PM.
#1083 _livo74_
_livo74_
Posted 17 February 2018 - 03:08 PM
thankyou every one, whilst you had left messages i was out under the car doing exactly as you mention.
car parks now. hooray!
took 4 goes.. bloody jacking up, stands, adjusting, dropping down and testing... and repeat another 3 times aargh!
but i got there!
(what may be the cause of all this seemingly unnecessary trouble... is i think my shifter .. and mounts... are all about 2cm forward than they should be.
you see... the hole was put in by previous owner... and i stupidly assumed correct placing. so.. i mounted shifter, sat my console on, marked mounts where sitting, and welded.
think having the shifter a bit forward affect the throw, despite my belief it shouldn't affect it.
and having to drill the console bolt holes "forwards" half a cm to accommodate the nuts should really of sent alarm bells off. but it didn't. idiot.)
gtr, kinda tried that earlier with the calculator, but was a few that kinda matched nearby, so couldn't pinpoint.
but.. what i did do while i had the car up is chucked the red one in.
gonna take for a drive and see how much better.. or worse lol
will post results very soon
Edited by livo74, 17 February 2018 - 03:09 PM.
#1084 _livo74_
_livo74_
Posted 17 February 2018 - 03:31 PM
so here tis..
red gear in, the car was doing 46-7k's when speedo said 50k's
and
92-3 when gauge said 100
not too shabby!!
so, on the calculator..
using the 8 toothed "white" (and my specs and red gear...)
Speedo Details
"Speedo Accuracy is :  -8.75%      at 100kph, your speedo reads :  91.3kph"
exactly!
so, therefore my  "green" drive gear is a white, i'd say.
and, if i buy a green cable drive piece... i'tll be spot on, cays the calculator!
"Speedo Accuracy is :  +0.34 % "
Edited by livo74, 17 February 2018 - 03:35 PM.
#1085 _livo74_
_livo74_
Posted 22 February 2018 - 03:23 PM
time to add another unexpected cost to the project.
as it is, the car surely must be in the running to win the worlds loudest in-car noise car competition. jeezus!!
am going to strip interior and add about 5 thick coats of kill rust epoxy, and a layer of sound deadener, and maybe a felt underlay too.
also a few more coats of sprayon deadener in wheel arches.
#1086 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 22 February 2018 - 04:14 PM
Dynamat the interior
#1087 gtrboyy
Posted 22 February 2018 - 07:08 PM
Yeah Dynamat is the new rage.
What's the issue exhaust drone or heat?
*never added heavy heat insulation but have added mufflers/resonator either for exhaust drone(v8 lc gtr) or too damn loud need earplugs (355 vh sle)
#1088 _livo74_
_livo74_
Posted 22 February 2018 - 07:44 PM
cheers dave, looked into the popular choice dynamat, but am also considering stuff called PingJing
hard to pinpoint gtr. is a loud exhaust for sure, but not "drone" as such thankfully! (have had that before, drove me nuts)
and no heat problem noticed.. as yet anyways.
is more just engine and general road noise really. (not tyres... i think)
i know these cars are supposed to be loud/fun, but i love cruising to music, and as it is it would have to blaring.
i don't have underlay and only have thin carpet. a bad combo for a start obviously.
so am going to go whole hog while dealing with it.
#1089 _livo74_
_livo74_
Posted 27 February 2018 - 10:41 PM
tried posting in "part for sale" in case any else was searching for old school mag "hotwire centre caps" hot wire  wheel center caps, but system wouldn't let me, so am just posting here. may be of help to someone
he has decals too. and thousands of caps. most new. and CHEAP!
https://www.gumtree....aps-/1175946101
edit: he didn't have the specific decals i wanted
this guy did
$4 each
https://www.gumtree....adId=1072084659
Edited by livo74, 01 March 2018 - 01:57 PM.
#1090 _livo74_
_livo74_
Posted 10 March 2018 - 12:01 PM
decals stuck on,
Attached File  IMG_3805.JPG   184.21K   4 downloads
and fitted
Attached File  IMG_3814.JPG   115.49K   6 downloads
very little being done, as money diverted elsewhere
#1091 gtrboyy
Posted 10 March 2018 - 03:09 PM
Oh man that butt has come done one day to sit level with front...or add fluffy dice then always wear ugg boots + flanno for the full 70's effect haha
It's come a long way dude.
#1092 _livo74_
_livo74_
Posted 10 March 2018 - 03:31 PM
and studded green army jacket with iron maiden patch, for full effect! lol ;)
dheers gtr, almost a finished product! unfrigginbelievable!
i don't want the rear as low as the front, as is preferred stance for my car
..so don't know what springs to JUST drop an inch.. but still be higher than front.
as suspect?? it has "standard" in rear..
and so mounting "lowered"(lovells, like the front) will take it too far
"cutting" am trying to steer clear of
(ive... done enough of that already hahaha)
Edited by livo74, 10 March 2018 - 03:34 PM.
#1093 Bigfella237
Posted 10 March 2018 - 03:43 PM
A full tank of fuel would be close to 50kgs, plus a spare wheel, jack and tools probably another 10kgs... that's gotta be good for at least an extra inch in the rear?
Plus you usually find suspension "settles" down a bit once you do a few miles, but the front is likely to settle more so that's only gonna make things worse.
I don't mind it so much myself anyway, old skool car, old skool look!
#1094 _livo74_
_livo74_
Posted 10 March 2018 - 03:49 PM
then a full tank of fuel, plus a spare wheel, jack and tools etc it is! cheap ..and slack, perfect!!
(fuel is almost on empty, and has NONE of that in boot)
love the look myself, and it's hopefully just hilarious/fun for people to see driving around (WITHOUT looking like a "joke".)
that's the aim, anyways!
am heckishly biased, but in person it's friggin grouse, a hoot
(though, barely done any miles, so front settling might force hand)
Edited by livo74, 10 March 2018 - 03:50 PM.
#1095 gtrboyy
Posted 10 March 2018 - 06:23 PM
If it comes down 2" with full fuel tank etc so that not much tyre gap left in flare it will look heaps better.
Should be able to find some that resets springs...basically when it's at full weight everything settled measure how far want to drop it they'll heat it up & compress them..afterwards heat treat/temper the springs all done was maybe $80 last time had it done.
I actually like lowered L34 or A9X look with tiny GTS rims which most can't stand haha
Edited by gtrboyy, 10 March 2018 - 06:26 PM.
#1096 _livo74_
_livo74_
Posted 10 March 2018 - 08:20 PM
hope not 2 inches! there goes the bulk of my outrageous look hahaha
resetting springs may still become necessary, i'll put in fuel etc asap and measure/post results
..and i'm in the opposing team in regards to skinny tiny original rims
heck... i'm complaining about my 14x8" rears! ;)
#1097 _livo74_
_livo74_
Posted 14 July 2018 - 11:50 AM
nothing to report, sadly.
as got to drive her to and from mechanics a few times (and got to take my dad with me for a cruise!)..
have been able to chill and put her on the backburner while spending money on daughter and a few things for myself.
still need... rear trans seal replaced, windscreen wipers which i don't have, underlay and sound proofing, an aerial and stereo... and probably ten other things i cant think of right now
here's some pics since have put a tyre and jack in boot, and half a tank of gas.
lousy to show difference made, but came down 2 cm so far
Attached File  IMG_4267.JPG   156.3K   9 downloads
Attached File  IMG_4272.JPG   156.52K   9 downloads
oh, and haven't got off arse to clean up the mags yet andrew. still a "weathered grey"!
Edited by livo74, 14 July 2018 - 11:51 AM.
#1098 _LS1 Taxi_
_LS1 Taxi_
Posted 11 August 2018 - 06:10 PM
Car looks terrific fella :)
#1099 _livo74_
_livo74_
Posted 11 August 2018 - 07:12 PM
Cheers Daz. been a great experience.
Slight mega change of plans.
have always intended to fluke coming up with the money for 15 inch replica hotwires.
but, as they aren't quite right, i think. (wider/thicker "wire", and odd flat flared? section, mainly on the rear)
..am considering the 15" challengers.
Attached File  a performance challenger hotwire wheels_n.jpg   204.98K   11 downloads
bit cheaper too! $1400 a set, as opposed to $2000 for thew hotwires
Edited by livo74, 11 August 2018 - 07:21 PM.
#1100 Rockoz
Posted 12 August 2018 - 10:11 AM
Nothing wrong with the challengers.
Look a bit like some of the race rims from back in the day.
And to be honest, hotwires while they look great, are done by way too many people.
Dare to be a little different.
