LC Engine Options
145 replies to this topic
#26 dattoman
Posted 29 March 2016 - 08:23 PM
253
fine spline axles and the right ratio diff
Once its all set and rego put a small snail on it for abit more whizz
#27 gtrboyy
I'm against exploding bango's simply due to fact that you'll never fully enjoy modded baby torrie unless you get that rear end stepping out...it's a natural occurence imho
Simplest conversion to get engineered
253 or 308/trimatic or m21,use hq or lh/x mounts,standand tailshaft,diff,speedo cable etc
exhaust is combination of kingy header & early commo header
hq radiator & shroud,use plastic flexi fan
Only real aftermarket item to buy willl lc-j v8 sump,small dissy cap & rotor
Rest of other stuff bolts on or mod slightly...over time can pick up all that stuff cheap as chips especially if you do all labour.
*complete 253/trimatic or m21 with quaddie be easiest & cheapest starting point..wait your time they go that cheap nearly get given away.
Edited by gtrboyy, 29 March 2016 - 08:24 PM.
#28 _Bomber Watson_
Posted 29 March 2016 - 08:28 PM
I fail to understand how you cant understand that you cant get a 308/5lt engineered in QLD without a massive headfrOck....
#29 Ice
Posted 29 March 2016 - 08:31 PM
Read budget 8 k wont happen with a V8 conversion
#30 gtrboyy
Posted 29 March 2016 - 09:08 PM
Just because it's said to be a headf*ck does not mean impossible nor does it mean it has to be a '5ltr' can be 253,283 f*ck knows what can be passed untill you try.
Several dudes on here s.a,vic & nsw got v8 cars passed when peeps here comment 'cant be done blah blah' if Lc69 is seriously keen to do it the onus is on him to do the homework & get approval.
If you cant do v8 conversion with engineers in baby torana under 8k made out of junker 2nd hand parts & doing majority of labour yourself then they'd have problems with a mild 202...give up now,leave 161 in it & close roller door or move to another state.
#31 Ice
Posted 29 March 2016 - 09:20 PM
NCOP in QLD and W.A. wont allow 5 litres in LC LJ Torana
whats hard to comprehend about that
#32 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 29 March 2016 - 09:25 PM
That's my understanding but I haven't actually asked around.
It sounds like there may be some ways around it, but it might start to venture into the "to hard" basket.
A simple 253 would keep my happy and tick the boxes.
Obviously a lot of dead weight compared to a 308, but not a big issue for the purposes of what I'm trying to achieve.
#33 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 29 March 2016 - 09:33 PM
Banjo is fine spline (although I have never personally checked).
Currently an auto, so not sure on ratio.
Changing the diff is going to add to the engineering list, so I might try and avoid that.....until it brakes maybe...
Maybe I should follow natural progression......
1/ Build a 6, bolt to existing auto.
2/ Manual conversion....could always change input shaft for V8 later?
3/ Drive and consider what's next.
#34 Ice
Posted 29 March 2016 - 09:34 PM
Bingo do it and enjoy it
#35 _Bomber Watson_
Posted 29 March 2016 - 09:39 PM
Correct. The NCOP is a guildeline, you can engineer things that are outside of these guideliens.
You will spend a lot closer to 30k by the time its legal though.
There are still a few dodgy engineers signing them off here, but alas if you have an accident or the like regardless of what paperwork you can show your CTP is null and void etc etc....
Not worth it.
#36 S pack
Posted 29 March 2016 - 10:41 PM
Were you told it is a fine spline Banjo by the previous owner? The std banjo for an LC trimatic is 2.78:1 ratio and course spline.
#37 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 30 March 2016 - 06:48 PM
I Was.
Hasn't been high on my radar to check because the plan has always been to remove the axels and do a rear disk upgrade.
I Figured I would find out sooner than later.
Although, a few course spline axels have come up for sale with stud patron already changed.
I really should try and find some time to check.
#38 _Skapinad_
Posted 30 March 2016 - 07:38 PM
One of my favourites
frOck that is cool... Love that sound.
#39 _Skapinad_
Posted 30 March 2016 - 07:48 PM
Not worth it.
How is your CTP null and void ever ?
#40 FNQ
FNQ
  • 118 posts
  • Name:Darryl
  • Car:lc
Posted 30 March 2016 - 07:52 PM
forgive my ignorance, but did any LC's come out with a 202?  I know it is basically the same car as lj, - where a blue, or possible black 202 is doable without engineering or mod plate ??  i am in QLD and was under the impression some form of mod plate ( minor)? was needed for an lc above 186 (technically)   a while ago i went hunting in the regs but couldn't find what i was looking for.... so info about what is allowed/ doable / required would be good for me.also
i gather if say the blue motor came with emissions stuff ,then again technically it should retain that if transplanted in an lc or lj?  ( mods feel free to split if this is invading the OPs train of thought)
#41 Ice
Posted 30 March 2016 - 07:58 PM
No they didnt
Come out with 202 LCs
#42 _Bomber Watson_
Posted 30 March 2016 - 07:59 PM
Under the NCOP your allowed to fit any engine size fitted within the family. LC and LJ are classified as a family, so 202's are ok.
You are correct that technically a blue or black 3.3 or 2.8 should retain all of its emissions gear to be legal, but no one does that :P
#43 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 30 March 2016 - 08:19 PM
I'll just paint it red, ha ha
#44 r2160
r2160
  • 712 posts
  • Name:Glenn
Posted 30 March 2016 - 08:46 PM
The largest engine released in the LC 4 door range was a 173. The largest engine released in the LC 2 door range was the 186 in the XU1
#45 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 30 March 2016 - 08:52 PM
Surely I don't need to engineer a 202. That would just be crazy.
#46 _Bomber Watson_
Posted 30 March 2016 - 08:53 PM
I give up.
Read the NCOP yourselves.
Lc69, your fine.
#47 Ice
Posted 30 March 2016 - 10:48 PM
I give up.
Lc69, your fine.
Hahahaha
#48 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 30 March 2016 - 11:00 PM
So would a virgin black 202 be the best place to start?
#49 Ice
Posted 30 March 2016 - 11:02 PM
Yes Yes yes
#50 _ljxu1torana_
_ljxu1torana_
Posted 31 March 2016 - 12:17 AM
No they didnt
the lc 6 cylinder only came out with the 161.173.186.
