LX Hatch Complete Restoration
484 replies to this topic
#451 FLY_LX
FLY_LX
  • 198 posts
  • Car:LX sedan
Posted 19 November 2024 - 06:29 PM
nice job, well done. sure looks sweet
#452 Hatchback13
Hatchback13
  • 193 posts
Posted 19 November 2024 - 09:16 PM
Looks fantastic, good luck with the engineering and look forward to seeing it, probably at a coffee and chrome. Cheers
#453 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 20 November 2024 - 12:22 PM
Thanks with the Engineering
Regards Mando.
Edited by jeffblanco, 20 November 2024 - 12:23 PM.
#454 Hatchback13
Hatchback13
  • 193 posts
Posted 05 December 2024 - 08:15 PM
Hi Mando, how did you go with your engineering at the bend? Any pictures of the day? Cheers
#455 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 07 December 2024 - 10:05 AM
Hi Brad,
had the tow truck on the street ready to start the car just as the clutch would  pedal all the way up pushed when the stalled.
I turned up the motor about 5 times with the stalled each time.
The electrical thinks there is an earth that's not 100% touching.
I have started up every other time since with the clutch effected.
Luck the tow truck wasn't loading would have cost $750 cost.
Regards Mando.
#456 Shiney005
Posted 11 December 2024 - 08:06 AM
Bugger. Get it sorted and then get it done. It will be so worth it on the day you drive out with plates on it.
#457 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 14 March 2025 - 01:26 PM
Hi Guy's,
I want get to do the rego replace the gasket in to the sump, I don't know but my sump oil leaks.
I have a stand under the bell house and put a stand under the K frame.
I am hoping the out riggers will turn around when the four bolts will slip under the chassis.
I have down so down......
made up some brackets bolted through the extractors.
loose bolts under out rigger
oil engine
power and steering
brake fluid
steering uni
bolts engine brackets
.Attached File  IMG_2168.jpeg   355.72K   4 downloads
Attached File  IMG_2169.jpeg   355.93K   4 downloads
Attached File  IMG_2170.jpeg   359.69K   5 downloads
Attached File  IMG_2171.jpeg   310.87K   5 downloads
Regards.
#458 Hatchback13
Hatchback13
  • 193 posts
Posted 14 March 2025 - 09:23 PM
Wow , so close now Mando, the little things are frustrating so close to the end but it’s all worth it. Still looking forward to seeing it. Cheers
#459 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 14 March 2025 - 09:47 PM
Hi Brad,
what a disaster.
Regards.
#460 Shiney005
Posted 17 March 2025 - 07:13 PM
Oh no Mando. What a bastard!  Nice work with the engine lifter. Never seen anything like that before.
#461 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 17 March 2025 - 08:19 PM
Hi Laurie,
that's if the weight of the engine might lifter the guards up dent's.
Regards.
#462 SmacT
  • 1,026 posts
Posted 18 March 2025 - 09:21 AM
I'm no expert Mando, but I am wondering if it's too big a risk supporting an engine with that section of the guards/engine bay... I can see the gearbox crossmember would take some of the weight off the whole lot, but yeah, there's not much more than sheet metal in that area and the guards aren't flat. Can you support the main brace off the ground instead? Or pop off the bonnet and support the engine from above with an engine crane or the like? I'd hate to see those beautiful panels rippled up - happy to be wrong, but I can't not say something. :-)
#463 RallyRed
Posted 18 March 2025 - 09:46 AM
Have done similar with a 202 a few times, no dramas. Rags, cardboard and little timber spacers ( not as nice a set up as Mando's, but did the job). I think that area of the guards has enough folds and welds to make it quite strong.
That said, our paintwork isn't as nice as that Hatch's!
#464 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 18 March 2025 - 03:37 PM
Sam,
I am going to put a prop under the bell housing.
The only way I can think is to remove the belt, pulley and  harmonic and a use a longer bolt use another prop.
My mechanic  "SHOULD" be work.
Col used is exactly what you did.
I hope will weight the motor being all aluminium.
Regards.
#465 Bruiser
Bruiser
  • 881 posts
  • Name:Bruce
Posted 18 March 2025 - 04:40 PM
I don’t like the risking all the weight on the guard lips thing either
I ripped the sump off my engine while in the car (only a 202, though)
Jacked it up with a big flat hunk of wood under the sump, and
jammed a pair of strong (and safe) big enough bits of wood
in the engine mount gap then lowered it back down
#466 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 18 March 2025 - 05:22 PM
I might be able to used the timbers if I have some space.
I will see what I can do.
Regards.
#467 SmacT
  • 1,026 posts
Posted 18 March 2025 - 06:35 PM
Yeah agreed it could totally work, but on a car the level of this one, I reckon supporting the weight with something other than the guards/engine bay is worth doing, to take out the maybes. Just my opinion of course.
Supporting the bellhousing as you mentioned is defo a great option and should be enough. It's just the "should" bit. 😬
#468 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 18 March 2025 - 07:38 PM
I bolted some plates to the front of the engine that rested on my front sway bar bracket then when I had the cross member completely out I put jack stands under the sway bar  bracket.
Attached File  P1140160.JPG   164.1K   4 downloads
Attached File  P1140162.JPG   158.1K   4 downloads
#469 Bruiser
Bruiser
  • 881 posts
  • Name:Bruce
Posted 18 March 2025 - 08:38 PM
Nice idea
#470 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 18 March 2025 - 09:23 PM
Hi Bruce,
looks like you got it done lucky.
I wasn't looking the winch at the tow truck that used the sway bar bent up the brackets, all he needed was to do use the lower arms.
I'm not touching the bar or brackets.
I'm still not damaging the guards unless I longer the bolt into the harmonic.
Regards.
#471 rexy
  • 3,834 posts
Posted 19 March 2025 - 12:53 PM
I have taken the sump off the holden V8 in the old LX sedan a few times.
Jacked the car up and used stands. Then supported the gearbox with a jack and the harmonic balancer with a wooden block on a jack.
Dropped the K frame a little by loosening the 4 big bolts that go through the front rails.
Jack the engine and gearbox up enough to touch the top of the trans tunnel.
This was plenty of room to get the job done, even with the High Energy sump it had on it.
#472 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 19 March 2025 - 06:09 PM
Hi Rexy,
after you loosening the 4 big bolts and the K frame starts  to low.
Did your riggers are still bolted and the frame begins angle get's enough room get the sump .
Regards.
#473 rexy
  • 3,834 posts
Posted 19 March 2025 - 08:24 PM
Yes, leave the back two bolts in.
#474 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 11 April 2025 - 08:22 PM
Hi Guy's,
the mate has removed the K frame and the sump.
He has done a great job without damage so far.
We will see the crane is removed see what the guards look like.
Attached File  IMG_2225.jpeg   282.5K   7 downloads
Attached File  IMG_2226.jpeg   352.59K   3 downloads
Attached File  IMG_2227.jpeg   89.83K   3 downloads
Attached File  IMG_2231.jpeg   309.94K   6 downloads
Attached File  IMG_2229.jpeg   360.58K   4 downloads
Mando.
#475 Indy Orange
Indy Orange
  • 2,987 posts
Posted 11 April 2025 - 09:59 PM
Geez so clean ,looks like a operating theatre.
