Great job and agree so clean, awesome set up. Keep up the work. Cheers
LX Hatch Complete Restoration
#476
Posted 12 April 2025 - 10:38 PM
#477
Posted 16 April 2025 - 09:00 PM
#478
Posted 17 April 2025 - 02:21 PM
Sam,
I am going to put a prop under the bell housing.
The only way I can think is to remove the belt, pulley and harmonic and a use a longer bolt use another prop.
My mechanic "SHOULD" be work.
Col used is exactly what you did.
I hope will weight the motor being all aluminium.
Regards.
Thanks for all the different ways to try support the engine.
I was told a few guy's not to touch the harmonic balancer or pulley or using the bolt in the harmonic.
Regards.
#479
Posted 09 July 2025 - 07:12 AM
Hi Mando,
I have a drop tank like yours (Brown davis), Does your filler neck has a vent hole connecting to one of the back 3 fuel tank vents?
I am now in a process plumbing the hoses. Thanks in advance.
Regards,
Joe.
#480
Posted 12 July 2025 - 02:40 PM
Hi Joe,
I have 3 tubes into the back of the tank but there is no tube into the filler neck.
Regards..
#481
Posted 21 January 2026 - 09:16 PM
Hi Mando, how’s the hatchback going? Do you have it registered yet and are you out cruising? Still keeping an eye out at one of the many coffee and chromes. Cheers
#482
Posted 23 January 2026 - 10:25 PM
Hi Brad,
how are you going.
Did you get to the GMH car show at Glenelg at the Reserve.
I've been driving the car on a permit so far going around up to Glenelg and to Mt Barker.
I cancelled the engineer on November but it should go at AIR on Wakefield Rd Virginia providing the temps no more than up to 30 degrees.
Let me know if you want to stop in one of the day's
Regards Mando.
#483
Posted 25 January 2026 - 08:49 AM
Go back to post 409 and re read what you wrote that day, and in the months afterwards Mando. Anybody reading this page now wouldn't even know how badly scrambled up you were back then. I don't know if you have made a full recovery, but I am glad you are sounding like you are back to your old self.
#484
Posted 27 January 2026 - 09:23 PM
Glad you’ve got it out on the road at least, when are you heading to AIR? Does that mean you don’t need an engineer now or you just put it off for now? Agree with Laurie too, glad you’re sounding a lot better. Cheers
#485
Posted Yesterday, 10:17 PM
Thanks Brad,
the engineer will give me a day.
I hope on a hot day.
Regards Mando.
