LX Hatch Complete Restoration
484 replies to this topic
#176 Bigfella237
Posted 24 March 2021 - 01:36 PM
I hate it when you guy's give me answers that are not what I want to here.
You guy's cause me more grief than when I had a wife.
Just for once can't you guy's bull$hit to me, and tell me it will all be fine, go ahead and do it your way.
Kindest Regards Mando.
Yes dear, whatever you say dear. It will all be fine, go ahead and do it your way. :D
But seriously, if getting an exhaust made, I'd suggest having a bung welded in both sides and just plug up the one you don't use.
That way it's easy to add a second oxygen sensor later if your tuner changes his mind!
Edited by Bigfella237, 24 March 2021 - 01:37 PM.
#177 gtrboyy
Posted 24 March 2021 - 04:19 PM
Most of early Ls had two 02 sensors..not necessary if aftermarket ecu but still damn handy if want to fit a/f gauge or swap banks to check all is kosher.
As above stated want slipons sealed so it doesn't fudge 02 readings.
#178 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 24 March 2021 - 06:38 PM
Thanks guy's,
thats a brilliant idea.
I'll install two bungs on the cats but use only one O2 sensor and add another one if necessary.
This is like being married again.
Regards Mando.
#179 Heath
Posted 29 March 2021 - 09:28 AM
You could possibly tune it in one side, then swap it to the other side and see if there's any significant difference?
Not every system would have an input for two O2 sensors.
#180 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 29 March 2021 - 07:17 PM
I didn't know that would even be possible, thanks for the tip.
I'll point it out to the tuner when the time comes.
Regards Mando.
#181 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 11 April 2021 - 12:39 PM
Hi Guy's,
can anyone let me know where the bump stops go on the diff of an LX please?
There is a flat section on the body with 3 or four screw holes directly above the diff housing.
Is this for some type of bump stop, and if not what's it for?
Regards Mando.
#182 Bigfella237
Posted 11 April 2021 - 02:00 PM
The bump stops are inside each coil spring (No. 7 on the following diagram)...
If you're talking about a mounting plate in the centre of the car above the diff pinion then I'd guess it's for the illusive pinion bumper (see "A" inset above, item No 14).
EDIT: Also see this thread: http://www.gmh-toran...rana-diff-bump/
Edited by Bigfella237, 11 April 2021 - 02:02 PM.
#183 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 11 April 2021 - 08:39 PM
Thanks Andrew,
I'll see if Rare Spares sell the number 7 bump stops.
Being a different diff setup, I reckon it would be hit and miss to get
the rubber the right length to make it work properly.
Regards Mando.
#184 Heath
Posted 12 April 2021 - 09:29 AM
It's quite likely you can source the third "A" bump stop and trim it down if needed, to suit the nose area of your diff pumpkin. I may even have one spare... but I would need to check that out.
There should be a piece of sheetmetal with two captive nuts in it, to secure that bump stop.
Attached File  2016-04-10 13.04.12.jpg   365.65K   21 downloads
Nothing with 3-4 holes that I have ever seen.
The normal bump stops can be sourced from Superpro apparently:
https://www.ebay.com...GIAAOSw9fFf83oz
Or you can get your hands on an original pair and cut them down etc.
#185 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 12 April 2021 - 02:44 PM
Attached File  IMG_0609.jpg   236.25K   16 downloads
Attached File  IMG_0610.jpg   160.47K   15 downloads
Thank's Heath,
I've ordered a couple of the blue bump stops.
Thank's for the offer to look for the bump stop on the metal plate.
I'll take a look through my left over pile and see if I have one for the [diff pumpkin] as you describe it.
I took a look at my body and I do have three holes. Two are threaded, for the bumper stop and the other is just a hole.
Regards Mando.
#186 Shiney005
Posted 13 April 2021 - 10:24 PM
What model and build date is the car Mando?
#187 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 14 April 2021 - 09:47 AM
Hi Laurie,
one of my plate has January 78 on it and the other plate has LX8UH77 on it.
It started life as a 4or 6 cylinder SL as far as I know.
It was first purchased in September 1978.
Regards Mando.
#188 Shiney005
Posted 14 April 2021 - 12:05 PM
4 cylinder LX Sunbudgie. It is now becoming the automotive equivalent to The Six Million Dollar Man.
#189 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 20 April 2021 - 06:08 PM
Very clean build, loving it. Can you please share what accessory drive kit you have on the front of your engine?
#190 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 21 April 2021 - 04:41 PM
The drive system comes from Drive Junky in California.
Regards Mando.
#191 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 21 April 2021 - 10:38 PM
Thanks for that mate, did you buy direct from Drive Junky or through anyone local? I hadn't heard of them before but I prefer it to the Holley offering, especially the the balancer.
#192 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 22 April 2021 - 12:00 PM
I bought it directly from Drive Junky and they shipped it to Long Beach where it was loaded into a container with a hundred other parts bought from  all over the states,
and then shipped to Adelaide by a guy that brings over Mustang cars and parts.
He charged me a flat rate for as many parts I could get to his shipping yard.
The guy I dealt with at Drive Junky was fantastic, and the quality of everything supplied including the machined brackets was first rate.
The list was long but some of the parts sent over were
crate motor
valley cover
rocker covers
engine manifold
handbrake cables
radiator
thermo fans
fuel filters
air cleaner
and a heap more.
Regards Mando.
#193 Bigfella237
Posted 22 April 2021 - 01:33 PM
G'day Mando, was that Jeff or someone else who shipped your parts?
And does he ship to other cities as well (Sydney for example)?
If our exchange rate keeps going up I may need to bring over one of those 'crates' myself. :D
#194 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 22 April 2021 - 06:23 PM
Hi Andrew,
I think he only did it to fill up containers coming to Adelaide but give him a call, you never know.
Mustang and Australian Classics
08  83239008
Regards Mando.
#195 Heath
Posted 23 April 2021 - 08:58 AM
East Coast Mustang & Camaro in Lilydale VIC offer the same service BTW. Great for Melbournians.
#196 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 15 May 2021 - 09:23 AM
Hi Guy's,
more progress.
Attached File  IMG_0639.jpg   309.09K   9 downloads
Attached File  IMG_0640.jpg   317.2K   8 downloads
Attached File  IMG_0641.jpg   290.85K   8 downloads
Attached File  IMG_0642.jpg   327.66K   9 downloads
Attached File  IMG_0658.jpg   305.63K   10 downloads
Attached File  IMG_0659.jpg   313.33K   10 downloads
Attached File  IMG_0660.jpg   305.49K   11 downloads
Attached File  IMG_0661.jpg   255.83K   13 downloads
Attached File  IMG_0662.jpg   289.12K   11 downloads
Attached File  IMG_0663.jpg   235.8K   14 downloads
Attached File  IMG_0664.jpg   235.33K   13 downloads
Attached File  IMG_0665.jpg   249.24K   11 downloads
Attached File  IMG_0666.jpg   250.97K   9 downloads
Regards Mando.
#197 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 15 May 2021 - 09:35 AM
Looks great Mando, well done on the progress. I like that floor reflection in the shiny mufflers.
Did that Dellows cross member come with the holes drilled for the gearbox mount? On their website they look blank in the middle
Cheers, Tom
#198 Bigfella237
Posted 15 May 2021 - 11:20 AM
That exhaust is pure car porn!
So close now... I bet you can't wait to get out and drive it.
#199 Hatchback13
Hatchback13
  • 193 posts
Posted 15 May 2021 - 02:16 PM
Wow that looks fantastic, may I ask where u got your drop tank from? It looks very compact and clean. Look forward to seeing a pic on the road. Cheers.
#200 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 15 May 2021 - 06:07 PM
Thanks guy's,
Tom, the crossmember had holes in place for the gearbox, but they needed to be slotted sideways.
Brad the tank came from Brown Davis. They did a fantastic job. The welding is amazing.
The tank is 90 litres and not 120 litres as you would see on the Bathurst cars.
The 120 litre tank hangs down to low to get past registration.
Andrew, I can't see this thing on the road for ages.
The biggest hurdle for me is getting the air conditioning plumbed up and getting the computer setup for the LS3,
and having to pass the car through registration, in what we call Regency Park.
Regards Mando.
