The Sally Report
1003 replies to this topic
#426 sibhs
Posted 12 January 2021 - 09:08 PM
This is the last time I plan on sand blasting in the room so I'm doing the bonnet and a few other big bits.
The Bonnet looked like it had a light black primer on it but it wasn't easy to get off.
First the catch was removed by lightly drilling out the end of burred over pin. I'll re fit with a rivet in the end to keep it close to original looking.
Attached File  IMG_3643.jpeg   76.84K   14 downloads
Attached File  IMG_3644.jpeg   46.7K   10 downloads
Attached File  IMG_3645.jpeg   34.93K   12 downloads
Attached File  IMG_3646.jpeg   59.57K   12 downloads
Attached File  IMG_3647.jpeg   81.8K   11 downloads
First round of paint stripper.
Attached File  IMG_3648.jpeg   65.96K   12 downloads
Attached File  IMG_3649.jpeg   105.5K   11 downloads
Attached File  IMG_3650.jpeg   52.14K   11 downloads
Attached File  IMG_3651.jpeg   92.07K   10 downloads
Attached File  IMG_3652.jpeg   47.29K   10 downloads
Attached File  IMG_3717.jpeg   88.57K   10 downloads
Attached File  IMG_3735.jpeg   60.65K   12 downloads
Attached File  IMG_3737.jpeg   39.96K   11 downloads
Attached File  IMG_3738.jpeg   61.77K   11 downloads
I don't look happy but that could just be the last time I blast in the room, ye-haaaa.
Attached File  IMG_3770.jpeg   88.51K   11 downloads
#427 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 13 January 2021 - 11:52 AM
Looking great Marty.
I think your crazy hahaa.
Just a quick one how do you go with the tips for the sand blaster?
You have replacements? How long they last for you?
The one I brought all my tips have expanded and it runs shit house now and they don't make replacement tips for it at Sydney tools.
#428 sibhs
Posted 13 January 2021 - 04:29 PM
Great question Mitch.
The blaster came with 4 tips, 2 large orifice and 2 smaller.
First thing that went was the on/off tap at the end of the hose. I was trying to reduce the airflow to make every thing last longer so the tap was only on half way. This caused the valve to be blasted away in a very short time. Purchased two new taps.
Then I dropped the hand piece and busted one of the larger tips. Fitted the last big tip. That wore out after a good few sessions. Fitted a smaller tip which blocked frequently until I went to finer grit. That tip wore out after a few good sessions. I'm now on my last tip and I have the worn out sample in the car as I hunt for more.  I also blew through the hose where it joins the machine about three times, each time cutting the hose shorter to fix. I also wore out another tap and am on my last one.
I was told you can make a really long lasting tip out of a spark plug white section. Sounded a bit involved though.
I keep using worn tips and it becomes a waste of sand and effort, once I fit a new tip it's like Wow! this is better.
#429 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 13 January 2021 - 10:42 PM
Yeah mate ive had the same issue with mine.
The sand blaster only cost me around $200 bucks.
Now I cant get any replacement tips. Sydney tools have the upgraded model now. It has a different gun end so the tips aren't interchangeable. They won't just sell me the replacement gun and tips for that either have to buy the whole machine again which is stupid.
My mechanic/gear guy said he can lathe me up one from brass or metal but reckons it won't last long either and 100 bucks for a tip no thanks.
I can't source any replacement handles or gun ends for it anywhere and the industrial places the guns are crazy expensive and shit for the little machine anyways.
Going to have to throw it out if I can't get any tips. Seems a waste as its a good little machine but I dunno where to go from here.
I've only blasted the k frame, diff and suspension parts and all my tips are gone.
I wanted to do the hinges small parts etc but I have given up and just been using paint stripper and wire brush attachments
Spewing.
#430 warrenm
Posted 14 January 2021 - 05:54 AM
What do the tips look like?
#431 claysummers
Posted 14 January 2021 - 06:15 AM
My sand blaster consists of a $30 gun, bucket of dried sand and 13cfm compressor. Compressor can't keep up, but I only use it in tight spots. Otherwise it works a treat.
#432 sibhs
Posted 14 January 2021 - 08:25 AM
Hi Warren, the ones on my machine look like the white section of a spark plug. Long thin going from about 15mm wide to 10mm wide at the tip. These are used on the ball valve style gun.
There is another style used on the dead mans gun which is bigger and pink in colour, these are easier to find.
#433 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 14 January 2021 - 10:16 AM
These are the tips for my one.
They are ceramic I think.
The 3mm worked the best but they just go to shit so fast its not funny
Any ideas on replacements would be great hahad925edb311183366e7d7c4d95981110c.jpg82d40e107dc122e4157496c13b346dea.jpg16abdc6a44be9dd8a1a94ae91c23ebdd.jpgd30e8d93644e99bc7063a79737a04bbb.jpg
#434 Rockoz
Posted 14 January 2021 - 02:48 PM
Anyone thought about going to a pottery craft place and see if they fire ceramics as well?
Looks like it would be an easy enough design to replicate then get fired.
#435 sibhs
Posted 14 January 2021 - 10:22 PM
Finding 5 good rims has been a challenge. I bought 7 rusty dirty rims from one bloke and another 2 from someone else.
After having them in molasses, and sand blasting I've managed to find five acceptable rims.
There was a little bonus in amongst them as one cleaned up to be a Nibless 1973 rim.
Attached File  IMG_0038.jpeg   49.24K   9 downloads
Attached File  IMG_0039.jpeg   54.67K   11 downloads
Here's my five nibbed rims
Attached File  IMG_3740.jpeg   82.21K   11 downloads
I'm applying KBS to the internals to help prevent rusting.
Attached File  IMG_3779.jpeg   56.29K   9 downloads
Attached File  IMG_3780.jpeg   55.63K   10 downloads
Below are some molasses brewing pictures. Every so often you have to scoop out the crud that forms on the top.
Attached File  IMG_2310.jpeg   63.07K   9 downloads
Attached File  IMG_2409.jpeg   84.56K   10 downloads
Attached File  IMG_2410.jpeg   70.76K   10 downloads
Attached File  IMG_2483.jpeg   84.14K   10 downloads
Attached File  IMG_2703.jpeg   79.26K   10 downloads
#436 claysummers
Posted 14 January 2021 - 10:51 PM
You going to “de-nib” them Marty?
#437 claysummers
Posted 14 January 2021 - 10:53 PM
Thanks for the molasses shots. I bought 20L of it but haven’t tried it yet as I’ve been using citric acid.
#438 sibhs
Posted 14 January 2021 - 11:09 PM
Hi Clay, leaving them nibbed, that's how they were on the GTR's.
It's amazing stuff if you have the time.
#439 Ice
Posted 15 January 2021 - 01:04 AM
Had these in a molasses bath for 3 months prior to blasting and 2 K primer
came out a treat
#440 claysummers
Posted 15 January 2021 - 06:13 AM
Very nice. No one could call you impatient gene.
#441 Indy Orange
Indy Orange
  • 2,987 posts
Posted 15 January 2021 - 09:39 AM
Looks great , GTS rims look fantastic when painted up.
Edited by Indy Orange, 15 January 2021 - 09:39 AM.
#442 sibhs
Posted 15 January 2021 - 09:41 PM
The petrol tank looked really good inside, no visible rust just clean metal.
I wasn't going to put a fuel tank coating system in this like I did in the LJ but after sand blasting and getting it covered in dust I could notice pin holes of leakage. I had sprayed CRC in the tank months ago.
So my advice is check it for leaks or coat the insides to get rid of any pin holes even if it looks mint inside.
Attached File  IMG_3738 (1).jpeg   61.77K   13 downloads
Out with the used grit and in with the new
Attached File  IMG_3742.jpeg   46.58K   13 downloads
Attached File  IMG_3743.jpeg   52.3K   11 downloads
Attached File  IMG_3744.jpeg   41.77K   11 downloads
Attached File  IMG_3746.jpeg   40.02K   12 downloads
Attached File  IMG_3768.jpeg   50.31K   12 downloads
Attached File  IMG_3769.jpeg   61.27K   12 downloads
A couple of my favourite pics after I cleaned-up the garage and opened the garage door for the first time in a year.
Attached File  IMG_3774.jpeg   51.88K   14 downloads
Attached File  IMG_3775.jpeg   61.28K   12 downloads
#443 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 15 January 2021 - 09:49 PM
To me, the gts rally rims look best restored correctly, which means a low gloss looking clear, it does mean that you need to clean them more thoroughly though. Some of the original rims are oversprayed a bit in the corners though. No one really cared in the 70's. You might have to get on the doobies to mask them Geno !
#444 Ice
Posted 15 January 2021 - 10:09 PM
Looking good Marty
That sand gets everywhere for sure
Doobies don’t know about that Gary
You can buy a stencil kit
sorry about  the thread steal Marty
#445 sibhs
Posted 24 January 2021 - 09:39 PM
Scraped out the bits of sealer in the gutter to find some rust. These spikey tools came in handy.
Attached File  IMG_3781.jpeg   45.49K   11 downloads
Attached File  IMG_3782.jpeg   37.44K   11 downloads
Moving the reverse switch wiring hole to accommodate the Aussie 4 speed.  I noted that the hole sizes varies between the two wiring grommets. Opal 20mm Aussie 14mm
Attached File  IMG_3784.jpeg   39.48K   12 downloads
Taped in the new metal ready to weld.
Attached File  IMG_3785.jpeg   40.51K   11 downloads
Fitted the seat bolt retainer.
Attached File  IMG_3805.jpeg   76.54K   11 downloads
Attached File  IMG_3806.jpeg   54.62K   11 downloads
Attached File  IMG_3807.jpeg   47.14K   11 downloads
Attached File  IMG_3808.jpeg   61.32K   11 downloads
Attached File  IMG_3809.jpeg   74K   11 downloads
Attached File  IMG_3812.jpeg   51.25K   12 downloads
I was concerned about the centre console position due to factory screw holes not centered. I checked another car and it was the same, skewed to the drivers side.
Attached File  GIKM6883.jpeg   29.73K   11 downloads
Attached File  IMG_3811.jpeg   57.21K   12 downloads
#446 bat 53
bat 53
  • 527 posts
  • Name:albert
  • Car:lc gtr
Posted 25 January 2021 - 09:55 AM
does the consol seam to have a twist in it  :<_<:  :fool:
#447 sibhs
Posted 25 January 2021 - 05:05 PM
Hi Albert, yes the front is toward the pedals.  It looks offset to the shifter hole and I was worried it might be an Opal position. So I checked a friends LJ 72 and his factory screw holes are skewed to the pedal side.
#448 sibhs
Posted 25 January 2021 - 11:21 PM
Fully welded the tops of the guards and set about grinding them flat. Tek screwed them every inch then removed every second one, prepped the hole and plug welded. Then did the remaining screws and clamping joins first if it looked like it needed it.
Attached File  IMG_3819.jpeg   43.75K   11 downloads
Attached File  IMG_3820.jpeg   42.61K   12 downloads
Attached File  IMG_3821.jpeg   44.96K   12 downloads
Attached File  IMG_3870.jpeg   49.54K   14 downloads
#449 sibhs
Posted 26 January 2021 - 10:08 PM
Did a couple of things I wasn't planning on tackling.
Firstly the lower rear window sill look fairly solid. But after sand blasting I noticed it had been repaired roughly before. I've heard the repair panels are good so I made the call to replace it.
Attached File  IMG_3840.jpeg   43.54K   11 downloads
Attached File  IMG_3842.jpeg   36.3K   12 downloads
Attached File  IMG_3845.jpeg   42.8K   11 downloads
Attached File  IMG_3846.jpeg   46.18K   13 downloads
Attached File  IMG_3852.jpeg   54.42K   12 downloads
Then I decided to remove the sound deadening from the roof. This looked good and I like the original look it has but I'm glad I did because some of it came off very easily and there was rust below it. Only took about 20 mins to remove.
Attached File  IMG_3855.jpeg   47.73K   11 downloads
Attached File  IMG_3856.jpeg   65.76K   11 downloads
Attached File  IMG_3857.jpeg   51.67K   11 downloads
Attached File  IMG_3862.jpeg   73.67K   11 downloads
Attached File  IMG_3863.jpeg   71.12K   11 downloads
#450 rodomo
Posted 27 January 2021 - 12:38 AM
You are a Trojan  :spoton:
