The Sally Report
1003 replies to this topic
#451 sibhs
Posted 27 January 2021 - 10:41 PM
G'day,
I'm fully focused on getting the shell in etch primer. Just finished grinding all the welds flat. Used the 10mm belt grinder for all the bits that I couldn't get to with the angle grinder. Definitely go through the belt quickly but there's not much out there that can reach those tight little spots.
Attached File  IMG_3826.jpeg   55.79K   20 downloads
Attached File  IMG_3864.jpeg   58.35K   16 downloads
#452 claysummers
Posted 28 January 2021 - 06:11 AM
You shrunk yourself down to a leprechaun to get in those tight spots 8)
#453 sibhs
Posted 28 January 2021 - 10:29 PM
First round of Rust Blast is done. Spent a lot of time just focusing on seams and any rusty areas.
Attached File  IMG_3866.jpeg   76.58K   14 downloads
Attached File  IMG_3867.jpeg   67.26K   15 downloads
Attached File  IMG_3868.jpeg   64.91K   15 downloads
Attached File  IMG_3869.jpeg   66.67K   15 downloads
No need to shrink me any further thanks Clay.
#454 _2ELCS_
_2ELCS_
Posted 29 January 2021 - 04:15 AM
Good things come in small packages Marty.
Looking at what you are doing ALMOST makes me want to start another one...
I did say ALMOST ?....
#455 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 29 January 2021 - 02:14 PM
Rust blast is the best!
WINNING Marty!!
#456 sibhs
Posted 29 January 2021 - 09:06 PM
Now the metal is clean I can see bits of paint i'd missed so next was a bit of paint removal then another round of KBS Rust Blast.
Attached File  IMG_3872.jpeg   56.44K   9 downloads
Attached File  IMG_3873.jpeg   65.91K   10 downloads
Attached File  IMG_3874.jpeg   63.96K   11 downloads
Attached File  IMG_3875.jpeg   102.28K   11 downloads
Attached File  IMG_3876.jpeg   60.94K   11 downloads
Attached File  IMG_3877.jpeg   56.17K   12 downloads
This time I left the blast on too long and did too much scrubbing and flushing with water and the car turned gold.
I have a lot of confidence in Rust Blast but I was really hoping to get a picture of the shell in shiny bare metal so I made a few enquiries about other product like Oxi removers.
They all mentioned you must get it all off after, or neutralise with BiCarb otherwise it will keep eating away at the metal. You also had to get the etch on quickly after its dry.
This sounded all to risky to me so I've decided to re-apply KBS but this time following the instructions. With KBS you just hose it off and if you don't get it all off, no drama. You also have about 4 weeks to etch due to it leaving a zinc coating. The only down side I see with KBS is you never get beautiful shiny metal to admire. I'd rather a quality job rather than shiny metal.
#457 CYCO355
CYCO355
  • 152 posts
  • Name:Cameron
  • Car:G PAK and a LH sl, VS Senator, VE SSV sedan
Posted 30 January 2021 - 09:29 AM
When you do your next one maybe look into these
I want to keep mine bare metalled for as long as possible as I’m taking ages to repair it
#458 sibhs
Posted 30 January 2021 - 10:15 AM
Hi Cameron,
I've heard good things about EasyPhos. This product keeps metal shiny and ready for painting. I would of had to apply the AntiOx first and that's the product that needs neutralising or it keeps eating metal.
When ever a product says it needs neutralising it concerns me. What if I miss a bit?
I think if you know a product and you're comfortable with it, stick with it.
I do like the look of your shiny metal though.
#459 Rockoz
Posted 30 January 2021 - 10:28 AM
Hi Cameron,
Just keep throwing water at it if you are worried.
Eventually it gets diluted to neutral anyway.
And.
You will most likely be painting the area after it is treated.
That should seal it from the air, which means any oxidising should stop.
It needs oxygen to keep rusting away.
#460 CYCO355
CYCO355
  • 152 posts
  • Name:Cameron
Posted 30 January 2021 - 10:43 AM
Hi Cameron,
Cheers Marty, I look forward to your updates.
Yeah they do look good shiny.
#461 71xu1
71xu1
    Dave
  • 1,278 posts
  • Car:LC GTR XU1
Posted 30 January 2021 - 11:47 AM
When you do your next one maybe look into thesef3426c870e530338860f7444f6c2cf0a.jpg7c0c63f43def46cca970cac3da0a917d.jpg
Love this stuff.
#462 Rockoz
Posted 31 January 2021 - 03:06 PM
Cameron
When you look further into it, the companies that make the stuff and the high end shops that use it, recommend that once you get it to bare metal, you do a 2k etch prime as soon as possible.
Sorry for the long sentence.
Once the shell is stripped, it gets etched.
You might then need to do repairs.
Do the metal work to as close as you can to the required shape, then you etch over that bit of bare metal before going to using fillers, or hi fill primer.
If you have used bog to fine out the detail, you etch prime over that as your next step.
The idea is to have the metal and any repairs locked up with etch.
There are small cheap guns available on sites such as Wish that would be right for mixing small batches of etch and not waste any.
Ive bought quite a bit of stuff from various Wish suppliers, and havent had any real problems.
In fact they have given me Wish credit more than once when they detected something not quite right with transactions.
I think I have about a dozen guns now.
#463 CYCO355
CYCO355
  • 152 posts
  • Name:Cameron
Posted 31 January 2021 - 04:03 PM
Cameron
It’s been bare metal for over 4 months, no surface rust. I don’t want to etch it to leave it for months for the etch to absorb anything, then I’ll be rubbing it back again. At worst I’ll use their anti ox for any surface rust and redo the easyphos.
#464 sibhs
Posted 31 January 2021 - 07:47 PM
Applied the third lot of Rust Blast, this time following the instructions and a much better looking result.
Before
Attached File  IMG_3884.jpeg   55.33K   8 downloads
After
Attached File  IMG_3885.jpeg   55.9K   10 downloads
Attached File  IMG_3889.jpeg   60.2K   9 downloads
Then it was time to apply Rust Seal to all the welds and new panels and seams. Give you an idea of how much metal has been replaced.
Attached File  IMG_3892.jpeg   79.81K   10 downloads
Attached File  IMG_3904.jpeg   68.42K   10 downloads
Next it was time to rub back the Rust Seal and test my new big sanding block, this felt great and gives me confidence in getting  good flat panels.
Attached File  IMG_3906.jpeg   84.57K   9 downloads
About 10 hours spent sanding and then going over the whole car with a scourer. I would never advise Rust Seal as a final paint finish, even with its Top coat brand.  Great for stopping rust but it never looks as good as real paint.
Attached File  IMG_3917.jpeg   81.65K   9 downloads
Attached File  IMG_3927.jpeg   71.96K   12 downloads
#465 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 31 January 2021 - 08:30 PM
Durablock Marty ? Big blocks that you can get sand paper for would be fantastic.
#466 sibhs
Posted 31 January 2021 - 09:33 PM
Hi Gary, It's not a Durablock. Managed to find a place that sell sticky back rolls that match the width and just cut to length required. Has a gentle curve that flows nicely with the roof and big panels which will find any highs or lows.
#467 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 31 January 2021 - 09:55 PM
Would you mind sharing the brand mate ? Even just a pm is fine.
#468 sibhs
Posted 31 January 2021 - 10:11 PM
There you go Gary.
Bought an 80 and 120 grit roll
Attached File  IMG_3930.jpeg   55.62K   16 downloads
#469 sibhs
Posted 03 February 2021 - 09:34 PM
Time to do some repairs to the fuel tank.
Firstly I gave it a clean with KBS Aqua Kleen, but before that can happen I need to work out ways to block the holes.
For the fuel pickup hole I used an old seal and lock clamp and cut a round bit of metal.
Attached File  IMG_3933.jpeg   68.95K   10 downloads
The filler was blocked with an old gear knob wrapped in plastic.
Attached File  IMG_3934.jpeg   51.17K   9 downloads
Ad the hot water and Aqua Kleen.
Attached File  IMG_3938.jpeg   65.39K   10 downloads
Now that the tank definitely doesn't have fuel fumes in it I can use the dent puller.
Attached File  IMG_3936.jpeg   54.05K   9 downloads
Attached File  IMG_3937.jpeg   61.06K   10 downloads
Then the Rust Blast was applied inside and out, rinsed well and put in the sun to dry.
Attached File  IMG_3940.jpeg   125.57K   9 downloads
Once dry (next day) the Tank Seal is poured in and swished all over for 15 mins then drain the excess out.
Attached File  IMG_3942.jpeg   58.58K   8 downloads
Attached File  IMG_3943.jpeg   52.62K   8 downloads
Out of a 500ml tin only 200ml gets used and the rest has to be ditched. I decided to paint the outside of the seams to ad extra protection.
Attached File  IMG_3945.jpeg   44.69K   8 downloads
Attached File  IMG_3944.jpeg   47.12K   8 downloads
Then its masked up ready for etching soon.
Attached File  IMG_3947.jpeg   55.54K   8 downloads
#470 claysummers
Posted 04 February 2021 - 05:25 AM
Great work Marty. The tank sealer looks pretty thick. Thinners?
#471 _LONA-CK_
_LONA-CK_
Posted 04 February 2021 - 06:15 AM
Marty if your just looking for a neutralizeser just buy yourself some cheap old home brand white vinegar from Woolworths water down wipe on and off.
Cheers gong
#472 sibhs
Posted 04 February 2021 - 10:18 PM
Hi Clay, It's just right, thick enough to seal holes but thin enough to flow easily around the tank and pour out.
Cheers gong
Thanks Gong, it's just the fact you have to neutralise and the warnings I received about making sure you do or it keeps eating the metal.
I took the day off work today to get this shell in etch. Was planning on doing it this week-end but we're due a heap of rain and I've got to empty the garage to turn it into a paint booth.
Masked out the plenum to protect the Amethyst.
Attached File  IMG_3949.jpeg   60.07K   9 downloads
Garage all cleared out
Attached File  IMG_3950.jpeg   86.83K   10 downloads
Fitted the exhaust filter to the extractor fan.
Attached File  IMG_3951.jpeg   84.91K   8 downloads
Set-up the paint mixing station.
Attached File  IMG_3952.jpeg   96.04K   8 downloads
A bit of sanding and then wipe down the whole shell.
Attached File  IMG_3953.jpeg   56.28K   8 downloads
Get the PPE on.
Attached File  IMG_3954.jpeg   63.55K   9 downloads
These paint pourers have made a huge difference to my pouring and measuring while keeping the lids clean.
Attached File  IMG_3956.jpeg   86.23K   8 downloads
Etched pics to come later.
#473 claysummers
Posted 05 February 2021 - 09:41 AM
Epotec 408 grey green? Good stuff.
#474 Hatchback13
Hatchback13
  • 193 posts
Posted 05 February 2021 - 06:19 PM
Nice work there Marty, it’s a big effort getting a whole car in epoxy. I bet the shed turned green grey haha
I’m in the trade and haven’t seen those pourers, they look the business, always hard with a full tin haha. Clay I believe epotec to be a good product and a lot of restoration shops use it. PPG in general seams a common choice particularly with Aussie cars and colours, probably because they bought out dulux back in the day. Cheers
Edited by Hatchback13, 05 February 2021 - 06:20 PM.
#475 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 844 posts
  • Name:JASO
Posted 05 February 2021 - 06:58 PM
Hi Marty,
Thats GOLD, priority is Torana over work...to get the car in etch.
This build is a credit to both you and your wife. Engenious!!
