The Sally Report
1003 replies to this topic
#76 meanmachine72
meanmachine72
  • 2,050 posts
  • Name:Jono
Posted 07 September 2019 - 08:59 AM
great work marty..were did you get your dash pad done and price mate?..need mine to get so love
#77 Rockoz
Posted 07 September 2019 - 11:41 AM
Nice work on the cooler/drier.
With all the fittings, it may have been cheaper to buy a pipe bender.
I was think of something similar, but I was going to use a coil of pipe, and just tighten up the coils, trouble is I just dont have the room.
With just a single garage, and its only just a single, you couldnt open both doors of anything but a mighty boy in it, space is a premium.
Ive even resorted to having the Harley outside to get some room. Along with various lifting gear, stands and an old alloy V8.
Cant wait until I get a place of my own.
Primary decision on a new place will be a shed, or room to put one.
Couldnt care much less about a house. lol.
#78 sibhs
Posted 07 September 2019 - 11:53 AM
Our club sent off 4 dash's to the 'Dash Doctor' and it was $450 plus postage both ways which we split between us.  I'm so impressed at how well it came out, and it's definatley the one I sent them cause it still has my name on the back.
Hi Rob, I did consider the bender but I decided to get some experience in copper pipe soldering. I always try and learn something new or get more experience. It may cost me in dollars but in life experences it's worth it.
#79 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 08 September 2019 - 09:07 AM
Good stuff. Marty when you say you KBS all of your welds did you KBS them on the exterior panels of the car as well? Where they will be seen?
Then did you epoxy over all of it.
Edited by Mitchyboy, 08 September 2019 - 09:09 AM.
#80 sibhs
Posted 08 September 2019 - 08:02 PM
Yes all welding, even outer body.  You have to etch prime within a certain time while KBS is still tacky otherwise you'll have to scuff KBS at a later date.
It's amazing how the KBS will find a seal all the weld pin holes, something a spray etch wont do.
#81 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 08 September 2019 - 09:12 PM
Sweet.
I'm asking because I have done a few repairs to my back and front wind screen channels and I was thinking of applying the KBS system to my repairs. But as I am going to apply epoxy primer to the entire car I didn't know if I should or not as everything I have read says to apply the epoxy to bare metal.
Cheers mate
#82 sibhs
Posted 25 September 2019 - 10:57 PM
G'day all,
It's been a couple of weeks since last report.  Enjoyed my time at ToranaFest an amazing job done by The Hunter Vally Torana Club. Also great to catch-up with some of the members on here.
Fiddlin' around with bits and pieces on the car, I'll let the picture and captions explain it all.
The inner guard headlight bit was messed up from previous damage so that was replaced.
Attached File  IMG_8707.jpg   122.18K   15 downloads
Attached File  IMG_8711.jpg   103.63K   14 downloads
The front of the guard was swiss cheese after all the banging it back into shape so decided to cut it out and make a bit.
Attached File  IMG_8713.jpg   147K   14 downloads
Attached File  IMG_8715.jpg   167.22K   14 downloads
Attached File  IMG_8720.jpg   193.38K   16 downloads
Attached File  IMG_8723.jpg   122.2K   15 downloads
Attached File  IMG_8729.jpg   119.59K   17 downloads
After many on/offs of the guards I'm finally getting very close to a good fit. I want to check everything before I weld the windscreen cowl rust repairs in.
Attached File  IMG_8999.jpg   192.52K   17 downloads
Attached File  IMG_9001.jpg   191.19K   16 downloads
Decided to make up some dollys. Made a stand from a rusty GTR rim and tube.
Attached File  IMG_8968.jpg   135.75K   15 downloads
Attached File  IMG_8969.jpg   144.6K   14 downloads
Cut a dumbell weight in half and polished it before welding on to tube.
Attached File  IMG_8976.jpg   101.47K   14 downloads
Attached File  IMG_8974.jpg   94.66K   13 downloads
#83 sibhs
Posted 27 September 2019 - 05:40 PM
I needed a change of pace from panel and rust work so went to the back shed started prepping some of the chrome parts by wet and dry sanding then a polish.
Attached File  IMG_9004.jpg   148.78K   16 downloads
Filed off the dags around the badge.
Attached File  IMG_9006.jpg   126.55K   15 downloads
Stripped the bearings and springs from ash trays. Should of done this before the chrome was stripped.
Attached File  IMG_9010.jpg   192.79K   14 downloads
Attached File  IMG_9011.jpg   154.73K   14 downloads
Poured a few more parts, will see how they turn out once fully cured,trimmed and polished.
Attached File  IMG_9014.jpg   120.14K   14 downloads
Attached File  IMG_9015.jpg   208.56K   14 downloads
#84 Indy Orange
Indy Orange
  • 2,987 posts
Posted 27 September 2019 - 10:55 PM
Awesome job Marty, you don't miss anything .
#85 Rockoz
Posted 28 September 2019 - 09:11 AM
A small vacuum tank would be handy for making those little bits and pieces.
I have one in my to do list.
Just need to buy some more steel.
Im going to have a polycarbonate clear lid so I can watch the progress.
Bought a vacuum pump off fleabay for about 100 bucks.
Used that to vac down my Commodore aircon before a regas.
For those who may be interested.
Bursons sell an aircon gas that is a replacement for the 134a or whatever it is that gets used these days.
It is hydrocarbon based, so you dont need a fridgey ticket to buy it.
It works well too.
A mob like Big Boys Toy shop also sells it.
Not sure if I got that name right though.
What are you using to for the plastic bits?
Is it a 2 part polycarbonate or something?
I was looking down that road for when I get around to it.
#86 sibhs
Posted 04 October 2019 - 07:21 PM
It works well too.
Hi Rob, The first material I used would have benefitted with a vacuum tank due to it's thick consistency but this other product is very fluid and seems to poor well. It is a two part Polyurethane and feels and looks exactly like the original part.
#87 sibhs
Posted 11 October 2019 - 11:19 PM
Howdy guys,
Finished off some work on the cowl. Tried a new method of MIG welding. Unlike how I've read to randomly spot weld your metal together and do it slowly to avoid heat warpage this is the opposite.  Once the piece is tacked in place, start the spot welding and do about 4-6 spots joining on to the previous spot then stop and hit it with the compressed air till is cool enough to touch. Then continue this process all the way along the join. This was my first go at this method and found it much better for getting less gaps/holes in-between spots and no warpage.
Attached File  IMG_9087.jpg   227.99K   20 downloads
Attached File  IMG_9088.jpg   274.11K   15 downloads
Setting up for applying the rust blast solution which removes rust and leaves a rich zinc coating ideal for etching over or rust seal.
Attached File  IMG_9104.jpg   243.77K   15 downloads
Once dry I get set-up for the Rust seal.
Attached File  IMG_9110.jpg   229.59K   13 downloads
Attached File  IMG_9113.jpg   221.02K   15 downloads
Here you can see how the rust seal creeps into every pin hole and completely encapsulates it and exiting out the other side.
Attached File  IMG_9118.jpg   264.55K   14 downloads
Applied copper spray to the bare metal that'll be welded.
Attached File  IMG_9120.jpg   233.67K   16 downloads
A quick reminder of what it used to look like.
Attached File  IMG_8016.jpeg   153.23K   13 downloads
#88 claysummers
Posted 12 October 2019 - 08:08 AM
Apart from all your outstanding panel fab work, I’m very impressed with the way you are moulding all those little dip shit plastic parts. Fiddly work indeed. I’ve seen workshops on this stuff at Adelaide Moulding and Casting where I get resin and cloth for fibreglassing. I reckon they use the polyurethane product.
Very thorough work all around. Thanks for posting.
Clay
#89 Ice
Posted 12 October 2019 - 08:42 AM
Impressive work as usual Marty
#90 71xu1
71xu1
    Dave
  • 1,278 posts
  • Car:LC GTR XU1
Posted 12 October 2019 - 10:02 AM
Hey Marty, what diameter mig wire are you using?
#91 jd lj
jd lj
  • 2,124 posts
  • Name:James D
Posted 12 October 2019 - 04:02 PM
Marty,
As I was reading your previous post and looking at the pictures of the cowl and saw the surface rust I was thinking to myself that it needs some RUST BLAST on. It's good to see that your treating it with that.
#92 Ice
Posted 12 October 2019 - 04:26 PM
Are those philips head screws original Marty ✌️
#93 sibhs
Posted 12 October 2019 - 09:46 PM
Clay
Hi Clay, the shop I get the mould and resin material is also a fibreglass, resin etc shop too. There are a few different sorts depending on what hardness or flexibility you require.  I was almost going to try cast the rear quarter lenses but mine are good and that material is more expensive.
Thanks Geno. :)
Hi Dave, I think there are two common sizes and I've got the thicker one. I was told the thinner might make a better weld but will break easy and give you the shits so I went thicker.  .7mm or .9mm  I can't remember and the label is not on the spool.
Marty,
Hi James, yes, Rust Blast is my friend.
Get back in your hole Geno. :blahblahblah:
#94 sibhs
Posted 12 October 2019 - 10:22 PM
A few more pics of the repairs around the heater box. Using a panel LED to light up the area.
Attached File  IMG_9103.jpg   187.4K   13 downloads
Attached File  IMG_9112.jpg   154.8K   15 downloads
Applied Rust Seal to repairs and areas that need extra protection.
Attached File  IMG_9114.jpg   192.46K   16 downloads
Noticed a difference in spacing of windscreen pillar to dash on Passenger side compared to drivers. Pulled and jacked it into position.  I'm only talking about 3mm.
Attached File  IMG_9130.jpg   147.14K   16 downloads
#95 Rockoz
Posted 13 October 2019 - 08:25 PM
What do you mean by break easier with the thinner wire?
I use 0.6 for panel work, and 0.8 or 0.9 for anything over about 1.2mm.
Im trying to get a bit better with my TIG work on thicker stuff before I waste lots of gas on panels.
TIG welds dress up a lot easier, but I guess Im more of a grinder than a welder at this stage.
But Im getting the jobs done and improving.
#96 S pack
Posted 13 October 2019 - 08:50 PM
^^^ .6mm wire for panel work and .9mm for the heavier stuff like chassis repairs.
Edited by S pack, 13 October 2019 - 08:51 PM.
#97 sibhs
Posted 13 October 2019 - 10:42 PM
Thanks guys, I've had a chat with 71XU1 Dave and decided I will try the .6mm.
Hi Rob, It's just what I've heard, presuming they mean break at the spool drive area???
I will find out soon. It's on the shopping list
#98 Rockoz
Posted 14 October 2019 - 10:56 AM
Have never had 0.6mm break.
Have had very few jams, but turning the tension down a little prevents it most of the time.
Aluminium is a real bugger for doing it.
It usually happens when the wire hits the metal without arcing.
But using 0.6mm on panels makes it sooooooooooooo much easier.
You will blow less holes. You can use a slightly higher voltage for better penetration to.
Ive gone through a few rolls of 0.6,, over the last 10 years, and still havent used up a single roll of 0.8 or 0.9.
I bought a roll of 0.8 accidentally just recently. It will sit around for a long time before getting used.
I opened the box before I noticed, so will wear my mistake.
Ive been rebuilding my box trailer lately, so have used a bit of the thicker wire.
But will spool it up with 0.6 again shortly.
I wish I was in the same position as a mate of mine I worked with ages ago.
He had 2 300 or 400 amp Cebora Migs. One for steel, the other for aluminium, complete with a water cooled push pull setup on the gun.
He had another AS400 diesel rig that he had set up mainly for bucket hard facing.
Lots of other gear too.
He looked after a fleet of alloy tipper coal trucks, plus a few other owners trucks. He did dozer, loader and excavator repairs too.
Was a great time working with him. Always something different to tackle.
He taught me a heap about welding and prep and the like.
Not bad for me being an electrician, welding up aluminium bodies on coal trucks.
I needed variety even back then 20 years ago, or I just got bored.
#99 sibhs
Posted 14 October 2019 - 11:25 PM
I grabbed a roll of .6mm today and loaded it up and gave it a test.
I think it is a better weld and should help me get better results. I'm still getting used to it, feels like I can drop the power but have to feed the wire a bit faster to get a smooth weld.
There were a few bits to change as pictured below and lucky I found them in a box that came with the second hand welder.
Attached File  IMG_9160.jpg   142.95K   16 downloads
Attached File  IMG_9161.jpg   174.53K   16 downloads
Attached File  IMG_9162.jpg   144.83K   16 downloads
Thanks to Dave for spotting my big welds and mentioning wire size. Just remember I am no expert and have only learnt from you-tube, this forum and one metal shaping class.
Looking forward to better welds.
#100 Rockoz
Posted 15 October 2019 - 09:31 AM
You will get better very quickly with the 0.6.
It welds differently I find.
I get a lot more spatter with 0.8 or 0.9.
The welds are heaps cleaner.
My current task is improving my TIG skills, but it uses way more gas.
TIG welds are a lot softer to shape as well.
Hope Im not repeating myself.
Love my painkillers, but they give me alzheimers like symptoms sometimes.
Set the tension on the roller as low as you can to prevent bird nesting.
It will be a bit tighter than what is required to pull it off the roll.
If you avoid dead on starts, you can keep it low, but if you hit dead on it will either slip or birds nest.
Blow your liner out regularly too. Its amazing how much crap can get caught in it.
If you end up trying a bit of aluminium work, the experts recommend a seperate liner for that to reduce contamination.
Learning to weld aluminium is fun, but can also be frustrating.
Its a whole new world of fun.
