Nice job Marty!
The Sally Report
#751
Posted 13 May 2022 - 10:02 PM
#752
Posted 14 May 2022 - 09:19 PM
POPULAR
Weather turned it on for my last real paint day, had 25 degrees last Saturday so perfect for getting the stripes done.
IMG_8354.jpeg 205.82K
12 downloads
IMG_8359.jpeg 129.17K
12 downloads
IMG_8361.jpeg 154.79K
11 downloads
One of the reasons I did them in semi-gloss was to create a difference between the black and Amethyst. With certain angles of light the black stripes look silver. If I'd of glossed them they would have been harder to see.
IMG_8379.jpeg 114.74K
13 downloads
Just had to get the badge and handle on for a look. The orange goes really well with Amethyst.
IMG_8382.jpeg 178.81K
15 downloads
#753
Posted 15 May 2022 - 09:06 AM
Very cool Marty ![]()
#754
Posted 15 May 2022 - 09:20 AM
That looks so awesome!!
#755
Posted 15 May 2022 - 07:55 PM
I bought some more parts last week. One a bulk buy of all his left over parts and the other was just bits I needed.
You don't get much for $975 these days.
IMG_8365.jpeg 296.85K
25 downloads
IMG_8367.jpeg 302.63K
16 downloads
#756
Posted 15 May 2022 - 08:35 PM
#757
Posted 16 May 2022 - 05:44 AM
You could sell that grill for a grand.
Araldite the underdash panel and sell for $500+
#758
Posted 16 May 2022 - 07:08 AM
That's pretty good Marty!
The 4cyl spare wheel bracket won't fetch much
Edited by S pack, 16 May 2022 - 07:08 AM.
#759
Posted 16 May 2022 - 08:11 AM
#760
Posted 16 May 2022 - 02:05 PM
I purchased gaskets for and opel GT in the UK ,from memory only the extension housing one was different ,which I made from gasket paper ,scalpel and hole punch.Input shaft seal extremely hard to find.
Edited by Indy Orange, 16 May 2022 - 02:08 PM.
#761
Posted 16 May 2022 - 05:20 PM
Bugger! Obviously didn't know what I was looking at there. Just thought mines missing that, I'll buy it.
The grill and Aussie rebuild kit were my main priority.
I plan to restore the LC lower dash and hopefully recoup some money. I also think the small belt buckles are hard to find so they might help as well. There's a NOS muffler hanger in there too but don't see much demand for those. NOS wiring harness tape will get used soon.
Grill has a few broken and missing bits but plan is to fix that and keep as spare. I'm going to order a jewellers oxy torch and get some practice fixing the bars.
#762
Posted 16 May 2022 - 05:53 PM
Paint is looking amazing, I've said it before and I'll say it again, LC GTR's are my favourite
#763
Posted 16 May 2022 - 10:51 PM
Fairly sure the spare wheel bracket is the same for HK HT HG and there is a market for them.
#764
Posted 18 May 2022 - 10:50 PM
I finished off my modification of the clutch pedal and assembled the unit and accelerator pedal.
IMG_8391.jpeg 140.06K
9 downloads
IMG_8401.jpeg 126.25K
9 downloads
IMG_8402.jpeg 206.51K
9 downloads
IMG_8403.jpeg 140.54K
11 downloads
IMG_8406.jpeg 150.54K
11 downloads
IMG_8407.jpeg 140.61K
11 downloads
IMG_8408.jpeg 98.43K
8 downloads
IMG_8423.jpeg 184.23K
15 downloads
#765
Posted 19 May 2022 - 04:58 AM
#766
Posted 19 May 2022 - 06:55 AM
Well there ya go. I've got a NOS 4cyl spare wheel clamp screwed to a stud as a hanging hook..
#767
Posted 19 May 2022 - 07:08 AM
Just had a look at the HK parts catalogue. Nope, the LC LJ 4cyl spare wheel clamp part number is not shared with any models in the HK series. ![]()
So highly likely it does not feature in HT or HG either.
Edited by S pack, 19 May 2022 - 07:09 AM.
#768
Posted 19 May 2022 - 11:24 AM
What is that white grease Marty and where did you get it please?
#769
Posted 19 May 2022 - 05:48 PM
#770
Posted 19 May 2022 - 05:57 PM
#771
Posted 19 May 2022 - 08:27 PM
It's the Penrite white grease. I wouldn't recommend it, it's a food grade grease. I would of preferred the zinc oxide that Spack pictured above but could not find any.
#772
Posted 19 May 2022 - 09:25 PM
I have a tub of the Castrol.
Is this suitable for the door mechanisms too?
#773
Posted 19 May 2022 - 10:03 PM
Yep! The white grease is recommended in the workshop manual.
Edited by Indy Orange, 19 May 2022 - 10:04 PM.
#774
Posted 19 May 2022 - 11:33 PM
Time to restore the wiper motor.
IMG_6742 (1).jpeg 125.45K
4 downloads
IMG_6741.jpeg 153.65K
4 downloads
IMG_6739 (1).jpeg 46.19K
4 downloads
I found this stuff very good for cleaning up the dull zinc/galv finish.
IMG_6748 (1).jpeg 103.42K
4 downloads
IMG_6747 (1).jpeg 196.33K
4 downloads
One of the brushes had worn down so I bought some more that were close in size. Had to file it down to fit.
IMG_6750.jpeg 135.17K
5 downloads
IMG_8435 (1).jpeg 194.44K
7 downloads
IMG_6752 (1).jpeg 160.1K
3 downloads
IMG_6753 (1).jpeg 81.78K
4 downloads
IMG_6775 (1).jpeg 109.8K
5 downloads
IMG_6776 (1).jpeg 115.07K
4 downloads
Once it was all together I tested it with my test kit, an old switch and wiring plug connected to a battery. I use tape markers to confirm they park in the correct spot.
IMG_8442.jpeg 141.61K
4 downloads
IMG_8439 (1).jpeg 179.83K
5 downloads
#775
Posted 19 May 2022 - 11:46 PM
Cleaned up the wiper mechanism with a bit of paint stripper then the Metal Rescue.
IMG_8311 (1).jpeg 230.82K
13 downloads
IMG_8318 (1).jpeg 162.8K
12 downloads
Taking note of the wavy washers inside spline.
IMG_8310.jpeg 125.22K
13 downloads
Made sure the splines are all clean.
IMG_8383.jpeg 135.24K
15 downloads
Peen the end, you don't want these coming off once the heater box is in.
IMG_8392 (1).jpeg 128.9K
14 downloads
IMG_8397 (1).jpeg 91.29K
9 downloads
Fitted the fan cover plate
IMG_8395.jpeg 140.1K
15 downloads
Started working on the accelerator rod and pivot.
IMG_8410.jpeg 160.01K
20 downloads
IMG_8414.jpeg 142.67K
14 downloads
General →
General Discussion →
Hole for reverse cabling to gearboxStarted by dacastle , 02 Aug 2025 |
Holden Tech →
Electrical →
LC rear indicator screwsStarted by dacastle , 06 Apr 2024 |
General →
What can you identify from stamped body number onlyStarted by 70 XU-1 , 21 Dec 2018 |
General →
Resto Rage HelpStarted by Rainman , 16 Sep 2017 |
Holden Tech →
General LH-LX-UC →
LH Torana rear windscreen SpecificationStarted by _Pjabrown_ , 06 Sep 2016 |
