Jaso
The Sally Report
#776
Posted 20 May 2022 - 06:51 AM
Jaso
#777
Posted 20 May 2022 - 09:43 PM
I'm keen to get the roof lining in. Dug out the original one and cleaned up the rods and transferred them to the new lining one at time.
Added the padding to the rear quarters and also the three stripes behind back seat. Also tried to replicate the chalk markings that were on from factory. One day someone may work out what it means.
IMG_8426.jpeg 146.01K
10 downloads
IMG_8427.jpeg 106.23K
7 downloads
IMG_8429.jpeg 162.21K
11 downloads
Original markings.
IMG_7498.jpeg 84.29K
11 downloads
IMG_8431.jpeg 180.26K
9 downloads
I like to take my time with these. Last one took six weeks. Firstly get it unfolded and up in position.
IMG_8433.jpeg 135.86K
8 downloads
Using the old pinch weld to hold the lining in place.
IMG_8432.jpeg 229.52K
8 downloads
#778
Posted 20 May 2022 - 10:09 PM
Edited by rodomo, 20 May 2022 - 10:10 PM.
#779
Posted 21 May 2022 - 03:35 PM
Just realised I've got to get the wiring in for the interior light before fitting roof lining. Dug that part of the harness out, cleaned and tested it.
IMG_8448.jpeg 317.09K
9 downloads
Had some serious gunk stuck to it. I used thinners and a rag to wipe over the wires, wire brushed the connections and tested with volt meter for continuity.
IMG_8449.jpeg 163.39K
8 downloads
If it's ok to go on the dining room table it's got to be clean enough.
IMG_8483.jpeg 214.3K
11 downloads
Un-wrapped the stainless trim for the gutters, the glad wrap had stuck so I used thinners again to help clean it off.
IMG_8393.jpeg 208.93K
9 downloads
IMG_8394.jpeg 227.67K
8 downloads
IMG_8479.jpeg 119.08K
9 downloads
IMG_8480.jpeg 157.91K
12 downloads
#780
Posted 21 May 2022 - 08:16 PM
Have you got a photo of the clips that hold the hood lining bows in place? I forgot to take that photo when I pulled mine apart. I'll be fitting my hood lining soon too.
Thanks in advance.
#781
Posted 21 May 2022 - 08:23 PM
That was probably a LJ thing James,stops the rods from flipping over, not mentioned in the LC manual, probably not needed.
Edited by Indy Orange, 21 May 2022 - 08:27 PM.
#782
Posted 21 May 2022 - 08:57 PM
Here ya go.
Posted 21 May 2022 - 09:30 PM
Hey Marty,
Thanks in advance.
Hi James, No clips on this LC. Thanks for posting that pic Paul.
#784
Posted 21 May 2022 - 11:22 PM
Hi Marty,
Car is coming along beautifully, l always love your attention to detail.
Can I ask what you used to polish your gutter trims,l have 2 sets to restore.
Cheers Graham.
#785
Posted 22 May 2022 - 10:18 AM
Hi Marty,
Cheers Graham.
Hi Graham, on page one of this thread - post #11 are some pictures.
Depending how bad they are you either start with dent removal (tapping out with flat punch) Then file flat, wet & dry thought the grades to 3000 then use the polishing wheel like in pics. Two wheels used and the grey and white polish bars. Don't let the stainless get to hot or distortion can occur.
I'm going to run the polishing wheel over it again while it's on the car, it's a lot easier to keep it secure.
#786
Posted 22 May 2022 - 09:11 PM
Both window winding mechanisms are in.
IMG_8415.jpeg 165.93K
7 downloads
IMG_8417.jpeg 160.92K
7 downloads
Door mechanism in and working.
IMG_8416.jpeg 166.65K
9 downloads
Bit by bit, getting there.
#787
Posted 22 May 2022 - 09:34 PM
Hate to be the bearer of bad news, but pretty sure the glass has to go in before the mech :-(
#788
Posted 22 May 2022 - 09:51 PM
Don’t forget the weather strips.
#789
Posted 23 May 2022 - 09:30 AM
It's been a long time since doing this. I thought it was winder then glass in then quarter window???
I thought they went in last??
#790
Posted 23 May 2022 - 10:59 AM
Edited by Indy Orange, 23 May 2022 - 11:02 AM.
#791
Posted 23 May 2022 - 01:02 PM
Yeah , whilst the glass is still sitting in the bottom of the door.Then I could still get my arm up inside the door to push the clips up to secure the weather strips .
I know it's a prick of a job. Can't wait!
#792
Posted 23 May 2022 - 01:31 PM
#793
Posted 23 May 2022 - 01:35 PM
Finally got the heater box in. took a couple of attempts. First time I fitted it I noticed the back seal didn't fit well against firewall. Pulled it out and cleaned up all the shitty mastic. Checked some original rear seals and noticed they're about 3mm thicker than after market.
IMG_8521 (1).jpeg 51.01K
7 downloads
This time I used an original seal and it looks better.
IMG_8526.jpeg 213.15K
13 downloads
IMG_8525.jpeg 163.25K
8 downloads
IMG_8548.jpeg 199.36K
11 downloads
Noticed the accelerator rod was rubbing on heater box. Realised the throttle bracket was bent up a bit so straightened it out and it now clears, Just.
IMG_8530.jpeg 201.24K
7 downloads
IMG_8529.jpeg 181.39K
3 downloads
Realised this car never came with the heater box cable clip. If anyone has a spare I would gratefully accept it.
Goes here.
IMG_8551.jpeg 185.25K
6 downloads
Looks like this one
IMG_8542.jpeg 169.73K
3 downloads
Clean up the venting and installed those. I was missing some of the heater box nuts which are an unusual thread to the rest of the car. Found out they're 5mm metric and got some from my local nut and bolt store. Look similar but not exact.
IMG_8522.jpeg 187.74K
5 downloads
IMG_8524.jpeg 129.56K
4 downloads
IMG_8539.jpeg 125.91K
7 downloads
I was given this as a gift, one of the nicest and handiest ratchets you'll find. Well worth the money.
IMG_8540.jpeg 127.07K
5 downloads
#794
Posted 24 May 2022 - 09:50 AM
Slow down mate. You're making us look really bad.
Exciting times! Very fun part of the build.
#795
Posted 26 May 2022 - 10:25 PM
It's a good feeling unwrapping all these parts I restored a couple of years ago. Also glad I marked what they are and where they go.
IMG_8537.jpeg 170.18K
4 downloads
IMG_8538.jpeg 220.99K
4 downloads
IMG_8536.jpeg 135.59K
5 downloads
IMG_8553.jpeg 145.91K
5 downloads
I hooked up a battery to test the fan and cable set-up is working.
IMG_8555.jpeg 205.93K
4 downloads
Also managed to get the glovebox in with-out to much trouble this time. There is a technique to it so you don't break it.
IMG_8558.jpeg 145.39K
7 downloads
#796
Posted 27 May 2022 - 07:40 PM
Could you share the technique for fitting the glove box insert. I'll be doing my soon enough and recall that it's an awkward task.
#797
Posted 27 May 2022 - 08:41 PM
Marty,
Insert the left hand side first pushing it in as far as you can. This should give you just enough room to get the right hand side in. Next work on getting the top lip in behind metal. I used a plastic trim remover tool (Basically a plastic flat blade screwdriver). Lastly using the tool to lever the right hand side lip behind the metal edge. The bottom card stays on top of metal lip.
Good luck James.
#798
Posted 27 May 2022 - 09:19 PM
Time to clean up and repair the main wearing harness. I'll try and describe all the little fixes and photograph.
IMG_8572.jpeg 315.55K
3 downloads
This connector was discoloured and cracked. I have a spare harness which I have salvaged the missing and broken bits. Definitely worth having a butchered harness to get spares from.
IMG_8573.jpeg 164.01K
4 downloads
I used a home made tool to release the clips from the plugs. The tool is made from a street sweeper metal bristle, I've found many sitting in the street gutters.
IMG_8575.jpeg 173.31K
4 downloads
Re-fit the new plug.
IMG_8577.jpeg 174.84K
4 downloads
This indicator plug had been butchered
IMG_8586.jpeg 110.9K
5 downloads
I found some matching wires and joined and soldered further up the harness to be hidden by wrap.
IMG_8587.jpeg 106.27K
5 downloads
IMG_8588.jpeg 130.23K
5 downloads
The tool I made in top left corner.
IMG_8589.jpeg 220.88K
5 downloads
Drill out the old wire from clip, fitted new wire and soldered.
IMG_8604.jpeg 82.68K
6 downloads
#799
Posted 27 May 2022 - 09:34 PM
Apon inspecting and cleaning the harness I noticed this tan wire had been cut. It's on the drivers side between headlight and brake booster. Worked out its the brake valve indicator. I have a spare and will fit that once harness is in so I know the length.
IMG_8591.jpeg 128.92K
7 downloads
IMG_8592.jpeg 92.51K
6 downloads
Once I had cleaned and repaired it was time to fit the rubber grommet. You'll need plenty of lube for this job as you stretch this tiny hole over many large bits. Rubber grease is king for this task.
IMG_8605.jpeg 161.73K
7 downloads
A better picture of the tool. Removing clips I'd just put on.
IMG_8606.jpeg 168.95K
7 downloads
IMG_8610.jpeg 128.61K
6 downloads
Heres a bunch of clips attached to a pull wire and taped up, with plenty of lube.
IMG_8611.jpeg 170.69K
6 downloads
IMG_8612.jpeg 176.86K
4 downloads
IMG_8613.jpeg 175.47K
4 downloads
#800
Light lense.
General →
General Discussion →
Hole for reverse cabling to gearboxStarted by dacastle , 02 Aug 2025 |
Holden Tech →
Electrical →
LC rear indicator screwsStarted by dacastle , 06 Apr 2024 |
General →
What can you identify from stamped body number onlyStarted by 70 XU-1 , 21 Dec 2018 |
General →
Resto Rage HelpStarted by Rainman , 16 Sep 2017 |
Holden Tech →
General LH-LX-UC →
LH Torana rear windscreen SpecificationStarted by _Pjabrown_ , 06 Sep 2016 |
