My LC/J Torana Coupe
131 replies to this topic
#76 Indy Orange
Indy Orange
  • 2,987 posts
Posted 21 September 2021 - 08:44 PM
Very nice Matt,looks fantastic .
#77 RIM-010
Posted 21 September 2021 - 10:26 PM
That's awesome! Nice work
#78 claysummers
Posted 21 September 2021 - 10:31 PM
Great milestone Matt.
#79 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 17 October 2021 - 11:17 AM
I'm getting the old girl ready to hopefully go to the 'Torana's on the Murray' event early next month in Albury.
As it's a long drive from Sydney I fitted a new water pump and 180' thermostat yesterday as some preventative maintenance. (it's already had the alternator reco'd, new regulator, coil, plugs, belt and hoses)
My temp gauge has always read a bit high, around the 3/4 mark, so around 90 to 95 degrees when just cruising around. It gets a bit lower on the highway.
The car has a single thermo fan that is always on.
I'm thinking it may have the wrong temp sender for the dash?
From what I have seen it should be this one?      https://www.ebay.com...60.021&_sacat=0
Below are pics of what's in the car. Does anyone know if it's the right one??
From what I can see it has the numbers 6-83 120' on it
Edited by Gatti, 17 October 2021 - 11:20 AM.
#80 S pack
Posted 17 October 2021 - 01:52 PM
Mate, 360.021 is an oil pressure sender not a temp sender.
#81 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 17 October 2021 - 02:05 PM
For some reason that link I used show's an oil pressure sender first.
Below is what I meant
#82 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 01 November 2021 - 01:47 PM
I changed the temp sender in the weekend and it's much better.
It goes to just over 80' and I can see when the thermostat opens then happily sits as below when driving
#83 claysummers
Posted 01 November 2021 - 07:04 PM
Nice Matt. May be running a bit cold. Would be nice if it goes back to 82C and sits there.
early Holden nut
#84 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 01 November 2021 - 07:27 PM
early Holden nut
I’m driving it from Sydney to Albury and back this weekend for the Torana Muscle on the Murray event so I’ll see what it does then
#85 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 11 December 2021 - 01:14 PM
I had a split in the exhaust gasket so fitted a new one.
Here’s a photo of the ports on the head while everything was off.
Do you think it’s had much port work done??
#86 I'm a Red Motor fiend
  • 774 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 11 December 2021 - 02:59 PM
Dunno why they did that to the exhaust ports. 2/3 and 4/5 have had the dividers ground back past the bolt up face.
I would say they probably are too big as the inlets are fairly moderately ported.
#87 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 13 December 2021 - 07:57 AM
I thought that was a bit strange too.
I have been thinking about buying one of HSD's Bathurst style heads as a replacement and fitting roller rockers at the same time and maybe I'll do it sooner
#88 MustardGTR
MustardGTR
  • 243 posts
  • Car:72 GTR, 73 GTR
Posted 13 December 2021 - 10:04 AM
The head on your car looks like and older style head where the castings didn't have dividers up to the gaskets on the exhaust (2/3 and 4/5). Not ideal in terms of transferring gasses through into the extractor tubes and creating clean pulses/ scavenging.
#89 Heath
Posted 13 December 2021 - 12:04 PM
Yeah, that is super weird and I cannot see how it would be a good thing.
#90 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 13 December 2021 - 04:02 PM
Maybe it is to do with it being an early design head as MustardGTR mentioned?
From memory when I looked into it a while back the head is from the HT/HK era.
I had a search online and found a pic of another head where the exhaust ports are very similar to mine.
#91 I'm a Red Motor fiend
  • 774 posts
  • Name:Adam
Posted 13 December 2021 - 07:18 PM
To me your head looks as though it still has the remnants at the base of the ports where the divider used to be level with the bolt up face.
What is the number on you head?
#92 S pack
Posted 13 December 2021 - 08:02 PM
Agree.
From memory OEM Holden red 6 manifold gaskets to suit EH 149 & 179 onwards always had the divider strip in the middle of the 2/3 & 4/5 exhaust ports.
#93 claysummers
Posted 13 December 2021 - 08:08 PM
early Holden nut
#94 I'm a Red Motor fiend
  • 774 posts
  • Name:Adam
Posted 13 December 2021 - 08:14 PM
There are definitely early heads though that do have siamesed ports like MustardGTR mentioned.
#95 MustardGTR
MustardGTR
  • 243 posts
Posted 13 December 2021 - 10:05 PM
I once owned a yellow terra head with the siamese exhaust ports - cast number 7420081. Couldn't wait to get rid of it as the performance was woeful!
Attached File  IMAG5211.jpg   180.67K   13 downloads
Edited by MustardGTR, 13 December 2021 - 10:08 PM.
#96 I'm a Red Motor fiend
  • 774 posts
  • Name:Adam
Posted 14 December 2021 - 05:37 AM
Likely a 149 casting perhaps.
#97 claysummers
Posted 14 December 2021 - 06:37 AM
7420081 is a 179 L head
#98 I'm a Red Motor fiend
  • 774 posts
  • Name:Adam
Posted 14 December 2021 - 07:06 AM
So perhaps 149/179 had the siamesed ports and they changed with the introduction of 161/186?
#99 claysummers
Posted 14 December 2021 - 08:07 AM
I had one of each got rid of 6 months ago. Vaguely remember seeing siamesed ports when fitting extractors years ago.
early Holden nut
#100 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 14 December 2021 - 09:08 AM
I had a look and remembered the numbers on the head are no longer readable for some reason.
The block is a 186P so I think that is from a HK
