My LC/J Torana Coupe
131 replies to this topic
#101 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 26 June 2022 - 01:09 PM
I came across my compression tester when tidying up the garage so did a test on my motor
I tested with a warm motor and got
150
135
140
140
140
150
The cam is a 107 LSA with 254 duration
Do the results above seem o.k?
#102 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 26 June 2022 - 01:44 PM
I just went through them again and number two was up to just over 140 as well.
#103 I'm a Red Motor fiend
  • 774 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 26 June 2022 - 02:30 PM
I think they seem good.
You really need to know your static compression though to know if they reflect right and how much that cam bleeds off.
If it's only moderate then those numbers are fine. If you have a big static number I would say those figures are down.
Regardless, I think your good.
#104 I'm a Red Motor fiend
  • 774 posts
  • Name:Adam
Posted 26 June 2022 - 02:35 PM
If you do a warm wet test (bit of oil down each plug hole) and the figures are much the same then you are all good.
#105 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 26 June 2022 - 06:06 PM
Thanks mate
I'll do a wet test next time I take it out just to be sure
It doesn't burn any oil so I think it's pretty healthy
#106 gtrboyy
Posted 28 June 2022 - 11:42 PM
Within 10% so looks decent as said above warm it up do dry test then wet test couple drops of oil from squirter can.
General idea is If goes up means some ring wear if stays same valve or seat assuming not adjustable rockers.
#107 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 27 August 2022 - 06:48 PM
i've started getting my car read for XU1's on the Mountain at Bathurst this year.
I've fitted a 2.5 inch side pipe and steel rims to give it a racier look and sound
https://imgur.com/XWCNJj7
Edited by Gatti, 27 August 2022 - 06:50 PM.
#108 RallyRed
Posted 28 August 2022 - 09:18 AM
Nice work.
Reckon black wheels are a nice change.
#109 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 28 August 2022 - 10:34 AM
Here's a quick video
https://youtu.be/9JFvHyeZQ50
#110 lctriples
lctriples
  • 414 posts
  • Name:paul
Posted 28 August 2022 - 07:32 PM
Hey Matt, looks and sounds shit hot. Nice lumpy cam! Paul
#111 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 29 August 2022 - 07:49 AM
Thanks mate.
I kept taking it out for a drive around my area over the weekend as i'm loving the sound
#112 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 06 February 2023 - 01:33 PM
Started to get the car ready for the Torana Nationals in Canberra.
After I drove it from Sydney to Albury for Torana's on the Murray I decided the 3.55's aren't for me as the revs were a bit too high.
I picked up a 3.36 LSD and had it freshened up and fitted it on the weekend so it should be a bit nicer on the highway now
Edited by Gatti, 06 February 2023 - 01:34 PM.
#113 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 07 February 2023 - 11:02 AM
I also did a couple of big events with the car last year starting with Torana's on the Murray in Albury
#114 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 07 February 2023 - 11:07 AM
Then the following week I took it to Bathurst to XU1's on the Mountain to celebrate 50 years since Brocks win
#115 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 07 February 2023 - 11:11 AM
On the highway drives the motor was pushing a little bit of oil out of the breathers so I have now fitted a Bocam catch can to match the rocker cover.
Hopefully that will help on my drive to Canberra for the Nationals
#116 sibhs
Posted 07 February 2023 - 01:33 PM
Good to meet you at Bathurst Matt. I even got in your Fletch pic.
#117 claysummers
Posted 07 February 2023 - 02:54 PM
Good to see you out enjoying it Matt. Taller diff may help ease the oil venting.
#118 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 08 February 2023 - 10:09 AM
Good to meet you too
Your car looks great in the flesh too 👍
#119 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 16 July 2023 - 04:31 PM
I picked up some 13 x 7 and 13 x 9 wheels this weekend.
They were a great price and have been unused.
The new 13 x 7's for the front stick out quite a lot and as my car is lowered at the front it actually sat on the tyre.
My old rears were also 13 x 7's but a different offset that still keeps the wheel tucked under the guard so I ended up using them so no need to change springs or even roll my guards and so far I have no rubbing.
Pretty stoked with how they look
#120 Ice
Posted 16 July 2023 - 05:09 PM
They look fantastic with the Red
#121 sibhs
Posted 16 July 2023 - 08:45 PM
Hi Matt, I've got the 13 x 7 on the front and super low springs but never touched tyre. Something doesn't seem right?
215/50 Dunlops
Does look good though.
#122 claysummers
Posted 16 July 2023 - 08:59 PM
They look like they might be zero offset. I assume you are both running factory spindles, hubs brakes.
#123 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 17 July 2023 - 08:54 AM
215/50 Dunlops
Hi mate, I had a look at your photos and my car sits lower than yours in the front by the looks of it.
 Yep factory parts on mine
#124 RallyRed
Posted 17 July 2023 - 09:59 AM
Hi mate,
I have purchased a few sets of these recently manufactured Sprinters in the last few years.
From memory the fronts are normally  "6", ( as marked on the boxes/labels)...which upon inspection appears to be as simple as 6mm has been milled off the inside of the centre hub.
Apologies if you already know that.
Edited by RallyRed, 17 July 2023 - 10:06 AM.
#125 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 17 July 2023 - 11:39 AM
Hi mate,
Thanks mate
I was actually surprised how much further the fronts stuck out compared to the rears.
It looked a bit odd when you looked down the side of the car.
My old 13 x 7's made the front perfectly inline with the rears now.
