GMH LX8
391 replies to this topic
#326 rodomo
  • 18,095 posts
Posted 05 January 2023 - 11:03 PM
The improvements to this "budget build" track car were on going with lap times falling each outing. The next step was to fatten up the mixture but it never got there as I sold the car. I still have the engine set-up but it will be going in a road car with a road going exhaust so we may never know?
#327 Bruiser
Bruiser
  • 888 posts
  • Name:Bruce
Posted 06 January 2023 - 07:43 AM
Yeah, I’ve read through your adventure with your white commodore, brilliant stuff. It’s hard to tell what to say caused a gain, or even a loss with things like that sometimes. I’m betting it couldn’t have hurt. Love a great backyard job
Shitstr, the “headers by Ed” site has some more interesting exhaust theories, he seems to go against the grain a bit, and has claims to back his ideas too.
Look in the header design section, there might be something in there for you while you’re designing something different
- If you haven’t seen it already, that is
#328 Heath
Posted 10 January 2023 - 12:33 PM
Just make sure that you don't have any big flat areas on your exhaust (I'm looking at that middle section, triangular in shape on the drawing)
Everything has to be curved, or at the very least, bead-rolled, or you'll have structural issues.
That is why my big expansion chamber (V1.0) vibrated apart and why the car has V2.0.
#329 Shtstr
Shtstr
    Formerly lcxu105
  • 1,813 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 10 January 2023 - 12:57 PM
I've already thought of that and put a slight fold line down the centre of the flat sections to give it some strength and to stop vibration.
Only raiit 10mm max in the centre but more than enough to give it some ridged strength and stop vibration.
Edited by Shtstr, 10 January 2023 - 01:02 PM.
#330 Heath
Posted 10 January 2023 - 01:04 PM
Sweet. It's hard to know how carried away to get, but mufflers seem to survive forever with a constant radius in the metal, and my flat one lasted less than 100km, so somewhere in the middle is probably fine. :)
#331 Shtstr
Shtstr
    Formerly lcxu105
  • 1,813 posts
  • Name:Mmmmmmm
Posted 10 January 2023 - 05:58 PM
Fold like is down the centre line so it's rigid and stops it fluttering up and down causing stress on the welds.
#332 Shtstr
Shtstr
    Formerly lcxu105
  • 1,813 posts
  • Name:Mmmmmmm
Posted 14 February 2023 - 11:57 AM
Well after trying to make the expansion chamber out of 4 peices and not being able to keep it flat and not twist.
I decided toget a flat sheet of stainless steel rolled to make it in one peice to eliminate twist from end to end.
After having no luck finding anyone who could roll it even after they said they could.
I decided to give it a crack on my home made pan brake for the hell of it.
I think it turned out fairly good for a home made pan brake job and not a proper one. I overlapped the seam to get a better weld join. As it will have more strength than a but weld on 1.5mm stainless. If it was 3mm or larger I would have done a butt join full pen weld.
Now to build the exhaust system.
#333 Shtstr
Shtstr
    Formerly lcxu105
  • 1,813 posts
  • Name:Mmmmmmm
Posted 14 February 2023 - 12:02 PM
Not too bad.
I wedged a bit of alluminium in between the rear 45 bends to hold them in place so ignore that haha.
#334 Shiney005
  • 10,064 posts
Posted 17 February 2023 - 10:09 AM
Unfortunately, it is hard to find anyone to make custom parts these days. It looks like you have done as good a job of it anyway.
#335 Shtstr
Shtstr
    Formerly lcxu105
  • 1,813 posts
  • Name:Mmmmmmm
Posted 17 February 2023 - 01:48 PM
Well I managed to get some time in the shed today.
Started tacking the exhaust in place.
Have a bar across under the mufflers to hold it up at the rear atm until I decide to go over or under the diff.
I know under will be easier and less hassle. But nothing in this car has been easy to work out and build so far🤣🤣🤣.
So that's it now till I get some more time in there.
#336 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 18 February 2023 - 09:35 AM
You could use oval mandrel bends to get 3" tail pipes over the diff a bit easier.
I gained a noticeable amount of power when I ditched the 2.5" tail pipes.
#337 claysummers
  • 3,753 posts
Posted 18 February 2023 - 05:50 PM
I vote for flattening the 3" pipes over the axle too. Even if you reduce the crossection height to 2" over a short section effect on flow is negligible. Tidier solution than under slung.
#338 Shtstr
Shtstr
    Formerly lcxu105
  • 1,813 posts
  • Name:Mmmmmmm
Posted 19 February 2023 - 10:14 PM
I think I've worked it out.
90 degree from muffler pointing up.
180 degree bend over the top of the diff parrerel to the top diff arm. 170mm inbetween legs
90 degree facing outwtowards towards the wheel.
60 degree bend turning to run pipe parrerel to the side of my drop tank.
Straight pipe back to a 30 degree bend turning towards the rear of the car to exit the rear of the car with a Straight pipe.
Plenty of room and clearance all round. As my tank is different from others as I have a lot of modifications under the car with the awd system and wheel tubs mini tubbed.
#339 Rockoz
  • 4,086 posts
Posted 20 February 2023 - 08:44 AM
Anyone considered using donuts for the tight clearance places instead of mandrel bends?
You can get a lot tighter radius using donuts than a mandrel bend will ever give you.
#340 Shtstr
Shtstr
    Formerly lcxu105
  • 1,813 posts
  • Name:Mmmmmmm
Posted 20 February 2023 - 11:48 AM
Yes that's true. But you need a minimum of 160mm inbetween the legs down each side of the diff to have clearance. Have found a 180 degree bend that has 172mm between legs so it is perfect for the task at hand. It also happens to contour the diff tunnel almost perftoo. So can set and forget it.
The stainless will expand at a rate of 2.54 inches per 100 feet. So at the length of the exhaust it will expand about 6mm over 10 feet.
It all has to be taken into account for clearance of diff and tunnels.
#341 Shtstr
Shtstr
    Formerly lcxu105
  • 1,813 posts
  • Name:Mmmmmmm
Posted 07 March 2023 - 10:31 PM
Well the weather is going to cool down a bit on Friday in SE QLD. So hopefully I will be able to get this exhaust finished finally.
So I can move onto the next issue of running the wiring harness in the engine bay to the cabin on both sides of the bay.
#342 Shtstr
Shtstr
    Formerly lcxu105
  • 1,813 posts
  • Name:Mmmmmmm
Posted 14 March 2023 - 11:54 AM
Got some time this morning to spend some time on the exhaust.
Got one side up over the diff.
#343 Cook
Cook
  • 1,535 posts
Posted 15 March 2023 - 09:38 AM
Well done. I'm running a 2.5" system over a 9" diff and I know the exhaust guy had a lot of fun getting it over. Cheers Ron
#344 Shtstr
Shtstr
    Formerly lcxu105
  • 1,813 posts
  • Name:Mmmmmmm
Posted 16 March 2023 - 10:58 AM
Best v band clamps I've found by far. Heavy duty and the only one's I've found with a machined recess for your pipe to slip into for a cleaner join and better weld seal/ joint.
#345 Shtstr
Shtstr
    Formerly lcxu105
  • 1,813 posts
  • Name:Mmmmmmm
Posted 22 March 2023 - 10:31 AM
And over we go. Twin 3 inch pipes.
Just tacked together atm. Still have to run it to the rear behind the diff but the hard part is done.
20mm between exhaust pipes and body. Roughly 3 inches of suspension travel at ride height. So will set the bump stops to a height where nothing hits.
#346 claysummers
  • 3,753 posts
Posted 22 March 2023 - 06:14 PM
Very well done!!
#347 jeffblanco
jeffblanco
  • 392 posts
  • Name:Mando
Posted 25 March 2023 - 01:02 PM
Great work,
I wish I had used the V clamps.
It make so much sense.
Hindsight is grand.
There are so many things I've see the guy's on this forum do, that makes me stop and think "why didn't I think of that"
Regards Mando.
#348 Heath
Posted 29 March 2023 - 08:41 AM
That is a pretty difficult bit of exhaust work. Nicely done!
I'm gonna stick with my reduced droop rear suspension and pipes under the diff hahaha.
#349 Shtstr
Shtstr
    Formerly lcxu105
  • 1,813 posts
  • Name:Mmmmmmm
Posted 12 April 2023 - 04:39 PM
Got a bit of time over the weekend to finish running the exhaust pipes to the rear of the car.
Twin 3 inch stainless steel with mandrel bends over the diff.
Decide to run it up high at the rear. Will be fine that close to the rail as there will be a mounting bracket to hold it from hitting the rail. There is about 12mm between the pipe and the rail.
Over the diff I have 20mm plus between pipe and floor and 65mm between diff and pipe. So should be fine once I make my bump stops to suit.
Edited by Shtstr, 12 April 2023 - 04:41 PM.
#350 jeffblanco
jeffblanco
  • 392 posts
  • Name:Mando
Posted 12 April 2023 - 08:31 PM
Great work,
I love the way the pipes follow the shape of the tank.
Regards Mando.
