GMH LX8
#376
Posted 09 December 2023 - 07:35 AM
#377
Posted 09 December 2023 - 07:53 AM
Huge difference Clay ![]()
#378
Posted 19 December 2023 - 05:53 PM
https://youtu.be/zqt...ULOilHlmZ9Wrmr4
Nothing like the video I posted for the cam sound.
As I said before I've never heard an old gray motor sound like a lumpy v8.
I can say that with a lot of confidence too. Because our family use to race the old gray moors way back in the day. To the point of running them on 15% alcohol and nitro turned one on Allan Butcher engine dyno with a total of 72 degrees advanced and 9000rpm.
So as I said I've never heard any gray motor even one well and truly off its head for racing sound like a lumpy v8.
#379
Posted 19 December 2023 - 05:54 PM
#380
Posted 31 December 2023 - 09:13 AM
Gee, my humble apology mate. Seems I touched a nerve.
Nah mate not even the slightest.
But it did give me a laugh that you thought an old grey motor cold sound like that though
#381
Posted 31 December 2023 - 05:26 PM
#382
Posted 12 January 2024 - 05:18 PM
But those days are long gone and I'm not worried about winning races anymore.
So here is the cam card for my cam. This thing will have excellent low down and mid range torque and should carry hp to around 6800 to 7000rpm.
Funny thing is I couldn't find anything that was like this on the shelf from anyone.
When I asked on a usa site I found out that the ASA High lift cam is almost the same specs that I worked out for this engine.
227/235@50 277/289 advertised duration.
My dynamic compression ratio will be just under 8.6 to 1.
With 11.3 static compression ratio. Perfect for 95 or 98 octane and still able to run E10 if need be.
Posted 13 January 2024 - 05:18 AM
How do you work out the cam required?
#384
Posted 17 January 2024 - 11:04 PM
By knowing the engine specifications you can match a cam up to just about any given engine.
Valve timing is key for an engine to work to its full potential.
It's something that you learn over a long time unless you grow up with people who teach you.
I was lucky to have the later and be involved in motor racing for a long time from birth basically.
#385
Posted 19 April 2024 - 06:44 PM
Finally had time to spend on the lathe to turn up a custom aerial mount for the electric aerial out of some 6061 alluminium. Need to get it anodised.
Also made up a plenum drain fitting as one was missing from the car.
I have made a 2 peice sleeve fitting to press in from the top and bottom with some sealant between them to prevent any rust again. Plus I'll paint it in KBS to be sure.
Posted 19 April 2024 - 06:47 PM
Posted 20 April 2024 - 02:23 PM
Posted 28 February 2026 - 07:12 PM
I haven't posted on here for a while due to life getting in the way of the build.
But res assured it's still slowly moving forward.
Here is a couple of videos of the port work 95% completed on the intake and finished on the exhaust side.
Heads will be upgraded with VTKLS8 valve spring and 2.02 ferrera intake and 1.57 exhaust valves.
Note the intake ports are burr finish and the exhaust ports are polished smooth as possible.
Im in the process of polishing the combustion chambers at the moment.
Slow and painstaking process.
But well worth the benefits.
When I finish the heads I'll turn my attention to the intake manifold.
https://youtube.com/...kZOqs5gQCsFiI4k
https://youtube.com/...cWb_ABvtE8Kbh9z
https://youtu.be/-a2...nxPvoxXtq0qyTmK
https://youtu.be/nXM...Ce7kUPhpU6hURS8
#389
Posted 01 March 2026 - 09:10 AM
Cool. Good to see it is still moving along.
#390
Posted 01 March 2026 - 03:43 PM
There is many factors that decide what you use.
Static compression ratio
Rpm required
Idle quality
Drive ability
Stall converter size
Head flow and at what point the flow falls off
Valve size
Valve spring
Flat tappet or roller as they respond differently
Just to name the basic ones.
#391
Posted 06 March 2026 - 01:00 PM
Enjoy
https://youtu.be/fFJ...IcoixzchQBVp31z
https://youtu.be/rcC...bg7U-aYTlRLYo_H
#392
Posted Today, 11:10 AM
I don't know what the latest is in head porting, but I am assuming you will leave the inlet ports a bit rough? I can remember back in the '90's that polishing went out of fashion as some believed it hindered the mixing of fuel and air.
