Folded some 5mm flat bar into a U shape and drilled a 14mm hole for the bolt to go through.
Just have to get some longer bolts now.
Also run brake lines and fitted mounting clips to hold in place firmly.
Changed where they run from inside the front chassis rail to the outside and drilled some holes to run them through at the front.
