186 rebuild, Oracle advice
#151
Posted 29 May 2021 - 05:47 PM
#152
Posted 29 May 2021 - 06:16 PM
5thou lash+/-1 by Gregory’s. Haven’t had adjustable lifters since 1996. Prolly should get a factory manual. Oil coming up the pushrod ok.
#153
Posted 30 May 2021 - 09:23 AM
Didn't use the lube initially on advice of old jonno.
early Holden nut
#154
Posted 30 May 2021 - 09:32 AM
early Holden nut
#155
Posted 30 May 2021 - 09:48 AM
Hi Clay, are they new lifters?I will reinstall at right angles to slight wear mark. Should I be able to compress the lifter at all? Seems solid.
early Holden nut
Just FYI, i got supplied solid lifters a while back, that should have been hydraulic. Soon returned them in a fury.
The pushrod side of lifter, should have a springclip to retain the pushrod seat and internal hydraulic mechanisms.
You should be able to compress the pushrod seat slightly. Oil would leach out of the hole, on the side of the lifter.
Edited by 73SUNBURSTEXYOUWON, 30 May 2021 - 09:50 AM.
#156
Posted 30 May 2021 - 09:53 AM
early Holden nut
#157
Posted 30 May 2021 - 09:55 AM
#158
Posted 30 May 2021 - 10:01 AM
#159
Posted 30 May 2021 - 10:06 AM
early Holden nut
#160
Posted 30 May 2021 - 10:19 AM
#161
Posted 30 May 2021 - 10:26 AM
early Holden nut
#162
Posted 30 May 2021 - 11:43 AM
early Holden nut
Edited by claysummers, 30 May 2021 - 11:50 AM.
#163
Posted 30 May 2021 - 12:54 PM
I'm going to try swapping a few lifters around next.
early Holden nut
#164
Posted 30 May 2021 - 02:10 PM
Have a 161 here I'm considering swapping cam. Im assuming it's stock.
early Holden nut
#165
Posted 30 May 2021 - 03:33 PM
#166
Posted 30 May 2021 - 04:34 PM
Proceeding to bed cam in.
early Holden nut
#167
Posted 31 May 2021 - 09:34 AM
Just sorting clutch hydraulics then bed rings.
early Holden nut
#168
Posted 31 May 2021 - 07:41 PM
#169
Posted 31 May 2021 - 07:53 PM
Running sweet after 90 minutes driving. Added coolant and adjusted 1 or two loose tappets. Will change oil and filter before 6000km trip coming up. Thanks Dave, Adam, Jaso, Byron and others for input.
Cheers Clay, hope the 6k trip goes well
Happy motoring
#170
Posted 08 June 2021 - 12:25 AM
Adelaide to Broken Hill tomorrow. Certainly don't envisage any overheating issues as forecast says minimum 4, max 7, with 20mm rain along the route.
early Holden nut
#171
Posted 08 June 2021 - 06:50 AM
#172
Posted 08 June 2021 - 07:43 AM
So changed oil and filter other day. Tappets rattle about one second on fire up. Once warm it is sewing machine quiet. Run up to estimated 4200prpm. ( 100kph 1.59 second gear, 3.08 rear, 235 60 R14 tyres. Cut open the filter, nothing but clean oil in it that I could find.
early Holden nut
Have a safe trip mate.
#173
Posted 08 June 2021 - 08:46 AM
Love it when a plan comes together...enjoy the trip!
#174
Posted 09 June 2021 - 05:45 AM
Nudged up to 110kmh in second a couple of times, estimated 4600rpm, no sign of valve bounce. However dip stick shorted coil feed and melted some of the loom. Trundled in to the Hill on a hotwire. Damn, knew I should have brought a spare wiring loom.
#175
Posted 09 June 2021 - 07:01 AM
The one item you dont pack on a trip, will be the one thing you need.
Last year, i drove my EH to Bathurst for the EJEH nationals....had fitted new brakes all round the week before....had some teething problems with the brake drums prior to leaving, got it sorted, then felt we are ready to go....
(packed a few other spare bits n pieces that never got used)
Anyway, got to a tinpot town, had a squeally brake lining, n thought, i got nothing to shut it up.
Walked into a local hardware, bout some rough sandpaper. So at the 1st nights accomodation, pulled that drum off, to roughup the linings a bit.
Off we went again...
So it happens,
