Lowering top arm on LJ
71 replies to this topic
#26 _jklumpp_
_jklumpp_
Posted 06 December 2006 - 01:07 PM
I've bitten the bullet & drilled the holes... .I'll let you know how I go....
#27 _73LJWhiteSL_
_73LJWhiteSL_
Posted 06 December 2006 - 10:56 PM
I will be watching with much interest jklumpp. :spoton:
Steve
#28 _jklumpp_
_jklumpp_
Posted 06 January 2007 - 07:55 AM
Finally got around to uploading some pictures....
#29 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 14 April 2007 - 11:41 PM
I just did this mod testerday and today, the holes looked a little thin on the edges so i added some weld to thicken it. Also did other mods.
#30 _lurkin308_
_lurkin308_
Posted 15 April 2007 - 12:36 AM
i did this mod a few months backbut i did for ajustability and clearance reasons too
cheers caine
#31 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 15 April 2007 - 01:23 AM
cheers caine
yep it gave me a fair bit more room for the manifolds.
#32 _73LJWhiteSL_
_73LJWhiteSL_
Posted 15 April 2007 - 05:50 PM
Thanks very much mate. :spoton:
Now it is 1" centre to centre correct?
Steve
#33 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 15 April 2007 - 11:21 PM
I added some weld on the edges of the holes, custom suspension cross shaft/upper control arm mounted
My Webpage
#34 _rorym_
Posted 16 April 2007 - 12:42 AM
Steve
Should be Steve,..but thats a big 1"...but the rest is OK.
#35 _jklumpp_
_jklumpp_
Posted 16 April 2007 - 01:45 PM
Well 1" centre to centre is what I did.... but then I was told 5/8", and seemed to start a bit of a war with some saying 5/8", and others 1", and both sides categorically stating that they were correct & the others didn't know what they were talking about!! :cry:
.... My front end was back in at this stage, so Idecided to run with it, and see how it goes... So far so good! Car drives & handles beautifully, and the desired wheel alignment setting where easily acheived, so I have no plans to change it at this point! :spoton:
P.s. it's a good idea to make some spacer blocks to replace some shims... I think I made mine about 12mm thick...
#36 _73LJWhiteSL_
_73LJWhiteSL_
Posted 16 April 2007 - 03:16 PM
I've had people tell me 1/2" as well... If you've done it 1" then i will do that as well.
When i eventually rebuild the front end. :tease:
Steve
#37 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 17 April 2007 - 12:07 AM
1/2 inch sounds about right as any more dosnt leave much meat near the holes, ie i welded it up to thicken it.
#38 rodomo
Posted 17 April 2007 - 12:15 AM
Not definitive but off the old forum:
Posted: Sat Apr 03, 2004 10:31 am Post subject:
Electra Blue
The suspension on the XU1 differs in that the mounting for the upper control arm is lowered on the crossmember. I dont have the actual measurement but you are probably correct in calling it an inch.
There are two sets of bolt holes which indicate that the lower one was drilled somewhere along the production line.
The 1970 service bulletin notes as important the the upper control arm is always reinstalled in the lower mounting position.
I would confidently assume that it was for handling purposes.
From what I have read this mod can be carried out on any LC/LJ Torana
but I would check on that before you pull out the old Black and Decker and start drilling a few holes.
This was disccussed sometime ago on this BB with some pretty good and informantive information. Perhaps someone with Search capabilities could locate it and post a link.
Posted: Sun Apr 04, 2004 5:41 pm Post subject:
mounting the upper wishbone 1 lower will also give it a higher roll
center thus giving the car less body roll in the front.
and this i would say is the reasoning behined the revised mounting
position
#39 _jklumpp_
_jklumpp_
Posted 17 April 2007 - 01:18 PM
Both Greg (82911) & Rory say 1"..... that's enough for me! :spoton:
#40 _rorym_
Posted 17 April 2007 - 02:40 PM
The XU1 release is in Viv Antonios book from GMH...It says 1"inch.
#41 _Bomber Watson_
Posted 17 April 2007 - 08:12 PM
so whats the verdict boys?? woth doing?
#42 _rorym_
Posted 17 April 2007 - 11:04 PM
Just Do It!
#43 _jklumpp_
_jklumpp_
Posted 18 April 2007 - 01:37 PM
No problems here!
#44 _Bomber Watson_
Posted 18 April 2007 - 07:53 PM
oh fine i will. i'll biro it in for when im tweaking the front suspension.
#45 _73LJWhiteSL_
_73LJWhiteSL_
Posted 19 April 2007 - 12:01 PM
Thats my plan as well, some paint, new bushes, new ball joints, and 4 new holes. :spoton:
Steve
#46 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 19 April 2007 - 12:45 PM
Hi all
I don't seem to be able to find the reference to "1 inch" in the Antoniou book.
In my copy there are references to "front suspension modifications" and "relocating lower control arms" on pages 25 and 27 - but no reference to 1 inch.
Anybody?
Bazza
#47 limo
limo
  • 2,673 posts
  • Car:most Torana models, Jag, Vauxhall, Triton, Staesman
Posted 19 April 2007 - 09:04 PM
why doesn't some just measure from top down to hole centre, I can do both XU1 and GTR or stocky but not till weekend
#48 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 19 April 2007 - 11:07 PM
limo
I would be interested to know the true centre to centre measurement for the XU-1. There are a number of people one these forums who know the correct measurement but are just not saying.
Bazza
#49 _73LJWhiteSL_
_73LJWhiteSL_
Posted 19 April 2007 - 11:49 PM
Are you suggesting that the measurement isn't 1" Bazza?
And maybe the people that know don't want to say anything for the same reason imformation about the identifying markings of genuine cars is guarded? :fool:
Steve
#50 limo
limo
  • 2,673 posts
Posted 21 April 2007 - 01:16 PM
Well that was an interesting exercise, all cars are LCs-- XU!, GTR and stocky 4dr
but unfortunately the front ends are still mounted, no motors
tried about 8 different points of referrence, problems due to wheel align shims and welding pionts but the diff is not "1 inch"
variation between 15 and 20mm lower when calculated from readings between XU1 and others, so disregarded most and used 3 pts to measure
seemed most accurate and easiest to get at
variation 16.1 to 17.5 mm, hard to get vernier in and in line
will be dismantling the GTR and XU1 fronts soon so can get at the holes directly and get better measurement
I would expect the measurement to be 11/16" but could be 5/8" as someone suggested but not 1"
