Lowering top arm on LJ
71 replies to this topic
#51 _gtr161s_
_gtr161s_
Posted 21 April 2007 - 04:53 PM
i think you will find the correct measurement is 5/8" centre to centre.
1" (one) would be dangerously unsafe as there isnt enough meat left to safely support the bolts and arm.
#52 _73LJWhiteSL_
_73LJWhiteSL_
Posted 22 April 2007 - 02:04 PM
So it sounds like 5/8...
Steve
#53 _73LJWhiteSL_
_73LJWhiteSL_
Posted 29 April 2007 - 12:18 AM
The silence is deafening... :rolleyes: So does anybody else want to comment about this?
The correct distance is 5/8" according to limos measurements.
Steve
#54 warrenm
Posted 29 April 2007 - 07:46 AM
11/16" (17mm)but no further as theres not enough metal to support the bolts.
#55 limo
limo
  • 2,673 posts
  • Car:most Torana models, Jag, Vauxhall, Triton, Staesman
Posted 29 April 2007 - 04:35 PM
Steve
don't quote me yet
not easy measuring upside down while still in car,
got the GTR one out, Xu1 next weekend if time then I will remove bolts measure both from top down and subtract
#56 _73LJWhiteSL_
_73LJWhiteSL_
Posted 29 April 2007 - 10:26 PM
Thanks for that limo, that will be much appreciated. :spoton:
Steve
#57 limo
limo
  • 2,673 posts
Posted 06 May 2007 - 05:08 PM
got the XU1 front end out today, interesting
there are two sets of holes in it for upper mounts,
one standard, one lower down and the $64 question, how far down
5/8" looks to be the go
there is very little metal in front of front hole, less than 5mm
#58 _rorym_
Posted 06 May 2007 - 05:34 PM
Irrespective...the lower you can go...the better the improvement. Read M@s thread on same in LH/ suspension settings. But each to his own. I went down 1" and still had plenty of metal left, we are almost getting down to were rear exhaust hangers painted or gal dipped. Move forward guys..do it at the measurement you are comfortable with and reap the handling benefits. .
Edited by rorym, 06 May 2007 - 05:36 PM.
#59 _ber914_
_ber914_
Posted 17 May 2007 - 07:05 PM
With this mod, does one still adjust the control rod the same as standard( i.e I think 25mm of thread exposed out of the rear nut)? I am aiming for about 5 deg positive castor.
Robert
#60 gtrboyy
Posted 20 May 2007 - 02:51 PM
If you do lower the control arms does it require more or less shims?
#61 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 31 May 2007 - 11:30 PM
i think when you get a wheel algnment they will work that out, as you should get one after the mod i would think.
#62 gtrboyy
Posted 02 June 2007 - 02:56 PM
Last time I ended up doing most of the wheel alignment myself,as nobody around my way wanted to change shims on a v8 lc.I got it pretty close & the the wheel alignment guy finished it off.
Took me about a day to get it close.PITA of a job with the v8 in there.
#63 _monaroman68_
_monaroman68_
Posted 25 June 2007 - 12:21 PM
Can this mod be done on a HK frontend ? I no its not torana related but pretty close.
#64 _big_als_army_
_big_als_army_
Posted 30 June 2007 - 12:28 AM
When I had the front end out of my LC to rebuild and re-bush it, I was under the assumption that 1" was the correct measurement centre to centre so I marked it up and put the base of the drill bit where the hole was to be drilled to see how it looked. I had the Fiv book right there next to me to use the diagram but there are no measurements on it. Its definitely not 1" as there is no meat left and you end up with what jklumpp has done to his. His looks like its measured correctly as thats what mine would have looked like had I done it. No knowing exactly what the measurement was, I didn't do it at all. I would say limo's measurement of 5/8" is the one to go off as when I worked out it wasn't 1", it looked like about 5/8" would be right. 1" is psycho, you are asking for trouble, especially with a V8.
#65 _73LJWhiteSL_
_73LJWhiteSL_
Posted 30 June 2007 - 10:18 AM
So 5/8" should be fine without add extra metal there?
Steve
#66 _big_als_army_
_big_als_army_
Posted 30 June 2007 - 01:57 PM
5/8" seems to be the actual XU-1 measurement. I wouldn't go much further than that.
#67 _jklumpp_
_jklumpp_
Posted 03 July 2007 - 02:55 PM
still no problems with mine....except for the clutch rat trap fouling the top wishbone.... but some handy work with the grinder fixed that!
Wheel alignment was no drama to get the desired settings, and car drives & handles beautifully on the road & track.....
I do agree however that all information that has come to light seems to suggest that 5/8" is the correct XU-1 measurement.....just a shame more people weren't forthcoming with that info when i did the mod....
#68 _big_als_army_
_big_als_army_
Posted 03 July 2007 - 05:00 PM
As I said though, when I went to do mine, it was obvious that 1" was was too far down. As long as it worked for you and you are happy with the safety of your car then its all good. Probably the further down you can get it, the better its going to handle anyway and its not like you are doing it to replicate an XU-1 exactly.
#69 Green Goblin
Green Goblin
  • 30 posts
  • Name:Brian
  • Car:4/72 LJ Torana 'S' Model 2 door
Posted 22 June 2021 - 11:13 AM
Hi
Hope this helps
Bazza
Hi Bazza,
Yes this post is from some time ago... though I was wondering if by some slim chance you might be able to send me that photo that you have posted of this mod? I'm searching the forum but this post looks to be most relevant to this mod..
Thanks' heaps mate.
#70 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 23 June 2021 - 02:28 PM
Hi Bazza,
Thanks' heaps mate.
Now sorted.
#71 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 844 posts
  • Name:JASO
Posted 23 June 2021 - 08:24 PM
Post #10. Below link....is it close to to the requiremnt
http://www.gmh-toran...ole-easy-tiger/
Edited by 73SUNBURSTEXYOUWON, 23 June 2021 - 08:25 PM.
#72 rodomo
Posted 23 June 2021 - 11:23 PM
Posted: Sat Apr 03, 2004 10:31 am    Post subject:
________________________________________
Electra Blue
The suspension on the XU1 differs in that the mounting for the upper control arm is lowered on the crossmember. I don’t have the actual measurement but you are probably correct in calling it an inch.
There are two sets of bolt holes which indicate that the lower one was drilled somewhere along the production line.
The 1970 service bulletin notes as important the the upper control arm is always reinstalled in the lower mounting position.
I would confidently assume that it was for handling purposes.
From what I have read this mod can be carried out on any LC/LJ Torana
but I would check on that before you pull out the old Black and Decker and start drilling a few holes.
This was disccussed sometime ago on this BB with some pretty good and informantive information. Perhaps someone with Search capabilities could locate it and post a link.
Posted: Sun Apr 04, 2004 5:41 pm    Post subject:
mounting the upper wishbone 1” lower will also give it a higher roll
center thus giving the car less body roll in the front.
and this i would say is the reasoning behined the revised mounting
position
