MHDT L34 Bond/Harvey 76 Car
1760 replies to this topic
#1651 _MRNOS_
_MRNOS_
Posted 19 August 2008 - 12:42 PM
I don't think you'd really notice the difference... with the stripes and stickers all over them, you'd have to know what you're looking at to spot the difference. It's probably the easiest and cheapest option, but maybe not the best...
Would give it a fat ass though :D
#1652 RIM-010
Posted 19 August 2008 - 12:45 PM
Sure would :D especially with those 16x10's :spoton:
You're not running a drop tank though, are you?
#1653 _MRNOS_
_MRNOS_
Posted 19 August 2008 - 12:47 PM
No tank with this car, next one will though :spoton:
#1654 RIM-010
Posted 19 August 2008 - 12:49 PM
A9X replica? Brock's 77 Hatch?
#1655 _MRNOS_
_MRNOS_
Posted 19 August 2008 - 12:56 PM
Would love to do a hatch, but hatches lately are expensive and rusty, or really good...and expensive, so another sedan A9X replica this time, another HDT
#1656 RIM-010
Posted 19 August 2008 - 01:02 PM
I thought you might've already had a Hatch stashed somewhere :P If you can't find a half decent one relatively cheap, no one can!
Sounds like the replica bug has bitten you hard :D
#1657 _MRNOS_
_MRNOS_
Posted 19 August 2008 - 01:04 PM
I did have a hatch shell but sold it to a forum member
#1658 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
  • Car:76 LX Sedan, 4 seater
Posted 19 August 2008 - 03:24 PM
Hmmmm, that means I can't do one of the cars I was deciding on.......
Big fan of the co-driver too.....
How about you have the A9X sedan, and you can put the paint on mine for the third L34??
Let me know how much, eh?
Grant..
#1659 _MRNOS_
_MRNOS_
Posted 19 August 2008 - 04:03 PM
Grant..
What car were you deciding on?
Which co-driver?
Once the A9X replica is almost done i'll probably sell off the L34, im just keeping the mild 308 in it, test bed car, the 355 will go into the next car
Even though its still around-sorta- this is my next one http://www.autopics....c.html?cache=no
Edited by MRNOS, 19 August 2008 - 04:08 PM.
#1660 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
Posted 19 August 2008 - 05:14 PM
That's the one - #8 HDT A9X sedan - upgrade of Brocks L34 i think - Bathurst:O'Brien/Ron Harrop.
Also looking at some more obscure A9X sedans.
If you wanna do it as the "other L34" for me, let me know how much for the paintjob.
You should be a pro at that scheme by now.
Grant..
#1661 _MRNOS_
_MRNOS_
Posted 19 August 2008 - 05:17 PM
Grant..
Depends on ow much body work needed, prep etc etc, would have to see the car again
#1662 makka
makka
    A møøse once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 19 August 2008 - 07:09 PM
what are you going to gain from changing the brakes?
will you gain anything from swithching the inners for the outers on the 16's or are they 5" in and out?
and with the A9X flares it would be a biggish job to change them, the bolt holes are in different places to the L34 flares
Edited by makka, 19 August 2008 - 07:11 PM.
#1663 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
Posted 19 August 2008 - 08:23 PM
Makka,
the Commonwhore brakes have a spacer which pushes them outboard.
Changing them over reduces the bolt up length.
See the Skyline BW threads.
Grant..
#1664 _MRNOS_
_MRNOS_
Posted 19 August 2008 - 08:28 PM
If I go to skyline brakes they take away the extra 20mm, with the commodore brake setup it has the inner shoe/hand brake setup, the skyline doesnt. If you look at Rorys diff, it pretty much goes from the axle flange to the disc, the commodore setup goes, axle flange, inner drum then the disc.
The 16's and my other 15x10's both have 5inch inner and outer rims.
As for the flares ive seen 2 sets that have the same bolt holes but are wider, would just be a matter of finding some.
I dont really want to modify this diff too much, bit of a waste, so I may end selling it if I cant change the brakes or do the flares.
#1665 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 19 August 2008 - 08:35 PM
my commodore discs have the disc faces directly on the axle faces
#1666 _rocket_
_rocket_
Posted 20 August 2008 - 09:47 AM
Daren, I have some 150mm flares, they are a 4 door flare, but no cut for the door to open, try them if you want.
#1667 _MRNOS_
_MRNOS_
Posted 20 August 2008 - 09:57 AM
Might do that, will be interested to see if the bolt holes line up with the smaller ones
#1668 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
Posted 20 August 2008 - 12:04 PM
The rare "coupe" flares eh rocket :P
Makka,
do your calipers have a handbrake in them?
What model commodore?
Grant..
#1669 rodomo
Posted 20 August 2008 - 03:36 PM
My Bombadoor originaly had a 10 bolt salisbury.
It now has a VL wagon BW.
I have a VN BW in the shed.
They are all h/brake in disc.
#1670 _rorym_
Posted 20 August 2008 - 05:49 PM
Yeah I have one at the new shed...shitty setup with the brake shoes on the inside...the Nissan thing makes more sense.
#1671 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 20 August 2008 - 06:15 PM
Grant, they have the drum type brake on the inside. I am sure that they dont space anything out though as the drum setup mounts to the axle housing face with a 3mm or so plate. I will see is I can take them off tomorrow and have a look.
They are off a VP
#1672 _rorym_
Posted 20 August 2008 - 06:22 PM
As NOS says...there is a 20-25mm lost one the Commodore internal brake system each side...check it out.
#1673 _Bomber Watson_
Posted 20 August 2008 - 06:27 PM
The bearing to mount up flange measurement on the axle is different Makka. Thats where the distance is made up.
#1674 _rorym_
Posted 20 August 2008 - 06:30 PM
Bomber! You're back Whiteman!!..Finished with that wench and come back to the fold???
#1675 _rocket_
_rocket_
Posted 20 August 2008 - 06:41 PM
Grant, not sure what the flares are, they seem to be 4 door style, finishing short on the sill, but one peice.
